Horoskop - malo drugače
Napisal/-a Tomo Pe feb 23, 2007 11:35 am
Ne vem ali je že bilo ali ne...
NAPOVED ASTROLOGA, KI JE SLABO SPAL , NA LEVO NOGO VSTAL IN NA KOPRIVE
SCAL. :)
*OVEN* :
NADUVANI TEPCI, KI MISLIJO, DA VEDO VSE. MENIJO, DA SO BLAZNO
PRILJUBLJENI, V BISTVU PA GREJO VECINI FOLKA NA JETRA. IZMISLIJO SI NEKO
NEIZVEDLJIVO STVAR IN POTEM TEZIJO TISTIM, KI JIM JE NE USPE REALIZIRATI,
SAMI PA NE MIGNEJO S PRSTOM. NAVADNO ZIVIJO PARAZITSKO IN IZKORISCAJO
ODRUGE. RINEJO IN RINEJO, SE DOKOPLJEJO DO OBLASTI POTEM PA SE GREDO
ARISTOKRATE IN SE PUSTIJO STRECI. MNENJA DRUGIH NE UPOSTEVAJO, KER ITAK
MENIJO DA SO NAJPAMETNEJSI, VENDAR VECINA LJUDI KMALU OPAZI, KAKSNI
BLEFERJI SO.*
BIK*:
VZTRAJNI, NE VDAJO SE ZLAHKA, VENDAR PREDVSEM ZATO, KER SO NESPOSOBNI IN
JIM NIC NE USPE PRVIC. IZRAZITO BUTASTI IN BREZ SMISLA ZA HUMOR. ZLAHKA
JIH ZMANIPULIRAS, NAGNJENI PA SO K TEMU, DA ZATIRAJO SIBKEJSE OD SEBE.
ZENSKE RADE DAJO. ZARADI PRIROJENE TOPOUMNOSTI JIH TEZKO RAZ****IS, KO PA
TI USPE, JE DOBRO, DA HITRO TECES. ZNANA OSEBNOST:SADAM HUSEIN RECIMO. *
DVOJCKA*:
VELIK VZAMEJO, PA NIC NE DAJO. VECINOMA JIH IMAJO VSI RADI, PREDVSEM ZATO,
KER SO BISEKSUALCI. DO BLIZNJIH SO SKRTI, RADI PA DAJEJO TUJCEM, KER SI
ZELIJO BITI PRILJUBLJENI. BEBAVO NEPOSREDNI. ZATEZENCI, NAGNJENI K
SHIZOFRENIJI. KER IMAJO TEZAVES SPOLNO PREFERENCO, NI DOBRO PUSCATI OTROKE
SAME Z NJIMI, INCEST PA JE PRI NJIH ITAK STALNA PRAKSA. DVOJCICE SE KAR NE
LOCIJO OD SVOJIH PRIJATELJIC, VES CAS TICIJO SKUPAJ, KAR JE VECINOMA PRAV
ZOPRNO, CE MAS PA SRECO, JIH VCASIH VZAMEJO TUDI S SABO V POSTELJO, KAR JE
NEDVOMNO PREDNOST,CEIMAS RAD STEVILKO 3...*
RAK*:
ZMER SE JIM DOGAJA KRIVICA, ZMER SO ZRTVE IN V TEM TUDI NEZNANSKO UZIVAJO.
NAJVECKRAT IZVAJAJO MANUALNA DELA, VELIKO STRIKAJO IN KVACKAJO, DOBRI SO
ZA TEKOCIM TRAKOM. ZE PO KOZARCU ALI DVEH SE JIM POPOLNOMA STRGA, TEZIJO
DRUGIM, Z ZURA JIH JE TREBA DEJANSKO METAT SKOZ VRATA, KER BI SE KAR
NASELILI. BOGNEDAJ, DA TE OBISCEJO, NE
SPRAVIS JIH IZ STANOVANJA.*
LEV*:
MISLIJO, DA SO ROJENI VODJE, V RESNICI PA VSI VEDO, DA SO NAVADNI
NESPOSOBNI TEPCI. VEDNO SERJEJO, TUDI CE NIMAJO ARGUMENTOV IN SO STISNJENI
V KOT. EDEN JE V HAAGU. VECINOMA NE POZNAJO OSNOV HIGIENE,VELIKO JIH IMA
HEPATITIS. KOT PRAVI LEVI RADI POSCIJEJO VSA DREVESA NAOKOLI, SO TUDI
ROJENI V TEM ZNAMENJU NAGNJENI K TEMU, DA CECKAJO PO ZIDOVIH, VREZUJEJO
IMENA V DREVESA IN SMETIJO PO FORUMIH. VEDNO ISCEJO OSTALE LEVE, SE ZBIRAJO
IN LIZEJO MED SABO, NIKOLI NE MISLIJO S SVOJO
GLAVO SO KRITIZERSKI IN NEKREATIVNI. *
DEVICA*:
ZENSKE DOLGO CASA NE DAJO, KO PA LE DAJO, PONAVADI ZASPIJO MED SEKSOM. KER
