RegY
Prispevkov: 6720
Kraj: MariboR
[eng.] štorije, ki jih potniki letal nikoli ne slišijo
Napisal/-a RegY So sep 25, 2004 4:07 pm
The conversations flight passengers never hear
Here are some conversations that airline passengers normally will never hear. The following are accounts of actual exchanges between airline pilots and control towers around the world.
Tower: "Delta 351, you have traffic at 10 o'clock, 6 miles!"
Delta 351: "Give us another hint! We have digital watches!"
"TWA 2341, for noise abatement turn right 45 Degrees."
"Centre, we are at 35,000 feet. How much noise can we make up here?"
"Sir, have you ever heard the noise a 747 makes when it hits a 727?"
From an unknown aircraft waiting in a very long takeoff queue: "I'm f ... ing bored!"
Ground Traffic Control: "Last aircraft transmitting, identify yourself immediately!"
Unknown aircraft: "I said I was f ... ing bored, not f ... ing stupid!"
O'Hare Approach Control to a 747: "United 329 heavy, your traffic is a Fokker, one o'clock, three miles, Eastbound."
United 329: "Approach, I've always wanted to say this . I've got the Little Fokker in sight."
A student became lost during a solo cross-country flight.
While attempting to locate the aircraft on radar, ATC asked, "What was your last known position?"
Student: "When I was number one for take-off."
A DC-10 had come in a little hot and thus had an exceedingly long roll out after touching down.
San Jose Tower Noted: "American 751, make a hard right turn at the end of the runway, if, you are able. If you are not able. take the Guadalupe exit off Highway 101, make a right at the lights and return to the airport."
There's a story about the military pilot calling for a priority landing because his single-engine jet fighter was running "a bit peaked."
Air Traffic Control told the fighter jock that he was number two behind a B~52 that had one engine shut down.
"Ah," the fighter pilot remarked, "The dreaded seven-engine approach."
Taxiing down the Tarmac, a DC-10 abruptly stopped, turned and returned to the gate. After an hour-long wait, it took off. A concerned passenger asked the flight attendant, "What exactly, was the problem?"
"The pilot was bothered by a noise he heard in the engine," explained the flight attendant. "It took us a while to find a new pilot."
A Pan Am 727 flight waiting for start clearance in Munich overheard the following:
Lufthansa (in German): "Ground, what is our start clearance time?"
Ground (in English): "If you want an answer you must speak in English."
Lufthansa (in English): "I am a German, flying a German
airplane, in Germany. Why must I speak English?"
Unknown voice from another plane (in a beautiful British accent): "Because you lost the bloody war."
Tower: "Eastern 702, cleared for take-off, contact Departure on frequency 124.7"
Eastern 702: "Tower, Eastern 702 switching to Departure. By the way, after we lifted off we saw some kind of dead animal on the far end of the runway."
Tower: "Continental 635, cleared for take-off behind Eastern 702. Contact Departure on frequency 124.7. Did you copy that report from Eastern 702?"
Continental 635: "Continental 635, cleared for take-off, roger; and yes, we copied Eastern ... we've already notified our caterers."
One day the pilot of a Cherokee 180 was told by the tower to hold short of the active runway while a DC-8 landed. The DC~8 landed, rolled out, turned around, and taxied back past the Cherokee.
Some quick-witted comedian in the DC~8 crew got on the radio and said, "What a cute little plane. Did you make it all by yourself?"
The Cherokee pilot, not about to let the insult go by, came back with a real zinger: "I made it out of DC-8 parts. Another landing like yours and I'll have enough parts for another one."
While taxiing at London's Gatwick Airport, the crew of a US Air flight departing for Ft. Lauderdale made a wrong turn and came nose to nose with a United 727. An irate female ground controller lashed out at the US Air crew, screaming:
"US Air 2771, where the hell are you going?! I told you to turn right onto Charlie taxiway! You turned right on Delta! Stop right there. I know it's difficult for you to tell the difference between C and D, but get it right!" Continuing her rage to the embarrassed crew, she was now shouting hysterically:
"God! Now you've screwed everything up! It'll take forever to sort this out! You stay right there and don't move till I tell you to! You can expect progressive taxi instructions in about half an hour and I want you to go exactly where I tell you, when I tell you, and how I tell you! You got that, US Air 2771?"
"Yes, ma'am, l' the humbled crew responded.
Naturally, the ground control communications frequency fell terribly silent after the verbal bashing of US Air 2771. Nobody wanted to chance engaging the irate ground controller in her current state of mind. Tension in every cockpit out around Gatwick was definitely running high.
Just then an unknown pilot broke the silence and keyed his microphone, asking: "Wasn't I married to you once?"
After every flight, pilots fill out a form called a gripe sheet, which
conveys to the mechanics problems encountered with the aircraft during
the flight that need repair or correction. The mechanics read and
correct the problem, and then respond in writing on the lower half of
the form what remedial action was taken, and the pilot reviews the gripe
sheets before the next flight. Never let it be said that ground crews
and engineers lack a sense of humor. Here are some actual logged
maintenance complaints and problems as submitted by Qantas pilots and
the solution recorded by maintenance engineers. By the way, Qantas is
the only major airline that has never had an accident.
(P = The problem logged by the pilot.)
