Fault location Fault type
00003 - Control unit defective
00234 - ACC sensor misaligned
00446 - Function impairment due to low voltage Lower limit not achieved
00447 - Function impairment due to high voltage Upper limit surpassed
00456 - Entry and start authorisation control unit - J518 No signal/communication
00457 - Onboard power supply control unit -J519 No signal/communication
00466 - Steering column electronics control unit -J527 No signal/communication
00466 - Steering column electronics control unit -J527 Implausible signal
00466 - Steering column electronics control unit -J527 Please read fault memory
00473 - Electronic parking/hand brake control unit - J540 No signal/communication
00473 - Electronic parking/hand brake control unit - J540 Implausible signal
00532 - Supply voltage Upper limit surpassed
00532 - Supply voltage Lower limit not achieved
00652 - Gear monitoring Implausible signal
00778 - Steering angle sender -G85 No signal/communication
00778 - Steering angle sender -G85 Implausible signal
01042 - Control unit not coded
01044 - Control unit incorrectly coded
01299 - Data bus diagnostic interface -J533 No signal/communication
01299 - Data bus diagnostic interface -J533 Implausible signal
01314 - Engine control unit No signal/communication
01314 - Engine control unit Implausible signal
01314 - Engine control unit Please read fault memory
01315 - Gearbox control unit No signal/communication
01315 - Gearbox control unit Implausible signal
01315 - Gearbox control unit Please read fault memory
01316 - Brake control unit no signal/communication
01316 - Brake control unit Implausible signal
01316 - Brake control unit Please read fault memory
01317 - Control unit in dash panel insert -J285 No signal/communication
01317 - Control unit in dash panel insert -J285 Implausible signal
01317 - Control unit in dash panel insert -J285 Please read fault memory
01319 - ACC control unit -J428 No or incorrect basic setting / adaption
01330 - Convenience system central control unit -J393 No signal/communication
01330 - Convenience system central control unit -J393 Implausible signal
01330 - Convenience system central control unit -J393 Please read fault memory
01517 - Trailer recognition control unit -J345 No signal/communication
01517 - Trailer recognition control unit -J345 Implausible signal
01517 - Trailer recognition control unit -J345 Please read fault memory
01577 - Switch-off due to overheating
02001 - ACC data bus defective
02002 - ACC sensor heater -Z47 Electrical fault in circuit
02003 - Driver identification control unit -J589 No signal/communication
02003 - Driver identification control unit -J589 Implausible signal
02012 - ACC safety shut-off
02084 - Component protection No or incorrect basic setting / adaption
02095 - Component protection active
02213 - Function shut-off based on brake temperature
1 Spare
2 Spare
3 5A motor control
4 5A oil level sensor
5 5A air conditioner
6 5A Electronic Dynamic Stability Program (ESP), clutch sensor
7 5A plug for diagnostic system
8 5A HomeLink control unit
9 5A auto-shielded interior rearview mirror
10 5A maintaining distance (adaptive cruise control)
11 5A auxiliary heater
12 10A plug for diagnostic system
13 10A steering column switch module
14 5A brake signal switch
15 10A instrument cluster
16 10A telephone, telematics, mobile phone
17 10A Electronic Stability Program (ESP)
18 5A left headlight electronics
19 5A rain sensor
20 5A heated washer jets
21 5A antenna amplifier
22 absent
23 5A electromechanical parking brake
24 absent
25 absent
26 absent
27 absent
28 absent
29 absent
30 absent
31 15A reversing light switch, multitronic transmission, engine component
32 30A intelligent driver power module (footwell and headlights, horn, wiper, ele. steering column adju.)
33 25A intelligent driver power module (lighting on the left)
34 25A intelligent driver power module (right lighting)
35 20A auxiliary heater
36 30A headlight cleaner
37 25A Electronic Stability Program (ESP)
38 30A wiper
39 15A left door control unit
40 25A beep / MMI display
41 40A heater fan
42 30A ECM / ELECTRONIC STEERING COLUMN CONTROL MODULE
43 absent
44 15A advanced key control box / airbag
A Fuse for ABS control unit 1 -S123- (40A)
B Spare
C Spare
D Spare
1 Power relay (terminal 15) -J329-
2 Headlamp washer relay -J39-
3 Spare
4 Starter relay -J53-
5 Power relay (terminal 75x) -J694- (up to 04.2005)
6 Starter relay 2 -J695-
7 Signal relay -J4-
7 Voltage supply relay (terminal 75x) -J694- (from 05.2005)
8 Spare
9 Spare
