fare
Prispevkov: 2085
STOP - izdelki?
Napisal/-a fare Ne maj 22, 2005 6:18 pm
Ej folk,
ma kdo izkušnje z STOP izdelki ki jih prodajajo na pumpah in Spar-u?
ps: tiste tekocinice za vse vrste goriv, ki naj bi bile kot Aspirin za mašine.
Še posebej me zanima kako se TDi zverince odzivajo na to?
Jeaka
Prispevkov: 536
Pridružen: Sr maj 11, 2005 11:37 am
Kraj: lj
Napisal/-a Jeaka Ne maj 22, 2005 6:22 pm
jst ti svetujm da se cim bol izogibaš tega s...ja!!! :cry
Napisal/-a lisko Ne maj 22, 2005 8:16 pm
A niso to STP izdelki? Tist sem jaz zadnjič kupo kot dodatek k naftii..... Pa se mi zdi da je kr nekak razlika.... ne bom pa trdil..... pač vsak po svoje.
pugi405
Prispevkov: 1970
Napisal/-a pugi405 Ne maj 22, 2005 9:05 pm
Jeaka je napisal/-a:jst ti svetujm da se cim bol izogibaš tega s...ja!!! :cry
Lej kaj sem ti najdu na eni strani...
Gre za review STP izdelka oz. kake izkušnje je mel nekdo z aditivom:
Mal moraš angl. znat :P
never believed any of those so called miracle additives. Just keep a well maintained machine and keep truckin.
The only time I could see a benefit is when your engine is already wasted, what do you got to loose.
My father used to run some of that STP oil treatment, (some kind of oil thickner) in the summer in one of our older cars. After about 5 years, whenever you came to a stop, the car would create large amounts of smoke screen. Pulled off the valve covers, and all the oil return ports were gummed up causing oil to be sucked in the PCV valve, not to mention the lack of oil in the crankcase because all the oil was stuck in the heads.
Never again. Now he just keeps clean fresh oil in there every 2k miles.
lonestar is offline
ahiM
Prispevkov: 799
Napisal/-a ahiM To maj 24, 2005 6:12 pm
Mah, to je stran metanje denarja. Sej tud ne moreš pričakovat od flaškice za enga jurja, da bo delala čudeže. Drgač bi vsi galone tega noter zlival pa noben nebi hodu na servise. Edina pametna stvar od teh "flašk" je QMI, ki pa ni več tako poceni. Samo ne vem, kako je s QMI in dizli.
Ti samo redno menjavaj (oz. dolivaj, če je treba) olje in poskrbi da bo le-to karseda kvalitetno. In seveda upoštevaj ABC vožnje pri dizelskih motorjih.
