sashs1 je napisal/-a:gti
It reaches an electronically-governed top speed of 250 km/h (155.3 mph). Going from 0 to 100 km/h (62 mph) will take 6.5 s,
mislim da piss on GTI lahk res ostane:))))))![]()
944 S2
In 1989 944S2 was introduced, and powered by a 211 PS (155 kW; 208 hp) 3.0 L engine, bore 104 mm (4.1 in), stroke 88 mm (3.5 in), the largest production 4 cylinder engine of its time. The 944S2 had the same rounded nose and a rear valance found on the Turbo model. This was the first example of the use of an integrated front bumper, where the fender & hood profiles would merge smoothly with the bumper...a design feature that has only now seen widespread adoption on nearly all cars. The S2 was also available as a cabriolet, a first for the 944 line. Performance was quoted as 0-60 mph in 6.6 seconds (0–100 km/h 6.8 s), with a top speed of 240 km/h (150 mph) (manual transmission). The 944S2 also received a revised transmission and gearing to better suit the 3.0 liter powerplant.
sashs1 je napisal/-a:motor je obnavljal golja... nekateri ga poznate po k2 attackih, on dela rdečega venturija, on dela cicerotovega leona on dela belega golfa 3 vratnega ki bi naj imel 700 konjev...
CockroaC je napisal/-a:sashs1 je napisal/-a:motor je obnavljal golja... nekateri ga poznate po k2 attackih, on dela rdečega venturija, on dela cicerotovega leona on dela belega golfa 3 vratnega ki bi naj imel 700 konjev...
Sicer se zavedam do so to vse res jezni projkti .. samo vsi od teh avtov kar jih poznam so al bli salbajzersko sestavljeni, al so jebali al pa oboje.
xalfist je napisal/-a:Ker golja a iz Selnice?
~toMmy~ je napisal/-a:sashs1 je napisal/-a:gti
944 S2
A sem spregledal kakšen podatek o predelavi motorja al je ta Porsche že kot nov bil slabši od prejšnje in aktualne generacije GTI-ja? S tem da, če motor ni temeljito obnovljen, lahko samo sanjaš o začetni konjenici. Saj me ne zanima, če ga pihneš ali ne, me pa zanima od kod jemlješ tako samozavest.
ko bodo vaši golfi po 22 tih letih še vedno šli tak kot ta avto pol se javite...
to da ti 22 let star avto pride blizu novemu avtu z približno isto konjenico je pohvale vredno...
