ronnie
Prispevkov: 260
Akumulatorji Bosch
Napisal/-a ronnie Pe okt 16, 2009 10:59 am
L.P.
Sem že brskal po netu pa nikjer nisem našel konkretne razlage.
Zanima me, kaj je razlika med akumulatorji Bosch Silver S3; S4 in S5 ?
Hvala!
kšn dan ga tri dni serjemo , kšn dan pa cel teden
MatejW
Prispevkov: 1495
Napisal/-a MatejW Pe okt 16, 2009 6:06 pm
Visja st. modela, pomeni vecjo kapaciteto Ah, posledicno so tudi dimenzije vecje ...
Beni-Norc
Prispevkov: 109
Pridružen: To mar 04, 2008 3:58 pm
Kraj: Črnomelj, Maribor
Re: Akumulatorji Bosch
Napisal/-a Beni-Norc Ne feb 05, 2012 1:59 pm
ne da pametujem, samo včasih se oglašate prav eni dribci brez utemeljene podlage..
tudi sam sem iskal razlike, pa sem malo pogooglal in lahko marsikaj najdeš. pa bom postal, da bo mogoče še komu v pomoč koristen post..
This is from the Bosche website (which I am surprised you didn't bother to check out):
_______________________________________________________
Advantages of the Bosch-Battery S3
For older and smaller vehicles
Reliability and Starting Power at the right price
________________________________________________________
Advantages of the Bosch-Battery S4
15% higher than standard car-batteries
20% higher service life thanks to innovative PowerFrame technology
For all vehicle classes
Reliably guarantees the energy needed for an average number of electrical consumers (electric windows, radio, air-conditioning)
Meets permanently the high demands made by international car manufacturers in electrical terms (A, Ah)
Also suitable for asian vehicles
Covers 97% of the market
The powerful energy source for safe starting also fulfils the increased convenience demands of middle-class cars. Also, covering 97% of the market helps meet the special requirements of Asian cars.
___________________________________________________________________
Advantages of Bosch-Battery S5
30% higher cold cranking power than standard car batteries
Safe starting also in extreme temperatures
30% higher service life thanks to innovative PowerFrame technology
Fulfills and surpasses original-equipment recommendations
85% Market Coverage
Dependable supply of the safety-relevant extra consumers, e.g., ESP, ABS, etc.
Minimal self-discharge
Extreme short-distance tolerance
Great class calls for great battery power: For powerful engines to start safely and for the dependable power supply of wide-ranging convenience features.
____________________________________________________________________
The power plant for maximum demands: Bosch-Battery S6 with AGM-Technology
The new AGM battery technology by Bosch is absolutely maintenance-free, 100% leak-proof in any position and extremely vibration-proof.
Dependably ensuring the multitude of comfort, safety and system functions of the latest generation of cars requires a battery technology that meets extreme energy demands while promising reliable starting power at the same time. The new Bosch-Battery S6 with AGM Technology (Absorbent Glass Mat) guarantees this power for maximum performance in starting and power supply everyday.
Thanks to AGM-Technology with fixed electrolyte, the Bosch-Battery S6 is extremely cycle-proof and long lasting. Bosch even recommends the Bosch-Battery S6 for middle-class cars with power starting at 3,500 watts and for vehicles with an extreme cycle load, such as taxis.
Constant top performance where others throw in the towel
Starting too many electrical consumers simultaneously will push a generator to its capacity limits. Basic starter batteries can balance this deficiency a maximum of 100 times at the height of their capacities. After that they begin to loose considerable power, which leads to troublesome starts. The Bosch S6 can balance it 300 times. Its high energy flow rate ensures the output and input of lots of energy.
Depending on their equipment, the Bosch S6 is also recommendable for cars currently equipped with a 66 Ah-, 74 Ah-, 88 Ah-, 90 Ah- and a 100 Ah-battery as a standard.
Advantages of the AGM-Technology
Extremely cycle- and vibration-resistant
100 % maintenance-free, tilt-resistant and safe from leaks
Double action time, triple energy flow rate
Installable in any position
ThugBoy
Prispevkov: 534
Pridružen: To feb 24, 2004 10:18 pm
Kraj: Morje
Napisal/-a ThugBoy Ne feb 05, 2012 2:12 pm
gre se za to da ima vsaka višja serija več zagonskega toka. najbolj simpl razlaga
Even When They Kill Me They Can't Never Take A Game From Young G
BlueViper02
Prispevkov: 1
Pridružen: So jun 02, 2012 10:03 am
Napisal/-a BlueViper02 So jun 02, 2012 10:09 am
Za Bosch dela akumulatorje Varta.
S3 = Varta Black (Ca-Ca tehnologija)
S4 = Varta Blue (Ca-Ca tehnologija, izboljsana mreza, posledicno vecja kapaciteta na tezo in boljsa trajnost)
S5 = Varta Silver (Ca-Ca+Ag tehnologija, dodano srebro zmanjsa obcutljivost na korozivne procese v celicah, povecana trajnost)
Po forumu brska: 0 registriranih uporabnikov in 81 gostov
