Borcix
Prispevkov: 346
Pridružen: Ne maj 11, 2003 11:48 am
Kraj: Prekmurec v Ljubljani
Kaj se zgodi če izgubiš dirko ...
Napisal/-a Borcix Če maj 06, 2004 9:36 pm
Po tem filmčku res premisliš a se splača tekmovati :EE
http://generalhaberdashery.com/links/go ... inigun.wmv
Če si pa prepričan v zmago potem pa le :vrum
Asterix
Prispevkov: 1385
Napisal/-a Asterix Če maj 06, 2004 9:45 pm
These Weapons of Mass Destruction cannot be displayed
The weapons you are looking for are currently unavailable. The country might be experiencing technical difficulties, or you may need to adjust your weapons inspectors mandate.
Please try the following:
Click the Regime change button, or try again later.
If you are George Bush and typed the country's name in the address bar, make sure that it is spelled correctly. (IRAQ).
To check your weapons inspector settings, click the UN menu, and then click Weapons Inspector Options. On the Security Council tab, click Consensus. The settings should match those provided by your government or NATO.
If the Security Council has enabled it, The United States of America can examine your country and automatically discover Weapons of Mass Destruction.
If you would like to use the CIA to try and discover them,
click Detect weapons
Some countries require 128 thousand troops to liberate them. Click the Panic menu and then click About US foreign policy to determine what regime they will install.
If you are an Old European Country trying to protect your interests, make sure your options are left wide open as long as possible. Click the Tools menu, and then click on League of Nations. On the Advanced tab, scroll to the Head in the Sand section and check settings for your exports to Iraq.
Click the Bomb button if you are Donald Rumsfeld.
Cannot find weapons or CIA Error
Iraqi Explorer
Stuhec
Prispevkov: 277
Pridružen: Ne mar 21, 2004 10:42 pm
Kraj: M. Sobota
Napisal/-a Stuhec Če maj 06, 2004 10:44 pm
sam jaz ga ne morem odpret :(
2Fast&2Furious
Prispevkov: 3272
Kraj: Lj
Napisal/-a 2Fast&2Furious Če maj 06, 2004 10:48 pm
Stuhec je napisal/-a:sam jaz ga ne morem odpret :(
tut jst ne
Dejan1
Prispevkov: 239
Pridružen: So maj 01, 2004 4:01 pm
Napisal/-a Dejan1 Če maj 06, 2004 10:50 pm
Men tud ne odpre :?
Borcix
Prispevkov: 346
Napisal/-a Borcix Če maj 06, 2004 10:50 pm
Hmm, niti meni ne odpre tak da niam pojma kaj štrajka :roll:
Stuhec
Prispevkov: 277
Kraj: M. Sobota
Re: Kaj se zgodi če izgubiš dirko ...
Napisal/-a Stuhec Če maj 06, 2004 10:55 pm
Borcix je napisal/-a:Po tem filmčku res premisliš a se splača tekmovati :EE
vcasih lahk tud Prukmurci zaserjemo
Borcix
Prispevkov: 346
Napisal/-a Borcix Če maj 06, 2004 10:56 pm
Ma ja to ti je redkost :-P
Samo tam od kje sem ga skopiral pa dela :?: :?: :?: :roll:
Nix jasno :?
HeP][MeN
Prispevkov: 2341
Kraj: Trbovlje
Napisal/-a HeP][MeN Če maj 06, 2004 10:58 pm
[i]Weeeeeeee![/i]
daewoo_rugby
Prispevkov: 1292
Pridružen: To dec 16, 2003 12:54 am
Napisal/-a daewoo_rugby Če maj 06, 2004 11:23 pm
kmet
2Fast&2Furious
Prispevkov: 3272
Kraj: Lj
Napisal/-a 2Fast&2Furious Če maj 06, 2004 11:53 pm
opet američani na delu :roll:
Zok
Prispevkov: 1196
Pridružen: Če feb 20, 2003 12:34 pm
Kraj: Ponikva
Napisal/-a Zok Pe maj 07, 2004 7:32 am
...fukjenci... :roll:
Mondeo mk3 saloon 2.0 TDCi - 186 HP, 408 Nm
woolff
Prispevkov: 1276
Pridružen: Ne jan 11, 2004 5:12 pm
Kraj: Lukavci
Napisal/-a woolff Pe maj 07, 2004 8:17 am
Adijo živci. Drugače sploh ne vejo :roll: Idioti :?
Če se bojiš brzine prelepi števec!
HMX
Prispevkov: 437
Pridružen: To apr 29, 2003 7:40 pm
Kraj: Radlje Ob Dravi
Napisal/-a HMX Pe maj 07, 2004 8:32 am
Ne :shock:, ampak :evil:
Glej moj podpis, kaj si mislim o njih.
Sploh pa, kaj ima Discovery Channel pri tem?
A se jim je malo skisalo?
HeP][MeN
Prispevkov: 2341
Kraj: Trbovlje
Napisal/-a HeP][MeN Pe maj 07, 2004 8:39 am
let's do it like they do on the discovery channel :roll:
[i]Weeeeeeee![/i]
darkdog24
Prispevkov: 2211
Pridružen: Če sep 18, 2003 6:30 pm
Kraj: Velenje
Napisal/-a darkdog24 Pe maj 07, 2004 8:49 am
tt Jessie pa je eden od mojstrov v Ameriki ki proizvajajo Harley motorje ročno izdelane in je vsak unikat.pri njem jih kupujejo tisti ki majo $$$$
sam nevem kaj dela tu z autom?Mogoče ma kak show al kej takega
UPOKOJENI STYLER (8 pokalov)Slika
darkdog24
Prispevkov: 2211
Kraj: Velenje
Napisal/-a darkdog24 Pe maj 07, 2004 8:52 am
Tale tip v autu je potomec od zelo znanega kriminalca in lopova poštnih vlakov v času indijancev in kavbojcev in sicer Jessie James ki je umrl 3 aprila 1882.
Ni čudno da je tk nor!
KMX
Prispevkov: 1500
Pridružen: Po okt 27, 2003 12:05 pm
Napisal/-a KMX Pe maj 07, 2004 1:40 pm
jaoooo idiiiioooot :evil: :evil: :evil:
Styling is not a hobby, it's a lifestyle!
Andy
Prispevkov: 2122
Kraj: sLOVEnija
Napisal/-a Andy Ne maj 09, 2004 12:45 pm
:evil: :evil: :evil: :evil: :?
