Napisal/-a nebivedu Sr jun 11, 2008 7:15 am
esem je napisal/-a:
nebivedu je napisal/-a: .... ker za plavo optimo, ki se sama fila, še šparam(stane okol 4000 evrov) ....
Lahko to malo pojasniš?
Lahko - to je samo fraza za te baterije, zato ker jih imaš lahko v kateremkoli položaju (ni več nujno, da so konektorji na vrhu) in se full hitro nafilajo, pa delajo v skoraj vseh pogojih, s tem da če jo imaš v avtu lahko stoji tudi leto ali več pa se ne sprazni.
Starter & Semi-Traction (BlueTop)
OPTIMA BlueTop Battery
SOME DAYS, ENDURANCE IS MORE IMPORTANT THAN LUCK
The OPTIMA BlueTop battery will keep you on the water longer. Its patented SPIRALCELL Technology means more running time, faster recharge, and up to twice the life of traditional marine batteries.
Vibration Resistant
The OPTIMA is over 15 times more resistant to vibration than other batteries. The constant vibration and jarring from waves can be deadly for traditional marine batteries. The tightly wound construction in OPTIMA batteries minimises plate movement and subsequent damage caused by harsh conditions - extending battery life.
Completely spill-proof/Maintenance Free
The OPTIMA is spill-proof and maintenance free and due to its completely sealed case, OPTIMA batteries are extremely safe. Acid can't leak or spill, making them clean, user-friendly and environmentally sound. In addition, the maintenance free sealed case design eliminates the need to add water or clean terminals. OPTIMA Blue Top batteries are spill proof, so they can be mounted anywhere inside a boat and in almost any position.
Retains Charge Longer / Recharges Faster
In the off-season, sometimes marine batteries sit for months at a time and lose their charge. But the OPTIMA BlueTop battery has such a low rate of self-discharge, that it can go unused for up to one year without recharging, if kept at or below room temperature. And because of its low internal resistance, it recharges faster, getting you back on the water quickly
Za rumeno lahko potrdim da to kar je napisano velja, ker jih imajo nekateri offroaderji vgrajene v svoje avtomobile, pa resnično ni nobenih problemov z njimi.
OPTIMA YellowTop is made to install and forget. No matter the conditions, be it dampness, heat, dirt or exposure to extremes in vibration or regular discharge, it is guaranteed to deliver uninterrupted power throughout the entire discharge cycle. Its capacity to maintain high voltage during the discharge cycle means that you can take advantage of a larger part of the stored power in the OPTIMA compared to ordinary batteries. This is all thanks to OPTIMA's SpiralCell Technology , which combines the advantages of a starter battery with those of a deep cycle battery. The YellowTop will provide many more charge and discharge cycles when compared to the traditional lead acid batteries often used. It is also ideal for seasonal use because of its very low self-discharge rate.
The OPTIMA RedTop
The looks alone generate plenty of interest. But it's the patented SPIRALCELL Technology in OPTIMA RedTop batteries that's truly worthy of praise. OPTIMA RedTop batteries are built to withstand the abuse Trucks, Racers and 4x4's experience on and off-road. SPIRALCELL Technology immobilises the internal components of the battery, enabling OPTIMA batteries to withstand incredible amounts of vibration.
Vehicles modified for improved engine performance demand more from a battery. OPTIMA batteries withstand the high engine bay temperatures associated with these Performance vehicles. The sealed construction makes the battery spill-proof, even if you install it on its side! This prevents external gassing and leaking which can damage engine components and reduce battery performance.
If your battery is used in applications that demand extra reliability endurance and performance, or if you just take pride in getting the best performance out of your vehicle, OPTIMA RedTop batteries deliver the performance you demand.
Cene so pa take
RED optima 215 evrov 55Ah, 815CCA
YELLOW optima 252 evrov 55AH, 870CCA
BLUE optima 320 evrov 55Ah, 250dni - 50% še vedno polna
Podatki za rumeno optimo
Voltage (V) 12
Cold Cranking Amps @ -18°C (A) 765
Cranking Amps @ 0°C (A) 870
Reserve Capacity (Minutes) 120
Capacity (C/20 Rate) (Ah) 55
Internal Resistance (ohms) 0.0028
PHYSICAL SPECS
Length (mm) 254
Width (mm) 175
Height (mm) 200
Mimimum Weight (kg) 19,5
dskrab
Prispevkov: 421
Pridružen: Sr maj 04, 2005 10:05 am
Napisal/-a dskrab Sr jun 11, 2008 7:55 am
Jaz ti predlagam TOPLO ali pa BOSCH za pošten denar. FIAMM je tudi zelo dober samo malo dražji.