SO ZLO NATANCNE SO PONAVADI DOBRE SNAZILKE, PROSTITUTKE PA ZVODNIKI. ZOPRNI
KO PRASICE IN HKRATI IZRAZITO OMEJENI ZAGOVEDNI IN KONZERVATIVNI. VSAKA
PRIBOMBA NA NJIHOV RACUN JE ZA NJIH VOJNA NAPOVED. ZAPICIJO SE V
NASPROTNIKA, POISCEJO NJEGOVO SIBKO TOCKO IN GA
POTEM PRAV POCASI IN ZAJEDLJIVO MESARIJO. SICER SE RADI DRZIJO V OZADJU,
KER NIMAJO j**c ZA FRONTALNI NAPAD, AMPAK BOGNEDAJ, DA PRIDEJO NA OBLAST:
SO STRAHOVITI TIRANI. ZNANA OSEBNOST: IVAN GROZNI, JANEZ JANSA. *
TEHTNICA*:
KONZERVATIVNI IN OMEJENI. VSEGA SE LOTIJO POCASI IN PRETEHTANO, PREDVSEM
ZATO, KER IMAJO TEZAVE S KOGNITIVNIM RAZMISLJANJEM, VECKRAT JECLJAJO IN
IMAJO DISLEKSIJO. V TRENUTKU ZAMENJAJO MNENJE. CUSTVA JIM VSAKIC ZAMEGLIJO
RAZUM, VEDNO SKUSAJO BITI PRAVICNISKI, PREDVSEM KADAR
S TEM SKODIJO DRUGIM. VES CAS NALAGAJO BEDARIJE IN SPLOH NE OPAZIJO ZA
KAKSNE TEPCE SE KAZEJO. MOSKI PONAVADI GEJI, ZENSKE PROSTITUKE, NAJVECKRAT
UMREJO ZARADI SPOLNIH BOLEZNI. *
SKORPIJON*:
NE SMES JIM ZAUPAT. NIKOLI NE KUPI RABLJENEGA AVTA OD SKORPIJONA,NIKOLI NE
KUPI NICESAR OD SKORPIJONA, CE TI KAJ PODARI, IMA GOTOVO KAJ ZA BREGOM. SO
BREZ VSAKE ETIKE, ZATO VELIKO DOSEZEJO. VECINOMA SO NEPLODNI. MOSKI IMAJO
SPOLNE ORGANE PRECEJ RAZVITE, SO PA VECINOMA IMPOTENTNI. ZENSKE POTREBUJEJO
IZRAZITO DEBELE, DOLGE, ZAJETNE BATINE,
KO JIH ENKRAT RAZPALIS, SE TEZKO UNESEJO. UPORABLJAJO EROTICNA POMAGALA,
PREDVSEM ENORMNE VIBRATORJE IN DILDOTE. ANALNO? NI PROBLEMA. ZNANA
OSEBNOST: BILL GATES.*
STRELEC* :
VECINOMA PIJANCI IN NARKOMANI. VECKRAT SE ZACNEJO KROHOTATI NA NEPRIMERNIH
MESTIH(POGREBI, MASE, PREDAVANJA), KER KONCNO ZASTEKAJO VIC, KI SO GA
SLISALI PRED TEDNOM. DAJEJO NEPRIMERNE PRIPOMBE NA NEPRIMERNIH MESTIH, SO
BREZ VSAKEGA TAKTA. CE SI DO NJIH PRASEC, TE VZLJUBIJO, CE PA JIM NAREDIS
USLUGO, TE ZANICUJEJO. SEKSUALNO JE STRELKE TEZKO ZADOVOLJITI, CE NI
PREKRATEK JE PREDOLG, CE NI PREMEHEK JE PRETRD, DOVOLJ DOBREGA PA ITAK NE
NAJDEJO. ZNANA OSEBNOST: NIXON RECIMO.*
KOZOROG*:
NIC NE TVEGAJO, SO PRAVE USRANE RITI. VECINOMA SE IMAJO ZA MUCENIKE IN
ODRESENIKE. GRADIJO SI CUDASKE MISELNE SVETOVE, MENIJO, DA SO EZOTERICNI
IN DA IMAJO NEKAKSNE CUDEZNE MOCI. KOZOROG SI VZAME URO ALI DVE CASA IN TI
JE PRIPRAVLJEN POVEDATI CELOTNO VSEBINO KNJIGE ALI FILMA, KI JO/GA JE
KONZUMIRAL ONI DAN IN HKRATI MENI, DA ZRAVEN NEIZMERNO UZIVAS. UZIVA KADAR
PRIDIGA, MENI, DA JE NAJPAMETNEJSI,
NASPROTNE ARGUMENTE PA GLADKO IGNORIRA. NAGNJENI SO K AUTODESTRUKCIJI IN
SAMOMORU, KAR JE TUDI NJIHOVA EDINA ODLIKA.*
VODNARJI *:
VEDNO PONAVLJAJO ISTE NAPAKE, TAKO V SLUZBI KOT V LJUBEZNI IN TO PREDVSEM
