hermand
Prispevkov: 416
Kraj: Rogaška Slatina
problem vžiganja audija a4 1,6 (ADP) letnik 1995
Napisal/-a hermand Ne apr 06, 2003 6:24 pm
Imam audija a4, ki ima naslednjo težavo:
ko vročega ugasnem in ga po 20 minutah hočem spet vžgati, ne vžge takoj ampak šele po kakšnih 5 sekundah verglanja, nato pa vžge in če spet ugasnem in ga spet takoj vžgem, normalno vžge.
Menjal sem že katalizator in lambdo sondo.
pugi405
Prispevkov: 1970
Napisal/-a pugi405 Ne apr 06, 2003 6:33 pm
HOT START PROBLEM
During a hot start, the time that the thermo-time switch applies ground to the cold start valve is significantly reduced. Various Bosch publications indicate that it may be as short as three seconds, however my experience suggests that it is often much shorter than this. So, when you go to start your hot engine, particularly on a hot day, very little extra fuel is injected into the engine. On an older engine, this is often not enough to start the engine. To compound the problem, the thermo-time switch has now timed out, and must cool before it will supply the necessary ground to the cold start valve to get the extra fuel to the engine for a start. On a hot day this can be as much as 20 minutes. Too long to wait, if you need to get somewhere. eeeehm, upam, da znaš kej ingliš, ker se mi ni dal prevajat. :P
LP, Pugy.
phoebus
Prispevkov: 1496
Napisal/-a phoebus Sr apr 09, 2003 10:53 pm
Isto sm mislu jaz prasat za Skodilackija (stara favorit, nc elektronke).... pri -20 vzge, polet pa vroca masina ne spljoh brez parih sekund verglanja...
Dobr, tle govori o Bosch zadevscinahi....ampak Skodilacki ma frgazar, edino "elektronsko" je pa "avtomatski cok" :D
kaj je pa tam lahko narobe?
Kot sem rekel - pri se takem mrazu uzge vedno iz prve, se nc ne matra...
Ideje? :?
patrick123
Prispevkov: 80
Pridružen: So feb 22, 2003 10:44 pm
Napisal/-a patrick123 Če apr 10, 2003 1:14 pm
pr škodi ti verjeten sam frgazr preliva ko se segreje in zato takoj ne užge. :)
Po forumu brska: 0 registriranih uporabnikov in 305 gostov
