blink
Prispevkov: 204
Pridružen: Če dec 11, 2003 5:59 pm
visokosvetleči LED žarometi
Napisal/-a blink Če apr 08, 2004 12:47 pm
A kdo ve kaj več o teh žarometih? Take kot ma npr. Audi Le mans. To pa more dobr svetit :)
http://www.kak.net/audi/audilemansquatt ... tro34s.jpg
Asterix
Prispevkov: 1385
Napisal/-a Asterix Če apr 08, 2004 12:54 pm
You are not authorized to view this page
You might not have permission to view this directory or page using the credentials you supplied.
If you believe you should be able to view this directory or page, please try to contact the Web site by using any e-mail address or phone number that may be listed on the www.kak.net home page.
You can click Search to look for information on the Internet.
HTTP Error 403 - Forbidden
Internet Explorer
HORSE
Prispevkov: 1899
Pridružen: Sr sep 25, 2002 6:24 pm
Kraj: Promised Land
Napisal/-a HORSE Če apr 08, 2004 1:03 pm
Kolikor jaz vem, so te lučke samo kot dnevne luči - malo močnejše pozicijske... Ponoči pa, ko vklopiš (se vklopijo same) zasenčene luči (xenon) pa te ledice ugasnejo...
blink
Prispevkov: 204
Napisal/-a blink Če apr 08, 2004 1:22 pm
Klikn refresh, pa se pokaže fotka.
blink
Prispevkov: 204
Napisal/-a blink Če apr 08, 2004 1:27 pm
Ni tle nič xenona, samo LED.
LED - these three letters stand for “light-emitting diode” - a technology with confirmed advantages, such as a tenfold reduction in power consumption compared with conventional bulbs, but with a very much longer operating life.
Nor is that all - the LED principle has even more potential for future uses. In a later development stage, LED headlights will enable dynamic cornering beams to be provided by a system that does not use any moving parts. By switching additional LED elements on and off electronically, the light beam can be varied in width and direction.
Another LED advantage is that the lighting elements take up less room than conventional ones, so that the designers have more scope for exercising their talent. The 17 cooled light sources on each side are much closer to the transparent cover than is normally the case, and the covers too are of reduced size, so that the entire front end of the car looks more compact and tauter in its styling. The light-emitting diodes for the flashing turn indicators separate the two LED blocks used for the dipped and full headlight beams. The side turn indicator repeaters, housed in the base of the outside mirrors, also use this new technology.
Seen from the side, the rear-end contours consists of an interplay of concave and convex lines. Below the clearly defined spoiler lip is a shallow, vertical surface framed at the sides by the rear light assemblies, which also use LEDs. The light strip for the third brake light runs across the entire width of the roof at the read end of the transparent engine cover.
Nixxon
Prispevkov: 3646
Kraj: Vrhnika
Napisal/-a Nixxon Pe apr 09, 2004 7:57 am
To je zaenkrat še v fazi razvoja, bo še par let preden bo na cesti.
blink
Prispevkov: 204
Napisal/-a blink Če okt 21, 2004 10:11 am
Vse o teh žarometih je na tem linku......
http://www.audiworld.com/news/03/050403b/content.shtml
ITA_car_fan
Prispevkov: 571
Pridružen: Po jul 05, 2004 8:40 am
Kraj: Velenje
Napisal/-a ITA_car_fan Če okt 21, 2004 10:16 am
raje odnehaj in ostani pr H4 :lol: mislim da bi moral cel kup stvari spreminjat za inštalacijo takih luči.
deadly getaways TM
blink
Prispevkov: 204
Napisal/-a blink Če okt 21, 2004 12:28 pm
Sej ne mislem tega delat... :lol: slucajn sem najdu link o teh žarometih ki jih ma Audi Le mans in Nuvoulari.
Po forumu brska: 0 registriranih uporabnikov in 67 gostov
