MapleLeaf
Prispevkov: 478
Pridružen: Ne mar 14, 2004 10:11 pm
Kraj: Vancouver B.C.
Ghost Rider
Napisal/-a MapleLeaf Ne maj 15, 2005 8:58 am
Kaj je kdo ze gledal omenjen film, ko ga ded z Suzuki Hayabuso pegla po cestah evrope, s tem ima predelanega na 499 konjev in ga pri 290 km/h ma zadnjo dvigne!
Ce se kdo ni gledal so zunaj 3 deli prihaja pa se cetrti. To morte videt
tu pa se malo opisa motorja:
SUZUKI HAYABUSA TURBO SPECIAL
ENGINE:
1298cc
McXpress racing turbo kit with everything + much more & bigger
Port & Gas Flow Cylinder Head
JE low compression pistons
Steel rods
Johnson race crankshaft
Kent cams, high performance camshafts
Laminova watercooled oilcooler
NBN hudraulic steel clutch line
TTS gearbox with 15% higher speed on 6 gear
Front sprocket, 17-19
Rear sprocket, 32-38
BODY:
Fuel tank, GSX-R1000 K2
Race seat, GSX-R1000 K2
Rear light, GSX-R1000 K4
Front light, Derbi senda
Carbon front Mudguard, vented
Carbon heelplates
CHASSI:
Special made frame by Andersson turbo system
hlins special made front forks
hlins rear damper
hlins steering damper
ISR dual 6-piston radial-mount calipers in front
ISR 6-piston caliper in rear
ISR dual full floating 320mm discs in front
ISR 240mm disc in rear
ISR radial master cylinder and lever
ISR clutch lever
Race brake pads in front and rear
NBM hydraulic steel brake lines in front and rear
Harris adjustable yokes triple bolt bottom fixing
Harris footrest kit with adjustable footpeg position
Renthal handlebar
PVM forged magnesium 10-spoke wheel in Y-spoke design, front and back
PERFORMANCE:
Power, 499bhp on the back wheel
Topspeed, enough even on one wheel
Performance, 0-300km/h 9.1 second
tu pa se zloglasni stroj:
Zadnjič spremenil MapleLeaf, dne Ne maj 15, 2005 8:49 pm, skupaj popravljeno 1 krat.
stealth
Prispevkov: 405
Pridružen: Če feb 10, 2005 8:02 pm
Napisal/-a stealth Ne maj 15, 2005 9:14 am
poznam poznam :) nekaj se je pred pol leta govorilo da se je tip baje sesipu in da ni več med živimi. No saj po filmih sodeč je bilo to itak samo vprašanje časa.
Dodge Stealth Twinturbo AWD
MapleLeaf
Prispevkov: 478
Napisal/-a MapleLeaf Ne maj 15, 2005 9:16 am
eni pravijo da je hin, spet drugi pravijo da so ga skifi dobli, tak da ne vem
krt206
Prispevkov: 889
Kraj: Kjer sem
Napisal/-a krt206 Ne maj 15, 2005 9:18 am
Jest sm tut slišu da se je že ubil, sam res, kukr je stealth reku, dobr, da je bil sploh tok časa živ
zlabon
Prispevkov: 443
Napisal/-a zlabon Ne maj 15, 2005 9:30 am
Jaz sem pa nekje bral na netu da so ga najprej škifi pofukal, pol se je pa model ful umeru, ker je dubu familijo in nehal snemat filme (in tud nehu tko hudo vozt) sam nevem pa kok je to kj res :roll:
vesolc
Prispevkov: 1668
Pridružen: To maj 11, 2004 7:15 pm
Napisal/-a vesolc Ne maj 15, 2005 9:38 am
jest sem slisal samo to zgodbo, da je padu na motorju pri visoki hitrosti in da je zletu v zid!!! lahko pa da je to samo uradna izjava, neuradno je pa nehou snemat!! res pa ga nikol niso dobil...
Napisal/-a MacTron Ne maj 15, 2005 9:39 am
MapleLeaf je napisal/-a:eni pravijo da je hin, spet drugi pravijo da so ga skifi dobli, tak da ne vem
jah ce niste preprican je tuki mail za vprasat :)
Mail Team GR:
ghost@ghostridermovie.net
sicer sem pa neki najdu
2004.06.28, Monday
Finally from somewhere in Russia our web god has found his way back!!!