ZATO, KER SO BUTASTI. IMAJO SE ZA SAMARITANCE V RESNICI PA SI LE CAJTAJO
TOTALNO MENTALNO ZBLOJENOST, NA STAROST SE JIM PA ITAK UTRGA IN KONCAJO V
USTANOVAH ZAPRTEGA TIPA. VECINOMA LAZEJO. MENIJO, DA SO BLAZNO DUHOVITI, V
RESNICI PA SO DOLGOCASNI, SAJ HITRO POSTANEJO
PREDVIDLJIVI IN SE VECINI LJUDI ZACNEJO GRAVZATI, VODNARKE RADE DAJO TUDI
IZ USMILJENJA IN Z VESELJEM POGOLTNEJO. POSKUSIJO VSE.NEKROFILIJA,
SODOMIJA, BOLJ KO JE BIZARNO, BOLJ SO ZA STVAR. POPOLNOMA NESPOSOBNI SO
OCENITI CLOVEKOV ZNACAJ. DOSTIKRAT JIH UMORIJO.*
RIBI*:
VEDNO JIH SPREMLJA PARANOJA, POVSOD VIDIJO ZAROTO. BREZ SAMOZAVESTI,VES
CAS SE DAJEJO V NIC. NEPOMEMBNEZI. ZENSKE NERADE DAJO, KO PA JO ENKRAT
IMAS, LAHKO POCNES Z NJO VSE, KAR TI PADE NA MISEL. MOSKI SEN PONAVADI
ZAPIJEJO IN KONEC ZIVLJENJA PREZIVIJO NASLONJENI NA KAKSENSANK IN TEZIJO
DRUGIM S SVOJO ZIVLJENJSKO ZGODBO.
Upam, da ne bo kdo preveč resno vzel zadeve :P
leoCar
Prispevkov: 1569
Kraj: prekmurje
Napisal/-a leoCar Pe feb 23, 2007 11:40 am
Zanimiv horoskop :har :EE :rofl :bonk :mrgreen:
BMW E46
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Pe feb 23, 2007 11:47 am
Fak sem se narežal :lol:
In_Liner
Prispevkov: 484
Kraj: Sezana
Napisal/-a In_Liner Pe feb 23, 2007 12:41 pm
ja falus jaz sem bik pa sam kritizirajo :x :x :x
sploh ni tko
:cry: :cry:
*KAYA*
Prispevkov: 140
Pridružen: Pe jun 09, 2006 6:02 pm
Kraj: Ivančna Gorica
Napisal/-a *KAYA* Pe feb 23, 2007 4:57 pm
..uf ker dobr horoskop :lol: :lol: :lol:
Rada vas ima Kaychi :)=(:
Slika Slika Slika
Nejko87
Prispevkov: 1848
Kraj: Loka
Napisal/-a Nejko87 So feb 24, 2007 12:55 am
sam, če ne bereš dobesedno so pa mal zadel :shock:
vsaj tok kot tisti v časopisu :P
Pollo
Prispevkov: 2190
Napisal/-a Pollo So feb 24, 2007 4:20 am
Ja to je dost podoben napovedan, tko k je pisal enkrat v enem januarskem horoskopu:Letos boste dopolnili še eno leto :?
RED_line
Prispevkov: 670
Kraj: Markovec City
Napisal/-a RED_line So feb 24, 2007 1:45 pm
jz res mislim da je tip prav skinil :D grdo slišat samo je res :lol:
gassssssssssssssssss
ruco555
Prispevkov: 194
Pridružen: Pe mar 17, 2006 2:16 pm
Kraj: ankaran
Napisal/-a ruco555 So feb 24, 2007 2:19 pm
lej lej ki me je zadel...
točno tašen sem ko piše...
hahaha...
Never settle for a moment of mediocracy.
RED_line
Prispevkov: 670
Kraj: Markovec City
Napisal/-a RED_line So feb 24, 2007 2:22 pm
ajde, ne glih vsega samo ...
Napisal/-a Tomo Ne feb 25, 2007 12:02 pm
"NA STAROST SE JIM PA ITAK UTRGA IN KONCAJO V
USTANOVAH ZAPRTEGA TIPA"
Jaz raje ne vzamem preveč resno k bi se lahka poknu kar zdajle :)
