H2
Prispevkov: 1189
Pomoč pri installaciji san andreasa
Napisal/-a H2 Pe avg 10, 2007 3:26 pm
Danes sem po dolgem času našel CD in probam instalirat...
Ampak nikakor nemorem moutat al kako se ze rece... :S
Probal sem z deamon tools in alcohol 120%
To je use kar mam na CDju..
http://audi.moj-album.com/slike/1896209 ... Xh3zji.jpg
Tu v prvi mapi na CDju so te 3 fajli in če odpreš prvega je notri ta GTASA.exe
http://audi.moj-album.com/slike/1896209 ... ZrntKG.jpg
In v drugi mapi na CDju so pa zip fajli..
http://audi.moj-album.com/slike/1896209 ... P0H2R4.jpg
Ali ve kdo kako installirat tole...
Hvala!
Napisal/-a adis Pe avg 10, 2007 3:34 pm
odrari fajle v tem linku http://audi.moj-album.com/slike/1896209 ... P0H2R4.jpg
nato pa uporab deamn tools za mount image kaj je tist ta drug link pa pojma nimam probi to v glavnem
ps: če to ne dela potem "najd drug cd" ahahah joke
H2
Prispevkov: 1189
Napisal/-a H2 Pe avg 10, 2007 4:38 pm
Če hočem extrektat mi da opozorilo..
WinRAR: diagnostic messages
Napisal/-a MacTron Pe avg 10, 2007 4:54 pm
H2 je napisal/-a:Če hočem extrektat mi da opozorilo..
to opozorilo kar si ti napisal je samo okno... kaj pise v oknu!
ce ti kaj podobnega kot npr tole c:\test.r045 - Unexspected end
potem je ta datoteka falirana...
Napisal/-a adis Pe avg 10, 2007 4:57 pm
Citiram:
To unpack volumes you need to put them all in the same folder and start extraction from the .part1.rar volume (old extension based naming scheme .rar).
If you have done this but still receive the error when extracting from
one volume, it can be due to one of the two following reasons:
* one of the volumes is damaged. In this case WinRAR should point this out in the "Diagnostic messages" window.
* some of the volumes are absent. Check to make sure you have all volumes. Also it is possible that the volume sequence includes even more volumes, but you do not have them.
H2
Prispevkov: 1189
Napisal/-a H2 Pe avg 10, 2007 5:56 pm
extrektal sem v pač novo mapo na namizje.. sedaj je iz useh tistih fajlov nastal en fajl ki je velik 4.118.112KB ter eden, ki je velik 36 KB..
No sedaj sem mountal fajl.. in sem pri instalaciji igre.. kaj nato sledi?
Napisal/-a MacTron Pe avg 10, 2007 5:59 pm
sedaj pa mountaj image ...ta 4,1Gb v daemon toolsih nato pa pojdi v explorer
pogledat kje se ti je odprl se en virtualn cd/dvd potem pa normal install
razen ce ti ga ne autoinstall-a
H2
Prispevkov: 1189
Napisal/-a H2 Pe avg 10, 2007 6:00 pm
tam ko se je dalo mountat fajl je bil samo eden... in to ta manjši.. nato sem dal pač ta fajl mountat in prišlo je v gta san andreas meni in sedaj instaliram spil...
H2
Prispevkov: 1189
Napisal/-a H2 Pe avg 10, 2007 6:06 pm
Hvala vama!
Mi dela igra :)
Lahko se locka!