LP,
Dejko
Sej nimaš kej! Tko je pa nč drugač!
It`s not just JDM. It`s a LIFESTYLE !
Mr_Jingles
Prispevkov: 401
Pridružen: Če avg 24, 2006 2:39 am
Kraj: Črna na Koroškem
Napisal/-a Mr_Jingles Sr jun 11, 2008 9:13 am
Js bi ti priporočal TOPLA TOP, ima 30% večjo startno moč od navadne tople (rdeče), pa če se ne motim sm dav za 72 Ah tam nekje 90€...Ima pa 3 lete garancije...
Napisal/-a Slicker Sr jun 11, 2008 9:20 am
nebivedu: tle vidm najvišjo ceno 320€, ne 4000. drgač pa tole so gelni akumulatorji če se ne motm. se pravi jih lahko obrneš kokr hočš pa ne bo nič ven iz njih steklo. pa še precej daljšo življenjsko dobo majo.
A sem napisal 4000, se oproščam 400 sem mislil. Upam ,da ni kdo mislil, da bi bil akumulator 4000 evrov - to je skor 3x vrednost mojega avta (brez opreme in rollbara).
hribko
Prispevkov: 1933
Kraj: koroška
Napisal/-a hribko Sr jun 11, 2008 10:31 am
tudi pri nas izdelujemo takšne akumolatorje(topla-tab),ki ga lahko obračaš kakor češ,pa nebo kaj ven steklo,lahko ga tudi razbiješ pa nebo kaj steklo ven :)
reče se jim AGM,so pa dokaj dragi,če se ne motim je 66Ah okoli 200 + evrov,so pa zelo kvalitetni
PS:ne delam reklame za naše podjetje
im nobody
Prispevkov: 3321
Kraj: laško
Napisal/-a im nobody Sr jun 11, 2008 10:37 am
S|icKeR je napisal/-a:nebivedu: tle vidm najvišjo ceno 320€, ne 4000. drgač pa tole so gelni akumulatorji če se ne motm. se pravi jih lahko obrneš kokr hočš pa ne bo nič ven iz njih steklo. pa še precej daljšo življenjsko dobo majo.
želatinasti ;)
passat 1.9 tdi 110,235 nm
Na levi pas...do konca gas
hribko
Prispevkov: 1933
Kraj: koroška
Napisal/-a hribko Sr jun 11, 2008 10:38 am
no zgledajo pa takole
http://img.bolha.com/images/image/_45fa69dfc9619.jpg
na pogled so skoraj isti,vendar je notranjost popolnoma drugačna,pa tudi sama škatla je čist drugega materiala-bolj trpežna!
vem da so se naši šefi dogovarjali z mercedezom da bi ta baterija bila prvovgradnja pri mercedezih
damtwb
Prispevkov: 3
Pridružen: Sr okt 12, 2011 6:31 pm
Akumulator
Napisal/-a damtwb Ne okt 16, 2011 12:20 pm
Pozdravljeni, zadnji teden sem bil na "Vesni" v Mariboru- Melje. Sem nujno rabil novi akumulator za 1.4 avto in fantje so mi pomagali v trenutku, tako da priporočam obisk servisa, v kolikor rabite hitro pomoč za dobro ceno. Poleg tega še imajo res hitro menjavo pnevmatik.
Škoda, da že prej nisem vedel za to! :DDD :( posting.php?mode=reply&f=6&t=62980#
zlica22
Prispevkov: 1676
Kraj: Šk. L.
Re: Akumulator
Napisal/-a zlica22 Ne okt 16, 2011 2:21 pm
damtwb je napisal/-a:Pozdravljeni, zadnji teden sem bil na "Vesni" v Mariboru- Melje. Sem nujno rabil novi akumulator za 1.4 avto in fantje so mi pomagali v trenutku, tako da priporočam obisk servisa, v kolikor rabite hitro pomoč za dobro ceno. Poleg tega še imajo res hitro menjavo pnevmatik.
slaba reklama.
