eFxx je napisal/-a:NITI EDEN zvar na teh slikah ni narejen z robotom. Vsi ročno delo.
Everything is finished by hand. I just spend alot of time on this particular area to make sure that the radius is correct and consistant, because the air speed at this point is very high.
Thanks,
John
Manifolds start at $2500, then you have the add-on's.
Every manifolds I build is custom to the application, so give me a call and we can discuss it further.
Thanks,
John Marcella
Marcella Manifolds
ph.248-259-6696
eFxx je napisal/-a:Everything is finished by hand. I just spend alot of time on this particular area to make sure that the radius is correct and consistant, because the air speed at this point is very high.
Thanks,
JohnManifolds start at $2500, then you have the add-on's.
Thanks,
John Marcella
Marcella Manifolds
ph.248-259-6696
http://www.yellowbullet.com/forum/showthread.php?t=97936&page=5
Tolk o sanjanju, fantje. Tip je pač mojster svoje branže.
borisk je napisal/-a:eFxx je napisal/-a:Everything is finished by hand. I just spend alot of time on this particular area to make sure that the radius is correct and consistant, because the air speed at this point is very high.
Thanks,
Thanks,
John Marcella
Marcella Manifolds
ph.248-259-6696
tip je vsekakor majster, vendar še vedno ima zunanje zvare kot bi jih narisal, znotraj pa so čisto povprečni, čeprav pomembnejši zrak potuje znotraj kolektorja, ne pa zunaj. Je pa tip zlatar, in vsaka mu čast da prodaja kolektorje po 2500$ naprej...
