Levo, temnejše kupljeno direktno od uvoznika, desno iz leclerca.
Razlikuje se tudi barva flaše, način odpiranja in kvaliteta embalaže. Kaj menite ?
Mgajvr je napisal/-a:se pregledal embalaže od elf-a excelium in ugotovil da sta skoraj po vseh napisih identični , tudi piše na obeh made in ec...
vse skupaj mi je malo čudno. a ni elf delan v franciji?
Stefi je napisal/-a:Bi verjel, da si en bolha trgovc upa prodajat ponaredke, da pa si to privošči Leclerc, mi je že manj verjetno.
Je kdo pri Francozu preveril, od kod je njihovo olje.
Ali pa je zadeva morda zrela za tržno inšpekcijo.
Poslal slike in mail Total avto industrija. Njihov odgovor:
Concerning the colour of the 2 oils being different:
The base oils being used to make the Quartz 7000 10W/40 engine oils can vary from batch to batch depending on the crude and refining process used, this is why we do not use colour as a quality control check.
We check for additives being used in the correct amount as well as a lot of other physical and chemical tests to ensure that the oil is in specification before leaving the site.
Providing both bottles were sealed when you purchased them, they can be mixed.
The colour of the plastic bottles and labels also depend on the batches of plastic used as well as the labels and can also fade with sunlight.
I hope this helps to answer your questions.
Best regards
Bob Wood
Field Engineer Total UK
Po forumu brska: 0 registriranih uporabnikov in 73 gostov
