čare je napisal/-a:Navodila majo najbrž ene 200 strani pa to ne piše notri?
1. Pull up on the front edge (I believe there are two clips/snaps, one for each side)
2. Push directly back on the seat bottom (inline with the seat bottom itself) with it as low as possible (without the front clipped in)
3. Tilt the seat bottom back (aka lift the front edge) and pull foward.
Steps two and three are done to undo a hook system on each side of the seat. You push to relieve the tension and swing it up to get it out of hook. It's difficult to describe but once you see it, it will make perfect sense.
Warning...Getting the seat back on is much more of a pain in the ass because of the seat belt latches not feeding through the holes easy and the plastic things around the babyseat anchor points (or whatever they are called). Personally I took all those plastic things off and leave them off.