(S = The solution and action taken by the engineers.)
P: Left inside main tyre almost needs replacement.
S: Almost replaced left inside main tyre.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
jaz sem se smejal, kot norc :D
Slide
Prispevkov: 4349
Napisal/-a Slide So sep 25, 2004 4:22 pm
HUDO :cry
NoName
Prispevkov: 770
Pridružen: Po jan 27, 2003 1:04 pm
Napisal/-a NoName So sep 25, 2004 4:37 pm
carsko... najbl smesni so ti P:S... za popeesdit ej :> :twisted:
I can see dumb people...They're all around us... Look, they're even on this forum!
killah bee
Smrtonosni čebelj
Prispevkov: 4321
Kraj: RS
Napisal/-a killah bee So sep 25, 2004 4:39 pm
:lol: :lol: :lol:
če je res
no sej piloti se morjo tud mal zabavat :wink:
Pugi
Prispevkov: 6195
Napisal/-a Pugi So sep 25, 2004 4:50 pm
FAaaaaak, kok sm umru. To je se moj foh, pa mi je uiber smesn... Kake fore... :D :D
Zok
Prispevkov: 1196
Pridružen: Če feb 20, 2003 12:34 pm
Kraj: Ponikva
Napisal/-a Zok So sep 25, 2004 5:10 pm
aaaaaaaaaaaaaaa, watafaaaaaaak, js vmiram od smeha!!!!!!!!!!!! :rofl :rofl :rofl :rofl
Mondeo mk3 saloon 2.0 TDCi - 186 HP, 408 Nm
_Jerry_
Prispevkov: 1196
Pridružen: Če jul 22, 2004 12:55 pm
Napisal/-a _Jerry_ So sep 25, 2004 5:25 pm
Pugi je napisal/-a: To je se moj foh, pa mi je uiber smesn... Kake fore... :D :D
Moj tudi :wink: Fakulteta za strojnistvo, smer: letalstvo, program: poklicni pilot letala...
Tista je najboljsa: Mouse in the cockpit... Cat installed! :rofl
Pugi
Prispevkov: 6195
Napisal/-a Pugi So sep 25, 2004 6:47 pm
_Jerry_ je napisal/-a:
Moje sanje, ostal pri izpitu za enomotrca... Piper Tomahawk rulez ;)
_Jerry_
Prispevkov: 1196
Napisal/-a _Jerry_ So sep 25, 2004 6:56 pm
Pugi je napisal/-a:
Hm, kaj bos rekel, ce ti povem, da me frcoplani sploh ne zanimajo (no ja, mau ze, ampak ne tolk kot avtomobili) in da sem sel na to smer pac zato, ker ni avtomobilske smeri (sramota za naso solo!)? :roll:
Evo, imava nekaj skupnega: oba delava solo, ki naju ne veseli :wink:
GorazdO
Prispevkov: 2109
Napisal/-a GorazdO So sep 25, 2004 7:15 pm
umiram od smeha.. sploh ob temle:
btw - letalci - ste sprobal IL2 Sturmovik? klik
Nixxon
Prispevkov: 3646
Kraj: Vrhnika
Napisal/-a Nixxon Po sep 27, 2004 12:00 pm
Men je bla pa tale super:
:lol: Bogi revež je mogu čakat z enim okvarjenim motorjem, ker je bil večji imrđensi bombnik, ki mu dela "samo" še sedem motorjev. :lol:
Pecho
Prispevkov: 128
Pridružen: Ne avg 03, 2003 10:30 am
Kraj: Veleje Veleje
Napisal/-a Pecho To sep 28, 2004 7:44 am
hehe. Tale me mal spominja na kolega, ko smo se učili letet.
Letališče: Blanik 22 pozicija, višina.
Pilot: Levo od bele hiše na Partizanki....
Letališče:%&#$%& (cenzura)
Lp Pecho :hi
Slide
Prispevkov: 4349
Napisal/-a Slide Pe okt 01, 2004 9:26 am
menjekul
Prispevkov: 2635
Pridružen: Sr jan 01, 2003 8:14 pm
Napisal/-a menjekul Pe okt 01, 2004 11:16 am
:cry :cry :cry eni so tok svetovni da ...res, do solz se nasmeješ :cry
HORSE
Prispevkov: 1899
Pridružen: Sr sep 25, 2002 6:24 pm
Kraj: Promised Land
Napisal/-a HORSE Pe okt 01, 2004 11:23 am
Sam, a je to taprav avion oz. real posnetek? :shock:
Slide
Prispevkov: 4349
Napisal/-a Slide Pe okt 01, 2004 1:02 pm
Tudi jaz sem se to vprašal... :shock:
Bi moral Pugi povedat, k se mal bolj na te reči spozna
sonic
Prispevkov: 2393
Napisal/-a sonic Pe okt 01, 2004 1:30 pm
To pa 100% ni pravi avion. Verjetno je RV-model.
Če bi pravi avion tako z nosom gor-dol skakal, bi se takoj prelomil (če ne, bi bili pa vsi potniki kot masa za ćevape).
Slide
Prispevkov: 4349
Napisal/-a Slide Pe okt 01, 2004 2:02 pm
Pomoje tud ja, sam oni ko mu pa rep odpade pa je pravi verjetno :shock:
