zlabon
Prispevkov: 443
Napisal/-a zlabon Pe sep 16, 2005 5:29 pm
haha, to sem tud že jaz ugotovu, celo isto sliko najdu, sam modela nemorm ugotovit :D:D
YOC
Prispevkov: 887
Pridružen: Pe feb 14, 2003 10:53 am
Kraj: Spredi levo (LJ)
Napisal/-a YOC Pe sep 16, 2005 5:32 pm
Bolje 10 konjev premalo pod haubo, kot en osel preveč za volanom!!!
WWWWRRRRRRRRUUUUUUUMMMMMMMMM..........
YOC
Prispevkov: 887
Napisal/-a YOC Pe sep 16, 2005 5:35 pm
Regy, predlagam pod sticky v zabavnem.
Pa ne zato, ker je kako moja :lol:
Napisal/-a MacTron Po sep 19, 2005 7:26 am
YOC: obupal? al je zamanjkal enciklopedij :)
Nixxon
Prispevkov: 3646
Kraj: Vrhnika
Napisal/-a Nixxon Po sep 19, 2005 7:39 am
Men pa deluje ko en kombi, sam un k ga mam v mislih je ameriški. :x
Rjuhar
Prispevkov: 2634
Napisal/-a Rjuhar Po sep 19, 2005 8:33 am
Maserati Tipo 101/10 - Maserati Sebring Mk1 a.k.a. Maserati 3500GTIS, 1962(63)-69
Se par podatkov o avtu:
TECHNICAL DATA - TIPO 101/10
Body type 2+2 Coupé
Production years From 1963 to 1969
Engine Front engined 6 cylinder in-line
Bore and stroke 86 mm X 100 mm (86 x 106 mm - 88 x 110 mm)
Engine capacity 3485.3 cc (3694.4 cc - 4012.2 cc)
Compression ratio 8.5:1
Maximum power 235-bhp @ 5500 rpm (245 - 255 bhp @ 5200 rpm)
Distribution Two overhead camshafts, two valves per cylinder
Induction system Lucas indirect fuel injection
Ignition Double with Marelli distributor
Lubrification Forced with pressure pump
Transmission Rear wheel drive
Differential Salisbury 'live' axle
Clutch Dry single plate
Gearbox 5 speed and reverse
Chassis Welded tubular trellis
Front suspension:- Independent wheels, coil-springs and telescopic shock-absorbers
Rear suspension:- Rigid axle, semi-elliptical leaf-springs and telescopic shock-absorbers
Brakes Hydraulically operated disc brakes on all four wheels
Wheelbase 2500 mm
Wheel tracks Front 1390 mm Rear 1360 mm
Tyres Front:- 185 x 16 (205 x 15) Rear:- 185 x 16 (205 x 15)
Dry weight 1200 kg
Overall length 4470 mm
Overall width 1650 mm
Overall height 1300 mm
Maximum speed 235 - 245 km/h
Models constructed 591
Napisal/-a MacTron Po sep 19, 2005 11:26 am
Rjuhar: no vids da ni blo tezko :D
se letnik si taprav v oklepaje dal
:clapclap
evo... slikco za dokaz
yr next... ;)
Zadnjič spremenil MacTron, dne Po sep 19, 2005 5:02 pm, skupaj popravljeno 1 krat.
Rjuhar
Prispevkov: 2634
Napisal/-a Rjuhar Po sep 19, 2005 11:43 am
Evo nove naloge (po moje je bl simpl, kot prejsnja):
Napisal/-a MacTron Po sep 19, 2005 11:48 am
Rjuhar je napisal/-a:Evo nove naloge (po moje je bl simpl, kot prejsnja):
Fiat 600 Multipla 1958?
help :?
Rjuhar
Prispevkov: 2634
Napisal/-a Rjuhar Po sep 19, 2005 11:55 am
nope... keep trying
HajdukS
Prispevkov: 731
Pridružen: Če dec 26, 2002 1:45 pm
Napisal/-a HajdukS Po sep 19, 2005 11:55 am
bmw isseta?
Rjuhar
Prispevkov: 2634
Napisal/-a Rjuhar Po sep 19, 2005 11:58 am
Tole je blo pa hitro: cestitam
@MacTron - si pa letnik zadel...
sebaveh
Prispevkov: 2334
Kraj: Slov. Bistrica
Napisal/-a sebaveh Po sep 19, 2005 12:29 pm
Steve Urkel vozilo :P
EDD: Now what?
ED: Can I think?
EDD/EDDY: NO!
H2
Prispevkov: 1189
Napisal/-a H2 Po sep 19, 2005 1:31 pm
ugante ker del je to! :P
je pod lucjo sam to vam pomagam!
citroen xsara picaso.jpg (9.25 KiB) Videno 8511 krat
H2
Prispevkov: 1189
Napisal/-a H2 Po sep 19, 2005 1:33 pm
*od kerga avta je to del!
alanq4
Prispevkov: 1700
Napisal/-a alanq4 Po sep 19, 2005 2:10 pm
Mogoče citroen xsara picasso?
Mih@
Prispevkov: 404
Pridružen: So okt 18, 2003 3:41 pm
Kraj: Smlednik
Napisal/-a Mih@ Po sep 19, 2005 2:13 pm
alanq4 je napisal/-a:Mogoče citroen xsara picasso?
Tole je blo pa tko k tist vic. Če poveš kaj imam v košari ti dam vse breskve ki so notr! :P
http://mr.si/
H2
Prispevkov: 1189
Napisal/-a H2 Po sep 19, 2005 2:23 pm
ni citroen
to sm dau za foro!ker je bil prav naslov avta!
alanq4
Prispevkov: 1700
Napisal/-a alanq4 Po sep 19, 2005 2:24 pm
Sej se mi je zdel pa sem useen probu :P . Mogoče audi tt?
Slide
Prispevkov: 4349
Napisal/-a Slide Po sep 19, 2005 2:33 pm
h2 je napisal/-a:ni citroen
meni deluje kot luknja za luft na BMW M3 CSL :|
