tejo996
Prispevkov: 36
Pridružen: So jun 04, 2005 8:57 pm
TEST
Napisal/-a tejo996 To avg 23, 2005 4:14 pm
a mi lahko kdo zrihta teste od avtu
in sicer za bravo hgt(oba tipa) in pa za fiat coupe 2.0 20v turbo
TOYOTA
Prispevkov: 1167
Napisal/-a TOYOTA To avg 23, 2005 4:23 pm
našel sem samo podatke od obeh, če ti kaj pomagajo,pa upam da razumete ker so v angelščini.....
FIAT BRAVO HGT 20V letnik (1998)
Type: 4/5S HBK
Number of doors: 3
Dimensions
Wheelbase: 2540 mm 100.00 in
Track front: 1471 mm 57.91 in
Track rear: 1430 mm 56.29 in
Length: 4030 mm 158.66 in
Width: 1750 mm 68.89 in
Kerb weight: 1190 kg 2623.49 lb
Fuel capacity: 60 l 15.85 US gal
Engine
Manufacturer: Fiat
Type: S-5
DOHC
20 valves total
4 valves per cylinder
Bore x stroke: 82.00mm × 75.65mm
Bore / stroke ratio: 1.08
Displacement: 1998 cc 121.92 cu in
Compression: 10.70:1
Fuel system: SMPFi
Aspiration: Normal
Catalytic Converter: Y
Max. output: 154.1 PS (152.0 bhp) (113.3 kW)@65000 rpm
Max. torque: 186.0 Nm (137 lbft) (19 kgm)@3750 rpm
Coolant: Water
Specific output: 76.1 bhp/litre
Specific torque: 93.09 Nm/litre
Performance
0-100km/h: 8 s
Kilometre: 29.00s
Top speed: 213 km/h
Fuel consumption: 13.1/7.2/9.4 l/100km urban/extra-urban/combined
Power to weight: 127.73 bhp/ton
Chasis
Engine location: Front
Engine alignment: Transverse
Steering: rack & pinion PAS
Turning circle: 10.80 m
Suspension front: I.MS.LW.ARB.
Suspension rear: I.ARB.
Tyres front: 195/55 R 15 84V
Tyres rear: 195/55 R 14 84V
Brakes: VeDi/Di-S
Brake diametre: 284/240 mm
Transmission: 5M
Drive: FWD
Top gear ratio: 0.97
Final drive ratio: 3.56
FIAT COUPE 2.0 20V TURBO (letnik 1996)
Type: 2+2 FHC
Number of doors: 2
Dimensions
Track front: 1491 mm 58.70 in
Track rear: 1468 mm 57.79 in
Length: 4250 mm 167.32 in
Width: 1760 mm 69.29 in
Kerb weight: 1310 kg 2888.05 lb
Weight distribution F/R: 68 %
Fuel capacity: 63 l 16.64 US gal
Engine
Manufacturer: Fiat
Type: S-5
DOHC
20 valves total
Compression: 8.50:1
Fuel system: MPFi
Aspiration: Turbo
Intercooler: Y
Max. output: 219 PS (216.0 bhp) (161.1 kW)@5750 rpm
Max. torque: 310.0 Nm (229 lbft) (31.6 kgm)@2500 rpm
Coolant: Water
Specific output: 108.1 bhp/litre
Specific torque: 155.16 Nm/litre
Performance
0-60mph: 6 s
0-100km/h: 6.5 s
0-100mph: 14.5 s
Quarter mile: 14.60s
Kilometre: 25.90s
Top speed: 250 km/h
Power to weight: 164.89 bhp/ton
Chasis
Turns lock-to-lock: 2.200
Turning circle: 10.40 m
Suspension front: I.MS.LW.CS.ARB.
Suspension rear: I.TA.CS.ARB.
Tyres front: 225/45 R 16 Z
Tyres rear: 225/45 R 16 Z
Brakes: VeDi/VeDi-S
Brake diametre: 305/251 mm
Transmission: 5M
Drive: FWD
Top gear ratio: 0.91
Final drive ratio: 3.11
killah bee
Smrtonosni čebelj
Prispevkov: 4321
Kraj: RS
Napisal/-a killah bee To avg 23, 2005 4:26 pm
tukaj imaš kar iščeš in še mnogo več :D
http://www.carfolio.com
dejan84
Prispevkov: 2918
Kraj: Cesta moj duma
Napisal/-a dejan84 To avg 23, 2005 4:33 pm
Jan_87
Prispevkov: 104
Pridružen: Pe jul 08, 2005 4:50 pm
Kraj: Slovenia
Re: TEST
Napisal/-a Jan_87 To avg 23, 2005 4:38 pm
tejo996 je napisal/-a:a mi lahko kdo zrihta teste od avtu
Evo Coupe turbo (sicer je to primerjalni test, v tujem jeziku :P): http://www.puntotd.com/coupevsalfavshonda.html
...in še za HGT-ja (v slo) : http://fiat.5.forumer.com/index.php?showtopic=631
Vir: Fiat forum 8)
tejo996
Prispevkov: 36
Napisal/-a tejo996 Sr avg 24, 2005 6:48 pm
EJ FANTJE VI STE CARI
HVALA ZA TESTE
I LOVE FIAT
Po forumu brska: 0 registriranih uporabnikov in 47 gostov
