Kennman
Prispevkov: 600
Pridružen: Po jan 12, 2004 1:01 pm
Kraj: Velenje
GTR igra
Napisal/-a Kennman So mar 19, 2005 12:57 pm
"KUPIL" sem igro -GTR - Official FIA GT Racing Game-, ampak sem pol takoj CDje in racun zgubu, se dobr, da sem si oba CDja posnel na disk.... :D :D
uglavnem, mam cd key, crack, english translation (ker je original v nemscini), patch in update, vprasanje pa je:
kako hudica se da na enostaven nacin igro po instalaciji usposobit, da bo laufala????
Hvala!
Kennman
metallic
Prispevkov: 2636
Napisal/-a metallic So mar 19, 2005 12:59 pm
Ponavad jo pocrackaš pa špila... :?
metallic
Prispevkov: 2636
Napisal/-a metallic So mar 19, 2005 1:00 pm
PS, če maš piratsko kopijo špila ne smeš updateat, kolikor vem... :oops:
Redman
Prispevkov: 83
Pridružen: To apr 08, 2003 1:33 pm
Napisal/-a Redman So mar 19, 2005 1:08 pm
Zdej ne vem kakšno verzijo imas ti. Jest imam angleško in moram preden zaženem igro izklopiti cd-rome. Tole so navodila za zagon:
GTR FIA GT Racing Game
Game with cars and racing.
Running it:
* mount the full image and install
* reboot
* run starforce nightmare and press the following buttons:
1. disable CD
2. Disable node
* mount the miniimage
* run it
* use serial 6kthf-d6lbz-zdwv6-e3h88-9nfxz
* play the damned game finally
If you have manually blacklisted virtual drives in the registry previously, undo those before running starforce nightmare.
Starforce Nightmare is found at:
http://starf.bestmedia.kiev.ua/download/sfn.rar
Upam da ti bo kej pomagalo ker ma igra res eno zajebano zaščito.
Kennman
Prispevkov: 600
Kraj: Velenje
Napisal/-a Kennman So mar 19, 2005 1:11 pm
hja mal bols je ze kot pa moja navodila:
1)Installare normalmente il gioco usando le immagini dei 2 CD : GTR_CD1 e GTR_CD2 montate con Alchol o
Daemon Tools oppure masterizzate su CD
2)Usare la key : F84GX-WK9MB-VDBG3-S9VSH-Q6D3N
3) Disabilitare Dal Bios i canali IDE dove sono collegate le periferiche ottiche (CD, DVD) ecc. , oppure
staccare fisicamente i cavi IDE di collegamento dalle periferiche ottiche
4)Estrarre i 2 file GTR_CD1.mdf e GTR_CD1.mds da GTR_MiniImage.rar e montarle con Daemon Tools o Alchol
5) Per approfondimenti ulteriori su questo punto andare al 5 bis.
Lanciare Regedit.exe e posizionarsi su HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\R oot\SYSTEM\
Da qui vedrete una serie di chiavi tipo 0001 0002 0003 ecc.. apritele e cercate quelle che presentano a fianco
della dicitura DeviceDesc la descrizione : Plug and Play BIOS Extension
o PnP BIOS Extension.. Queste non sono altro che i riferimenti ai driver delle Periferiche virtuali di
daemon tools e Alcohol che dovremo “nascondere” alla protezione starforce.
Adesso che avete individuato le chiavi contenenti quelle diciture ciccate col tasto
destro sulla cartellina relativa (esempio: 0003>--------- tast dx) e selezionare autorizzazioni:
sulla finestra che apparirà selezionare SYSTEM con un click e poi sulla finestra sottostante spuntare
la casella “nega” a fianco del campo “in lettura” e applicare le modifiche.
5 bis.) Starforce3 fa ricerca di periferiche tramite setupapi.dll,dato che questo
è sicuro e facile risolvere questo problema.
per primo andate sotto Start/Pannello di Controllo/Sistema/tab Hardware/Gestione periferiche.
oltre le periferiche SCSI,installano sia Alchool 120% che Daemon Tools anche cosidetti PnP BIOS Exstension.
Con Alchool si chiamano "Plug and Play BIOS Exstension" mentre quelli per Daemon tools "PnP BIOS Extension".
A secondo di cosa usate dovreste trovarli nel gruppo "Periferiche di Sistema".
Chiudete tutto e ricordatevi che tipo avete trovato("Plug and Play BIOS Exstension" oppure "PnP BIOS Extension").
Adesso per chi non ha tanta conoscenza del PC e' meglio che lasci perdere, altrimenti potreste causare danni al Sistema.
Fate click su "Start/Esegui" e aprite Regedit.exe e nel ramo
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\SYSTEM\
qui sono tutte le periferie elencato come numero
ad esempio:
0000
0001
0002
0003
e cosi via,c'è ne possono essere molto,dipende dal tipo di PC e che configurazione avete.
si ho disattivato la lettura dalla 0002
adesso aprite una dopo l'altro le diverse periferie e cercate DeviceDesc che segnala che tipo di periferia è.
Se per esempio Alchool è installato sotto 0003 dovrebbe segnalare nella stringa Devicedesc: "Plug and Play BIOS Extension",
mentre con DT sarebbe: "PnP BIOS Extension". Avete trovato quello che volevate? Passiamo al punto piu' importante.
Se ad esempio la cartella 0003 sarebbe alchool, cliccateci su col mouse destro, ci sarà l'opzione autorizzazione,
cliccateci su e si apre una nuova finesrta sopra potete leggere gruppi o nome utente,la scegliete con un click "SYSTEM"
Sotto vedrete diverse riquadri: spuntate la virgoletta "Nega" ma solo per "LEGGERE".
