Simkha/Billy
Prispevkov: 2
Pridružen: Pe dec 30, 2016 10:42 am
AdBlue reset Seat Alhambra 2012
Napisal/-a Simkha/Billy Pe dec 30, 2016 11:04 am
Zdravo,
Mogoče komu prov pride...
Na seat Alhambri se mi je prižgalo obvestilo: AdBlue no engine start in 1000 km. ikona za doliti adblue in spodaj ključek
Priklop in prgled z VCSD mi je pokazal napako :
Tuesday,27,December,2016,16:48:39:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: *********** License Plate: 11111111
Address 01: Engine Labels: 03L-906-018-CFF.clb
Control Module Part Number: 03L 906 018 HL HW: 03L 906 018 M
Component and/or Version: R4 2,0L EDC H27 9228
Software Coding: 0019001A042401080000
Work Shop Code: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018HL 003006 (VW36)
VCID: 7BF51167F210BBC6C11-802E
1 Fault Found:
15733 - SCR NOx Catalyst Bank 1
P20EE 00 [101] - Efficiency too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 98153 km
Date: 2050.14.02
Time: 12:56:58
Readiness: 0 0 0 0 0
Po izbrisu napak z VCSD mi je opozorilo še svetilo, vendar ponovni scan ni pokazal napak... :(
Probal veliko stvari:
- Resetting of SCR Tank Level Detection
- Reset SCR Lock
- Diesel Particle Filter Emergency Regeneration -> http://wiki.ross-tech.com/wiki/index.ph ... generation
- Po pogovoru z mehanikom tudi pri kontaktu - izklop akumulatorja. čakanje 10 min.
vendar na koncu se je izkazal uspešen postopek ki sem ga našel preko interneta:
http://forums.ross-tech.com/showthread. ... -Procedure
Prerequisites:
- Engine fully warmed up (above 80’C) and idling
- Transmission in Park/Neutral
- Emergency brake = On
- Doors and hood are closed
- Do not depress any pedals during this procedure, until instructed to do so.
To Reset the AdBlue Level:
- Clear all fault codes(yes, even if there are none present)
- Select 01-Engine]
- Select [Basic Settings-04]
- From the pull down menu choose:
- - - [Resetting of learned values of average quantity adaptation], press [Go!]
- - - - After completion, Press [Stop]
- - - Then [Reset learned values quant. meter. unit and press. contr. Valve], press [Go!]
- Select [Check of SCR efficiency], press [Go!]
- Depress Brake pedal, then depress accelerator pedal, the ECM should take control of the Engine speed.
- This test may take up to 30+ minutes to complete!
- Upon completion, you should see ‘System Okay’, the AdBlue light and the warning message about ‘miles to no start’ will be reset. Verify there are no fault codes.
Sedaj dajmo času čas. Če je karkoli narobe z senzorjem Nox -a ali na tem sistemu bo verjetno ponovno zajambral...
Ivan36
Prispevkov: 4577
Re: AdBlue reset Seat Alhambra 2012
Napisal/-a Ivan36 Pe dec 30, 2016 11:19 am
Pa ravno prej videl na PETROLU ADDBLUE za 16€ 5 litrov :shock: NOVO, baje od njih ....
RedBaron
Prispevkov: 2272
Napisal/-a RedBaron Pe dec 30, 2016 12:14 pm
In za koliko litrov nafte je potem teh 5l AdBlue?
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 Pe dec 30, 2016 12:18 pm
Bom prebral, ko bom spet tam .... me res zanima ! Je pa pakirano v prozoren meh in ima ročko za dolivati tako z rebri ...
Simkha/Billy
Prispevkov: 2
Napisal/-a Simkha/Billy Pe dec 30, 2016 12:48 pm
Kakor sem po forumih prebral zadostuje za okoli 15 k kilometrov 1 tank. Tudi na uradnem servisu sem spraševal ali sem jest mogoče zaj... ker sem točil tega iz OMV . pa je serviser reku isto sranje, drugo pakovanje...
cena euroton 10 l ->cca 13 eur
še post iz siol-a
"V sharanu oziroma alhambri je na levi strani prtljažnika skrit 17-litrski rezervoar, ki zadošča približno za 17.000 kilometrov. Kot smo že navedli, je poraba raztopine približno enaka petim odstotkom porabe goriva. Med vožnjo v idealnih razmerah zadošča 17-litrski rezervoar, ki bi ga popolnoma izpraznili, za precej večjo razdaljo, kot jo navaja Volkswagen. "
je pa res mal bol zahtevno za dolit pr Alhambri...
sašo5
Prispevkov: 5085
Kraj: Brežice
Napisal/-a sašo5 Pe dec 30, 2016 3:10 pm
na črpalkah (ponavadi kamionski del) je po 0,6€ če se ne motim....
Crafter (stari 2.5) 20 litrov rezervar, točno za 15tkm (na ekranu sicer napiše, da je še za 2700 km )
