metallic
Prispevkov: 2636
Napisal/-a metallic Ne nov 21, 2004 10:36 am
Mc Čun je napisal/-a:Za wide kit moraš narediti outrun z nekim določenim racerom. Dobiš pa še unique RIMS (Lexani), hood, performance upgrade, poslikavo, spojler,... :)
Thx. ;)
Pro2Type
Prispevkov: 535
Pridružen: Sr okt 29, 2003 4:25 pm
Kraj: Povsod me je dost!
Napisal/-a Pro2Type Ne nov 21, 2004 10:57 am
FireSTORM--- kva a mislš da sm tok bukov da to ne vem. Mam mrežo doma postavleno z 3 račinalniki, pa še kej druzga tud pa server pa tako naprej, tak da res ne vem kaj je to LAN! :?
Mene sam zanima zakaj noče delat, vsaj v piratski verziji ne! En server se lahk postav na računalniku, sam se poj ne more gor nuben povezat! Moram poiskat kak MOD ali PATCH!
Prašam pa zato da vem če je že kdo se s tem ubadal!
svarci
Prispevkov: 299
Pridružen: To avg 19, 2003 12:37 am
Napisal/-a svarci Ne nov 21, 2004 11:08 am
Jaz sem tkole naredu, pa mi vse dela brez probelma... :D
ok guys, since u want to play on LAN, i think that u know how work a network and Tcp/Ip, and that u'll certainly understand what i will write below :
i got the same pb u have when i tried to make a lan game with another friend. My ip : 192.168.0.1, his : 192.168.0.2, both subnet mask : 255.255.255.0, and both computers in the same workgroup.
Well, no way to pass the "Connecting to Lobby" message with this configuration, and this on both pcs.
Now the solution : just on one pc (the computer which will be the server), u go to ur Tcp/Ip properties (u know, where u put ur ip address and subnet mask), and on the line below the line subnet mask, u just copy the same ip address that is put. For example :
ip : 192.168.0.1
defaut bridge(dont know if it's this word since im french, ) : nothing.nothing.nothing.nothing
becomes :
ip : 192.168.0.1
defaut bridge : 192.168.0.1
This solves completly the issue for me, and now the LAN work very well, and im pleased to be able to burn my friend ...
Try this, and one thing important, dont be connected to the net while creating, because it will pertub the game.
Hope this will work for u...
foto Modlic - odlični do zadnjega piksla!
FireSTORM
Prispevkov: 2098
Kraj: Murska Sobota
Napisal/-a FireSTORM Ne nov 21, 2004 12:42 pm
Pro2Type je napisal/-a:FireSTORM--- kva a mislš da sm tok bukov da to ne vem. Mam mrežo doma postavleno z 3 račinalniki, pa še kej druzga tud pa server pa tako naprej, tak da res ne vem kaj je to LAN! :?
potem pa kar lahko pozabiš...
ker prek neta tudi z piratsko verzijo ne gre...in verjetno tudi nikoli nebo šlo, razen če trofiš original CD key...torej...muči se :P
Mc Čun
Prispevkov: 41
Pridružen: So jun 19, 2004 8:34 am
Kraj: Kidricevo
Napisal/-a Mc Čun Ne nov 21, 2004 1:53 pm
FireSTORM
Prispevkov: 2098
Kraj: Murska Sobota
Napisal/-a FireSTORM Ne nov 21, 2004 1:59 pm
Mc Čun je napisal/-a:http://www.winnews.info/modules.php?name=Downloads&d_op=viewdownloaddetails&lid=131&ttitle=Savegame
Za vse ki rabite 100% savegame. :D
ne hvala
igro sem nabavil(po črni poti) zato da bom lahko igral in ne gledal kaj je vse v igri not ko obrneš
honda man
Prispevkov: 270
Pridružen: To jan 13, 2004 12:57 pm
Napisal/-a honda man Ne nov 21, 2004 2:23 pm
FireSTORM je napisal/-a:
prek neta se da igrt sam morš imet neki patch ;)
honda man
Prispevkov: 270
Napisal/-a honda man Ne nov 21, 2004 2:28 pm
aja,še to.a se komu sanja kje bi lohka bli save files za ta špil?
