belkaena
Prispevkov: 586
Pridružen: So nov 11, 2006 7:49 pm
Teža pnevmatike / platišča na formuli
Napisal/-a belkaena Ne avg 01, 2010 1:49 pm
Torej vprašanje je preprosto, problem je le ker pri prijatelju Googlu nisem našel odgovora nanj.
Koliko tehta platišče in koliko pnevmatiko oz. koliko tehta kolo pri formuli 1?
Lp.
^^[LuKa]^^
Prispevkov: 168
Pridružen: Ne nov 22, 2009 12:32 am
Napisal/-a ^^[LuKa]^^ Ne avg 01, 2010 2:27 pm
Race tires are quite thin and light. A typical dry tire for a larger formula car weighs less than 20lbs. FFord fronts as little as 10lbs.
I don't know if you'll be able to find the exact weight because F1 is so secretive, but it wouldn't be surprising if tire and wheel weighs 25-30 lbs.
The explaination for why the tire jocks can move so quickly and handle the tire/wheel so easily is because they are really trained gorillas!
20 lbs je pa mislim da okrog 9 kg
lep pozdrav Luka
Vrni se na Avto-Moto šport
