acidos
Prispevkov: 26
Pridružen: Ne sep 08, 2013 4:11 pm
Citroen C3 servo volan
Napisal/-a acidos Sr mar 16, 2016 6:56 pm
Pozdravljeni.
Imam citroen c3 2002 letnik 1.4 in imam problem z servo volanom.
Včeraj mi je še normalno delal, danes se pa vsedem v avto ga zalaufam speljem in opazil da servo sploh ne dela ( volan je trd, kot da serva sploh nebi bilo )Sicer na armaturi se ni prižgala nobena lučka.
Kaj bi lahko bilo narobe? kakšna varovalka, računalnik.....
Ivan36
Prispevkov: 4577
Re: Citroen C# servo volan
Napisal/-a Ivan36 Sr mar 16, 2016 7:05 pm
Sorry don't know how to help, but c3 is well known for this problems.
If i were you - i would reset the BSI first. Of course this doesnt look like bsi controlled thing, it would be stupid to programm that ecu could turn off it, but well.who knows maybe it would help.
open your bonnet
open drivers door window.
ignition on
off
shut the doors (go outside the car)
wait 3minutes.
disconnect battery +
wait 3mins
connect battery
wait 15secs
via driver's window switch lamps on (you will hear GONG sound..)
switch ignition on.
that's it. this is the reset procedure.
citroenc3owners.com/citroen-c3-questions/intermittent-power-steering-problem-t738.html
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 Sr mar 16, 2016 7:12 pm
Mimgrede ima tudi P207 L9 podbne težave a samo pri hladnem vozilu, par sekund po zagonu sploh ni serva! Nobene opozorilne lučke a ne dela ene 30sec. ???
acidos
Prispevkov: 26
Napisal/-a acidos Sr mar 16, 2016 7:27 pm
Misliš vsa električna oka na vratih odpreti do konca, izklopiti avto iz kontakta, zapreti avto ter odkopiti akomulator, počakati ter nazaj vklopiti da zapiska in vklopiti kontakt in to je to ?
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 Če mar 17, 2016 8:26 am
acidos je napisal/-a:Misliš vsa električna oka na vratih odpreti do konca, izklopiti avto iz kontakta, zapreti avto ter odkopiti akomulator, počakati ter nazaj vklopiti da zapiska in vklopiti kontakt in to je to ?
Samo voznikovo steklo, da slišiš.. To je prvo, če ne bo delalo ja pa okvara.
odprite pokrov
odprte okna vrata.
kontakt na
off
zaprta vrata (iti izven vozila)
počakajte 3 minute.
odklop akumulatorja +
počakajte 3 min
priključiti baterijo
čakal 15 sekund
preko okna voznikovih vrat (slišite zvočnim ..)
vključite kontakt.
to je to. To je postopek ponastavi.
acidos
Prispevkov: 26
Re: Citroen C3 servo volan
Napisal/-a acidos Če mar 17, 2016 10:40 am
Danes pa dela vse normanlo kot da ni bilo nič. :D
Po forumu brska: 0 registriranih uporabnikov in 518 gostov
