Other Problems – In case no problems can be found in the CMP sensor or its wiring, it may be that P0340 or P0345 are simply auxiliary fault codes. A jumped timing belt, faulty crankshaft position sensor signal or circuit, or engine misfire, may be the primary problem. Double check these before coming back to the CMP.
