Gricko je napisal/-a:Voith je napisal/-a:pa kot sm ze zgor omenu, ce das ven varovalko in se zgodi nesreca pri kateri ti odpovejo bremze, pri tem pa umre nekaj ljudi, gres na hladno za dolgo dolgo casa, kajti tovarna se morebitnih napak opere takoj ko ti pocnes nekaj tko kot ni v navodilih za uporabo avta.
zakaj bi ti pa bremze odpovedale, če ABS ne dela???
sej nimajo prov velik veze!!!
ABS je skor čist ločen od bremz!In če crkne, ti bremze še vedno delajo, le da brez ABSa!
Miholl je napisal/-a:js bi upu stavt da na suhem asfaltu, od 50 do 0 ce treniram en dan, na konc sigurn prej ustavim kot abs. na snegu pa iz prve vrej ustavim brez kot z.
To delajo poklicni vozniki,beri testerji ala Avtomagaznovci, vsak dan pa jim ne rata... ti si pač ekstra....
Nej ti še kak fizik razloži zakaj se nezablokirana guma prej vstavi ko zablokirana....
Če pa si tak optimist da ne misliš popolnoma blokirat gume, in jo držat na robu blokade in prekašat abs-si pa malo neresen....
A locked wheel has 100 % slip. Above 80% slip the brake force actually drops and the wheels ability to transmit side forces becomes low. You cannot steer and have no centrifugal force to help balance. ABS aims to stay in the 5% slip region below the uncontrollable zone. As 80% slip is exceeded it lets the brakes go but then immediately reapplies to try and get back to the maximum braking point. Hydraulic systems are slow a rider is slower. A typical full ABS cycle on air is 0.02 seconds. To pass EC/98/12 an ABS system has to equal 75% of the deceleration achieved using micro adjustment valves. You do the same stop time and time again adding a 0.1 bar pressure on single wheels until the wheels lock for more than 0.25 sec. Then you do an ABS stop and compare the deceleration. Who says test tracks are interesting.
My original post is correct about the theoretical stopping distance. If some one was lucky enough to hit 80% slip and stay there they would beat the ABS cycling between 75 and 82 %. If such a person exists they'll be taking over the world not playing on F650's. The rider who can beat ABS first time out is a job for geneticists not engineers. Theory and practice are separated by the human element.
kalbo je napisal/-a:ABS je že super zadevca, ki me je že nekajkrat rešila. Sam je treba vedet, da večina voznikov ne zna pohodit pedala za zavoro. Brez pohojenega pedala za zavoro ti ABS nič ne koristi, pa naj bo to na snegu, ledu al pa na suhem!
Preverjeno na Kuzmičevi šoli varne vožnje. Od 10 kandidatov so vedeli le trije, kaj pomeni pohoditi pedal za zavoro.
Po forumu brska: Google [Bot] in 15 gostov