E questo lo fate a tutte le periferiche che trovate con estensione "Plug and Play BIOS Exstension"
oppure "PnP BIOS Extension".
Quanto avete fatto tutto andate di nuovo sotto
Start/Pannello di Controllo/Sistema/tab Hardware/Gestione periferiche/periferiche di sistema e
controllate,se avete fatto tutto bene non dovrebberro essere
più presenti.
Adesso assicuratevi di disattivare il lettore cd e l'eventuale DVD dal BIOS
Montare l'immagine contenuta nel file .rar
finito
buona fortun
:roll: :roll: :shock: :shock: :roll: :roll: :shock: :shock: :roll: :roll: :oops:
dunker
Prispevkov: 560
Pridružen: To apr 27, 2004 12:54 pm
Napisal/-a dunker So mar 19, 2005 1:34 pm
Hehe, tale Starforce zaščita nam kar dobro življenja greni. ;)
Jst se niti ne trudim, preprosto čakam na normalen crack brez odklapljanja cedejev ali pa na znižano igro v trgovini (kakšnih 6 tisočakov bi še dal).
M3
Prispevkov: 1931
Napisal/-a M3 So mar 19, 2005 1:39 pm
jp jp daemon tools pa bo.
Kennman
Prispevkov: 600
Kraj: Velenje
Napisal/-a Kennman So mar 19, 2005 2:25 pm
Redman je napisal/-a:Zdej ne vem kakšno verzijo imas ti. Jest imam angleško in moram preden zaženem igro izklopiti cd-rome. Tole so navodila za zagon:
Running it:
* reboot
1. disable CD
2. Disable node
* run it
ZAKON !!!! DELA!!!!!
res hvala!! una it. verzija odklepanja je pa adijo pamet: nek bios in regedit mors slatat!!
Kennman
LaKi_
Prispevkov: 184
Pridružen: Sr jul 14, 2004 10:51 pm
Napisal/-a LaKi_ Po mar 21, 2005 9:46 pm
Redman, hmm probal sem po teh navodili pa vseeno nedela.
Kaj bi lahko bilo ?
Prosim za pomoč. Hvala vnaprej
Težko je danes biti norec, kajti konkurenca je velika.
MapleLeaf
Prispevkov: 478
Pridružen: Ne mar 14, 2004 10:11 pm
Kraj: Vancouver B.C.
Re: GTR igra
Napisal/-a MapleLeaf Sr mar 23, 2005 9:36 pm
Kennman je napisal/-a:"KUPIL" sem igro -GTR - Official FIA GT Racing Game-, ampak sem pol takoj CDje in racun zgubu, se dobr, da sem si oba CDja posnel na disk.... :D :D
Hvala!
Kennman
pol si pa res imel sreco ce si vse skupaj zgubo
ups, komaj zdaj sem opazil, zakaj hudica rabis crack ce pa si jo kupil? :roll: :roll:
to mi ni jasno
Metod Trobec
Prispevkov: 16
Pridružen: Če mar 03, 2005 1:58 am
Kraj: Zapori na Dobu
Re: GTR igra
Napisal/-a Metod Trobec Če mar 24, 2005 12:00 pm
renault19 je napisal/-a:pol si pa res imel sreco ce si vse skupaj zgubo
to mi ni jasno
:jao:
RegY zaudarja
Poredne tete gredo v peč!
Metodova himna
fastfury
Prispevkov: 336
Pridružen: Po sep 23, 2002 11:00 am
Re: GTR igra
Napisal/-a fastfury Pe mar 25, 2005 8:12 pm
Metod Trobec je napisal/-a:
to mi ni jasno
:jao:
:lol: btw, sej ti ne bo noben težil če boš reku da si jo snel z e-mule :EE
Metod Trobec
Prispevkov: 16
Napisal/-a Metod Trobec Če apr 07, 2005 1:38 pm
Zdaj sem dal gor popravek 1.3 in igra mi zateži, da nimam originalnega cdja. :ppppp Pred popravkom pa je vse delovalo B.P. Ima kdo rešitev? :cry:
RegY zaudarja
Metodova himna
.::GTR::.
Prispevkov: 1156
Pridružen: So mar 15, 2003 1:59 pm
Kraj: Gorenjska
Napisal/-a .::GTR::. Če apr 07, 2005 1:49 pm
Metod Trobec je napisal/-a:Zdaj sem dal gor popravek 1.3 in igra mi zateži, da nimam originalnega cdja. :ppppp Pred popravkom pa je vse delovalo B.P. Ima kdo rešitev? :cry:
system restore :)
Napisal/-a nebivedu Če apr 07, 2005 1:57 pm
FORMAT C: /C /U /X /FS:NTFS /A:512
Tole poštima takoj vse probleme. Aja zalaufat pa se more iz diskete na kateri je sistem posnet + format.com datoteka.
Metod Trobec
Prispevkov: 16
Napisal/-a Metod Trobec Če apr 07, 2005 2:42 pm
No, no, tako neuk pa spet nisem, no. ;) Ampak Metod ne bi bil Metod če ne bi bil na lastno pest odkril rešitve te zagonetke. Za uspešen zagon in delovanje GTR 1.3 naredite naslednje:
-najprej vklopite program starforce nightmare
-v tem programu pritisnite Disable CD in Disable Node, potem pa izklopite še kanal, na katerem imate na CD-rome. Ponavadi je to kanal 2, tako da pritisnite Disable ch2. Če se zmotite, vam bo izklopilo trdi disk in sledil bo reboot. :lol:
-poženite igro
8)
RegY zaudarja
Metodova himna
