Skodilars1 I've just looked your error code up on my new obd eleven app.
It says it means microphone open circuit.
That means that somewhere a wire is unplugged or broken between your microphone and the head unit.
I don't know where the wires go between the 2 things or how many connections they have but I would look on the back of the head unit as a starting place and see if you can work out which wires it is and unplug and then replug them to make sure it's a good connection.
I have heard of other people having problems with aerial wires coming unplugged it could be a similar problem good luck
Po forumu brska: Google [Bot], Google Adsense [Bot] in 14 gostov