He is in a good condition but cant tell us anything what happend this weekend,
due to the Russian police have forced him to take a huge amount of truth serum
to reveal the identity of Ghost Rider without any success...
And the best part is that we now can give you all I final date
when we will be done with our website- FRIDAY JULY 2...
stealth
Prispevkov: 405
Napisal/-a stealth Ne maj 15, 2005 9:43 am
če koga zanima je na tej strani nekaj kul filmčkov na to temo
http://www.linienmc.dk/video_galleri.htm
nitro1
Prispevkov: 875
Napisal/-a nitro1 Ne maj 15, 2005 1:16 pm
Tole reč sm gledou že kr en lep cajt nazaj,pa sam to lahk rečem da je totaln idot :evil: :/:o:/
Res ne vem zakaj taki modeli kot je ta se ne dokazujejo na kakih zaprtih moto-race-ih,namest da ogroža po civilni cesti še druge...če se je pa ubil pa sama sreča,ker tak res nima kej iskat na temu svetu.......Terorist :evil: :evil: :evil:
FireSTORM
Prispevkov: 2098
Kraj: Murska Sobota
Napisal/-a FireSTORM Ne maj 15, 2005 2:25 pm
lol
tip obvlada, niti enkrat ni nobenega drugega poškodoval
in sedaj ti praviš da jih tako ogroža :roll:
če obvlada motorbike ne ogroža nikoga...ampak res obvlada
wavemaker
Prispevkov: 547
Pridružen: Pe jan 30, 2004 5:10 pm
Napisal/-a wavemaker Ne maj 15, 2005 3:17 pm
URBY je napisal/-a:
stealth je napisal/-a:če koga zanima je na tej strani nekaj kul filmčkov na to temo
Jaz bi tako rad te video gledal, pa mi gre tako na K, ker mi vedno v Quicktime odpre pa nemorem dati na disk, če ga pa zbrišem mi pa nekaj teži.
A ima kdo kakšen predlog?
Desni klik in save target as, pa ga daš na disk.
Goku_6
Prispevkov: 18
Pridružen: To jul 13, 2004 1:12 pm
Kraj: Zemlja
Napisal/-a Goku_6 Ne maj 15, 2005 3:18 pm
Ta model je pa ziva legenda. sj vem da se nekateri s tem ne strinjate sm on je car. kva pa on dela s tem motorjem.... pa mn kt 200km/h pa tud ne zna pelat. sm a je kdo tko ze vidu njegov obrz? :oops: k u filmih nikol ne da celade dol! sm pa tud js ze slisu da je sou po gobe kaj je pa res pa ne vem
wuky
Prispevkov: 491
Pridružen: So jul 10, 2004 12:44 pm
Napisal/-a wuky Ne maj 15, 2005 3:18 pm
URBY je napisal/-a:
na mozili das samo desn klik Save link As...
tko sm js naredu in ga dobis na disk... a ni tko popravte me ce se motm.
lp wuky
Goku_6
Prispevkov: 18
Kraj: Zemlja
Napisal/-a Goku_6 Ne maj 15, 2005 3:26 pm
pomoje je tud za filme k sm jih js tko ze ene par zvleku.
MapleLeaf
Prispevkov: 478
Napisal/-a MapleLeaf Ne maj 15, 2005 4:37 pm
Goku_6 je napisal/-a:Ta model je pa ziva legenda. sj vem da se nekateri s tem ne strinjate sm on je car. kva pa on dela s tem motorjem.... pa mn kt 200km/h pa tud ne zna pelat. sm a je kdo tko ze vidu njegov obrz? :oops: k u filmih nikol ne da celade dol! sm pa tud js ze slisu da je sou po gobe kaj je pa res pa ne vem
saj manj kot 200 mu niti ne gre :D
perko84
Prispevkov: 1160
Kraj: malo tu, malo tam
Napisal/-a perko84 Ne maj 15, 2005 4:45 pm
jest tem podatkom ne verjamem glih.
od 0-300 v 9 sekundah, ok možn je, sam a bi šou kdo tko pospeševat. brez pretiravanja pomojem da te dobesedno odtrga iz sedeža. to je možn sam u filmih 8)
