ice
Prispevkov: 3083
Kraj: Gorenjska
Renault Clio - pregled serijskih težav
Napisal/-a ice Pe feb 13, 2004 5:39 pm
Na spletni strani CarSurvey sem našel besedilo Vinca, tukaj je v angleščini:
1. The GAS stops working.
This is a real pain and should never happen, but it does. Now just imagine your waiting to make a turn and you release the clutch, the car moves for a couple of inches and dies on you as the GAS is NOT working. No worries as long as there is no 20t cement truck comming your way...
- FIXED -
Renault insists this is a design flaw as the GAS pedal's electrical cabel is by design wrapped around the stearing weel axel and gets damaged by the friction over time?
"What the hell?"
2. Thermomether never works!
At its best it's off by just 6 degrees, but this happens like twice a year. Currently the temp. outside is -2 and the display is making me believe it's +47.
- Not FIXED -
Renault reported this to be fixed... I simply just don't care anymore.
3. High-beams - screen wipers BUG
Yes, this is a computer BUG. When the backwindow / front screen wipers timmers meet to turn off at the same exact moment the highbeams are turrned off. You have to manually turn them back down and up again.
- Not FIXED -
Renalut repair shop had taken my mobile phone number two YEARS ago with a promise to call me when replacement parts become available. Guess no parts yet, ha?
4. Running on 3 cylinders.
A common problem with Clio. I was actually stupid enough to change the spark plugs after only 12,000 km's thinking that might be it... but noooo. Passing the ECO test is going to be a killer with this catalyst I can tell.
- Not FIXED -
5. Ignition problems
Once temps drop below freezing point the car does not start. One has to be very patient and remain in the car for like 10 minutes trying the ignition over and over again. It eventualy fires up. I have no idea why this happens I just know I hate it!
- Not FIXED -
This started happening something like a year ago. Gave me trouble for a week and than stopped. Not that it's back I can just see me paying another $1000 to get it fixed.
I've started parking on hilltops as an emediate remedy to the problem.
6. The service light.
Now, does this light have a will of it's own or is it me? I mean does it just turn on to bug you or is there a purpose to it?
- Not FIXED -
Naturally, I can never get it to work when it's in the repairshop.
7. Stearing wheel height level adjustment lock
This lock has an annoying tandency to just release on a regular basis. This is very dangerous especialy at high speeds.
- Not FIXED -
You just have to remember to check the possition every now and then.
8. El. Windows
Very poorly assembed and I imagine the materials used are just a pile of junk. Gives up a very bad performance in rain.
That's it for now... I have to go push my car down a hill now.
Kind regards.
Vince
IceBreakr
ice
Prispevkov: 3083
Kraj: Gorenjska
Napisal/-a ice Pe feb 13, 2004 5:41 pm
p.s. vse lastnike Cliotov (ki jih je na avtomobilizem.com že kar veliko) sprašujem, če jim gre v teh dneh kaj na živce škripanje zavor ;) hehe, še ena serijska nadležnost novih Cliotov... spucat se nam jih pred spomladjo verjetno ne da? ;)
IceBreakr
habbich
Prispevkov: 1897
Pridružen: To jan 14, 2003 3:40 pm
Napisal/-a habbich Pe feb 13, 2004 7:16 pm
Mamo doma tud cliota 2003 letnik, pa nic od nastetih problemov...ne vem mogoce je pac naletu na slabo serijo
Ce bo pa kej narobe pa napisem
darkdog24
Prispevkov: 2211
Pridružen: Če sep 18, 2003 6:30 pm
Kraj: Velenje
Napisal/-a darkdog24 Pe feb 13, 2004 7:23 pm
Js mam pa Cliota letnik 1995 pa me ful poleti živcira škripanje bremz in sklopke.Vsakič ko sklopko stisnem zaškripa,prav tako tudi vsakič ko stopim na zavoro zaškripa :evil: In to se dogaja samo poleti ko je ful vroče in zrak ful topel.Ko je pa zima al pa ko dežuje tega ne slišiš.
Zanimivo :roll:
UPOKOJENI STYLER (8 pokalov)Slika
Napisal/-a lisko Ne feb 15, 2004 5:06 am
Mislim da tole škripanje zavor in sklopke ni sam kliotova nadloga :D To se je men dogajal pri obeh petkah.Sam a je problem pri ročkah podmazat dele ki se gibljeo? pa zajlo za sklopko pa tko :lol: no pol to škripanje čudežno izgine:)
Skull23
Prispevkov: 2128
Kraj: Kolomban
Napisal/-a Skull23 Ne feb 15, 2004 10:57 am
Dejte z grafitno mastjo namazat diske, pa bo. Baje da tudi voda rada udira v vrata pri teh novih klijotih, je to res?
Ruff_RydeRR
Prispevkov: 824
Pridružen: Če feb 12, 2004 12:31 am
Napisal/-a Ruff_RydeRR Ne feb 15, 2004 11:49 am
no sej jst mam podobne probleme z 1.8 16v na momente še hujše :x bi ga tud u kkšn grabn zavozu :)
My soul almost complete ;)
Nu-NRG
Prispevkov: 2344
Napisal/-a Nu-NRG Po feb 16, 2004 1:16 pm
Bivsi sodelavc kupil novega cliota 1.5 dizla .. po pol leta se je predal in semu ne da vec po servisih.. avto takrat se ni bil star pol leta in so bili problemi sledeci.
1. Rjsate pikce po strehi (odgovor servisa bomo pogledal .. 0 od tega)
2. Cricki v armaturki (na servisu raztavli in nazaj sestavli .. sezmer cricka)
3. Ko je bilo pod 5 stopinj avto vzgal z tezavo
Po forumu brska: Google [Bot], Google Adsense [Bot] in 24 gostov
