Selenia WR Pure Energy is a newly conceived fully synthetic lubricant capable to meet the needs of the most modern diesel engines. The fulfilment of the ACEA C2 specification certifies the low ash content, which is an indispensable characteristic to protect the particulate filter from residual combustion products that could cause dangerous clogging of the filter itself.
Selenia WR Pure Energy 5W-30 is the first product with High Fuel Economy System, a special formulation that allows considerable fuel saving compared with products of the same viscosimetric rating. This important target has been made possible thanks to the adoption of particular and innovative components in the formulation. It has also been possible to increase protection on the mostly stressed parts of the engine; in particular Selenia WR
Pure Energy greatly reduces the danger of turbine soiling, which is the main cause of falling performance and, in the long period, of damages.
lizard je napisal/-a:Bi bilo treba oz. boljše bi bilo Selenia WR P.E. predvsem zradi DPF-ja!, mislim, da je tudi to predpisano za tvojo Alfo, vsaj na strani od Selenie.
P.E. - pomeni Pure Energy
Tu pa še opis iz njihove strani:Selenia WR Pure Energy is a newly conceived fully synthetic lubricant capable to meet the needs of the most modern diesel engines. The fulfilment of the ACEA C2 specification certifies the low ash content, which is an indispensable characteristic to protect the particulate filter from residual combustion products that could cause dangerous clogging of the filter itself.
Po drugi strani pa Selenia ne spada ravno med top olja.
primozek68 je napisal/-a:Pa ne prepihat za 10 sekund na 4000obratov, ampak gas v podn za 20 minut, lahko v četrti da ne leti preveč.
One day......BACK TO BLACK!
VTS je napisal/-a:v originalnih navodilih za dizelske motorje navajajo Selenia WR.
kako naj dokažem da recimo to olje ni v redu in da se je recimo zarad tega zamašil dpf?
lizard je napisal/-a:VTS je napisal/-a:v originalnih navodilih za dizelske motorje navajajo Selenia WR.
Ne vem, koliko sem jaz bral na Alfa forumu je predpisano olje za 1.9 in 2.4 JTDm Selenia WR P.E. 5W-30, ravno zaradi tega, ker imajo 159ke serijsko DPF filtre. Možno, da je predpisana tudi samo Selenia WR. Pridi na Alfa forum, povprašaj, je gor en uporabnik ki ve o oljih precej.
Po forumu brska: Google Adsense [Bot] in 46 gostov
