mihakrapez
Prispevkov: 274
Pridružen: Če mar 04, 2004 3:17 pm
Napisal/-a mihakrapez To okt 18, 2005 10:44 am
Zadevo je treba inštalirati pravilno.
Zadeva ima starforce zaščito (to pomeni da je zelo zelo zaščitena).
pri inštalaciji je potrebno biti zelo dosleden (to velja za celo igro -ne za demo)
1. You must have Windows XP with SP2 in order of playing Worms4
2. IDE PCI Controller Drivers MUST be OS STANDARD IDE PCI Drivers.
3. Unpack file sfcure01 that's in tools.rar and launch file !setup.bat
through MS-Dos Prompt and reboot your box.
4. If u have AMD64, then use sfcure_x64 that works same way as the other.
5. Check if all option of Daemon or Alcohol are activated especially
RMPS option.
6. Mount Alcohol 120% img and install the game.
7. Once installation is complete, launch sfdrup.exe to update StarForce3
drivers and reboot the box.
8. Launch through MS-Dos Prompt the file !start.bat that's in the unpacked
file sfcure01.
9. Unpack file sfn.rar e launch sfn.exe (StarForce Nightmare 1.12)
10 Select in this order "Disable node" , "Disable CD" , "Disable node" , and
the IDE channel you use for real CD/DVD units (Pr. Slave , Sc. Master o Sc.
Slave ) , depending on how your IDE units are connected
11. Launch the game and use this serial: *****-*****-*****-*****-***** .
12. Play.
Further Hints For Common Problems
1. If you installed any bus monitoring tool (ide or scsi) such BusHound
uninstall it as it gives some troubles.
2. If launching !start.bat you get a system error message like "System Error .1
Not correct function", do this: edit boot.ini file that u find in C: root.
As boot.ini is a hidden file, be sure u set the system to show u hidden files.
Edit boot.ini and change the string with /noexecute=optin /fastdetect
to /execute=optin /fastdetect.
3. Reboot your PC and relaunch !start.bat. This way you should have solved your
incompatibility problems.
4. You have to virtually mount the game with Alcohol (even if Daemon Tools
should do as well).
mugen
Prispevkov: 182
Pridružen: So sep 25, 2004 12:50 pm
Napisal/-a mugen To nov 08, 2005 4:39 pm
jz hočem igrat pa mi napiše error pa da naj dam cd v drug disk..........zdj ne razumem čist kaj piše tm spodu k sm tud gledu navodila v beležnici zravn....ne razumem tistga in prosm nj mi kdo da napotke čene bom v kratkem znoru......komi že čakam d bom špilu
mihakrapez
Prispevkov: 274
Napisal/-a mihakrapez Sr nov 09, 2005 9:37 am
NA žalost zadevo ščiti starforce:(
Se ne da skrekati. Najbolj ti priporočam, da zadevo kupiš.
Jaz sem probal pa mi ni ratalo pa tudi forume na netu sem bral pa pravijo da ni mogoče. Enim je ratalo samo po veliko truda vendar ne za dolgo.
(baje da med igro neki preverja in te pol ven vrže).
Na žalost
Lp,
mihakrapez
mihakrapez
Prispevkov: 274
Napisal/-a mihakrapez Po nov 28, 2005 3:54 pm
Stratus_ je napisal/-a:pa sej tale igrca je prou ql..sploh k si daš diff na 80% :lol:
pa si ti to dejansko spelov ali te je pol zavrtelo.
Mene zmeri zavrti (na PRO SEVEDA)