TITan
Prispevkov: 3443
Napisal/-a TITan Ne nov 21, 2004 2:34 pm
C:\Documents and Settings\username\Local Settings\Application Data\NFS Underground 2
FireSTORM
Prispevkov: 2098
Kraj: Murska Sobota
Napisal/-a FireSTORM Ne nov 21, 2004 4:16 pm
evo še en brunout z civicom:
:twisted: :twisted: :twisted:
NoFX
Prispevkov: 255
Pridružen: To nov 02, 2004 2:23 pm
Napisal/-a NoFX Ne nov 21, 2004 6:35 pm
moja honda:
od spredaj
od zadaj
ozvočenje
CiCn
Prispevkov: 494
Pridružen: Sr maj 26, 2004 9:20 pm
Kraj: Zlata Sredina
Napisal/-a CiCn Ne nov 21, 2004 7:06 pm
KAm pa poj dam te sjve
blue tornado
Prispevkov: 159
Pridružen: So apr 03, 2004 6:39 pm
Napisal/-a blue tornado Ne nov 21, 2004 7:06 pm
Kdaj pa lahk das muziko noter??Prisel sem ze do drugega mesta,pa se ni nic...... :?
Pa se moja mazda mx5 v elementu... 8)
hitri in drzni
Prispevkov: 178
Pridružen: Sr avg 18, 2004 10:49 am
Kraj: ljubljana/ViČ
Napisal/-a hitri in drzni Ne nov 21, 2004 8:09 pm
mene pa zanima ce je sam ena al jih je vec unih trgovin z rumenimi luckami al je sam ena k sm na 33% pa sm najdu sam enu vseh drugih pa po vec
:ue
Vse kar je zenskega spola,rcunalnistvo in AVTOMOBILI
Airborne
Prispevkov: 453
Pridružen: Če apr 10, 2003 12:19 pm
Napisal/-a Airborne Ne nov 21, 2004 8:18 pm
Hmm mal neumn vprašanje glede na to da sem na 30%, ampak kaj je OUTRUN? :oops:
l.p.
Born to be wild !
sasiti
Prispevkov: 177
Pridružen: Ne maj 09, 2004 6:54 pm
Napisal/-a sasiti Ne nov 21, 2004 10:47 pm
Otrun je dirka z enim od nasprotnikov ki se vozijo po mestu - bodi pozorn na rumene puščice na mapi (ti si zelena). Dohiti enga, ko si mu za ritjo stisn enter- ga izzoveš na dirko, po mu pa probi čimprej spiz...
Airborne
Prispevkov: 453
Napisal/-a Airborne Ne nov 21, 2004 10:58 pm
AHA TNX, gremo jim mal riti sprašit :twisted:
Born to be wild !
acid
Prispevkov: 1910
Kraj: Vuzenica/MariboR
Napisal/-a acid Ne nov 21, 2004 11:36 pm
hitri in drzni je napisal/-a:mene pa zanima ce je sam ena al jih je vec unih trgovin z rumenimi luckami al je sam ena k sm na 33% pa sm najdu sam enu vseh drugih pa po vec
:ue
Je ja še ena trgovina z rumeno lučko nahaja pa se če gledaš zemljevid spodaj čisto skoraj desno, samo ti še tisti del mesta nimaš odprt ker si šele na 33%, si pa blizu da se ti odpre tretji del mesta. ;)
TITan
Prispevkov: 3443
Napisal/-a TITan Ne nov 21, 2004 11:39 pm
CiCn je napisal/-a:
maš notr v readmeju napisan.
TITan je napisal/-a:C:\Documents and Settings\username\Local Settings\Application Data\NFS Underground 2
-EC-
Prispevkov: 711
Pridružen: Ne mar 28, 2004 2:38 pm
Kraj: 1231
Napisal/-a -EC- Po nov 22, 2004 10:11 am
Ene par strani nazaj je zemljevid, in si lahko tam pogledas kje so se sopi.
Lp!
