dusan25
Prispevkov: 89
Pridružen: Pe jul 16, 2010 9:27 pm
Golf V - problem z ogrevanjem
Napisal/-a dusan25 To mar 31, 2020 4:05 pm
Vprašanje:
Golf V letznik 2004 ,212750 km, avto mi hladi desno stran potem včasih tudi na levi piha toplo, klima pa tudi enkrat hladi drugič pa greje izmenjaje.
Prilagam vse napake, ki so bile po narejene v otuput testu.
01809 - Actuating Motor for Temperature Flap; Left (V158)
000 - - - Intermittent
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - -
00710 - Defroster Flap Positioning Motor (V107)
00716 - Air recirculation Flap Positioning Motor (V113)
000 - -
01274 - Air Flow Flap Positioning Motor (V71)
To so merilni bloki, so v redu te vrednosti? Ima kdo izkušnje?
Address 08: Auto HVAC (1K0 907 044 AB)
16:39:39 Group 003
2.8 bar Refrigerant Pressure
9.6 % Radiator Fan Activation (actual)
0.0 % Radiator Fan Activation (spec.)
OFF Engine Speed (increase)
16:40:19 Group 005: Outlet/Footwell Blower Temperature
6.0°C Left Outlet Blower Temperature
6.0°C Right Outlet Blower Temperature
5.0°C Left Footwell Blower Temp.
5.0°C Right Footwell Blower Temp.
16:40:26 Group 005: Outlet/Footwell Blower Temperature
16:41:11 Group 006
6.0°C Evaporator Temperature
12.0°C Interior Temperature
0.0 Left Sunlight Intensity (G107)
0.0 Right Sunlight Intensity (G134)
16:42:00 Group 012: Left Temperature Flap Control Motor (V158) / Potentiometer (G220)
231.0 Potentiom. (G220) Current Value
230.0 Potentiom. (G220) Specified Value
24.0 Min. Position (G220) (Lower Stop/Close)
230.0 Max. Position (G220) (Upper Stop/Open)
Kaj bi lahko bil vzrok, mogoče tlačno stikalo? Ima kdo izkušnje, zdj ko smo v karanteni upam da se najde kakpen ki bi mi lahko pomagal na daljavo :) Evo sm vam dal dela v karanteni :)
golfek
Prispevkov: 91
Pridružen: Sr mar 22, 2017 8:11 pm
Re: Golf V - problem z ogrevanjem
Napisal/-a golfek Sr apr 21, 2021 9:19 pm
en motorčk ti šteka
vipe5s
Prispevkov: 321
Pridružen: Pe avg 07, 2015 11:46 am
Napisal/-a vipe5s Če apr 22, 2021 10:51 am
Ja, upam da je rešil (po enem letu).
Po forumu brska: Google [Bot] in 23 gostov
