http://www.cruisers-nation.com http://www.cruisers-austria.comThe term engine coolant is widely used in the automotive industry, which covers its primary function of convective heat transfer. When used in an automotive context, corrosion inhibitors are also added to help protect vehicles' cooling systems, which often contain a range of electrochemically incompatible metals (aluminum, cast iron, copper, lead solder, etc.).
cruiser1 je napisal/-a:Antifriz sčiti sistem tudi proti rjavenju in vodnemu kamnu. Torej mora biti notri tudi v avtomobilih na Hawajih!
pocesnkII je napisal/-a:to da lahko zamenjas z akterim koli antifrizom NI RES. ce ne ustreza tvojemu avtu ti lahko zaradi preagresivnosti sredstva razžre alu. dele motorja, zato ima vsak avto svojo barvo.
npr nemci imajo rdecega, peugoji ce se nemotim zelenega ,....
Energetik81 je napisal/-a:A misliš da bi katerikoli proizvajalec naredil KOROZIVEN avtifriz??
