rrobic
Prispevkov: 35
Pridružen: Sr feb 21, 2007 12:03 pm
vag com in stanje šob ter turbine pri tdi motorjih
Napisal/-a rrobic Ne okt 14, 2007 1:46 pm
a kdo ve na katerem kanalo lahko preveriš pritiske oz stanje vbrizgalnih šob in pritiska turbine za tdi dizle
im nobody
Prispevkov: 3321
Kraj: laško
Napisal/-a im nobody Ne okt 14, 2007 2:03 pm
pop tv
ka boš ti kr teme odpiral :?:
passat 1.9 tdi 110,235 nm
Na levi pas...do konca gas
rrobic
Prispevkov: 35
Napisal/-a rrobic Ne okt 14, 2007 2:10 pm
a te moti al kaj
im nobody
Prispevkov: 3321
Kraj: laško
Napisal/-a im nobody Ne okt 14, 2007 2:11 pm
ne samo mene
JoeLoe
Prispevkov: 242
Pridružen: To maj 16, 2006 5:53 pm
Re: vag com in stanje šob ter turbine pri tdi motorjih
Napisal/-a JoeLoe Po okt 15, 2007 7:51 am
rrobic je napisal/-a:a kdo ve na katerem kanalo lahko preveriš pritiske oz stanje vbrizgalnih šob in pritiska turbine za tdi dizle
Pritiska, mslim, da ne boš ugotovil, ugotoviš in nastaviš pa lahko količino vbrizganega goriva. Spodaj maš seznam. Uporaba na lastno odgovornost!
Group 000 measuring blocks
From left to right
Engine idle speed: range 42 - 45 = 870-950
Start of injection: range 12 - 75 = 2 degrees ATDC - 3 degress BTDC
Throttle position: 0 = 0 %
Injection quantity: 11 - 45 = 2.2 - 9.0 mg/stroke
Manifold Absolute Pressure
Atmospheric pressure
Engine coolant temperature: 80 - 35 = 80 - 110 degrees C
Intake Manifold Temperature: 182 - 50 = 10 - 110 degrees C
Fuel Temperature: 91 - 201 = 20 - 80 degrees C
Air mass: 69 - 111 = 230 - 370 mg/H
These are valid ranges only when the EGR is switched on, engine at idle and at least 80C (176F) coolant temp.
Group 001 (injected quantity)
Engine RPM: 870 - 950
Injected quantity: 2.2 - 9.0 mg/H
Modulating piston displacement sensor voltage: 1.450 - 2.000 V
Engine coolant temperature sensor: 80 - 110 C
If below 2.2 - injection is running too rich
If above 9.0 - injection is running too lean, or the engine is cold
If below 1.450 volts - injection too rich
If above 2.000 volts - injection is too lean, or engine is cold
Group 002 (idle speed)
Engine rpm: 870 - 950
Operating condition: 010
Engine coolant temperature: 80 - 110 C
Throttle should go 0 - 100 depending on pressure applied to "go" pedal
Operating condition left digit: 1 = idle increased because AC is on
Operating condition middle digit: Closed throttle position switch is closed (foot not on pedal)
Operating condition right digit: AC compressor switched on
Group 003 (EGR)
Air mass drawn in (specified): 230 - 370 mg/H
Air mass drawn in (actual): 230 - 370 mg/H
EGR vacuum solenoid duty cycle: 40 - 75 %
If air mass specified is above 370, engine too cold.
If air mass actual is below 230 mg/H, excessive EGR or an air leak.
If air mass actual is above 370 mg/H, engine is cold, insufficient EGR, or bad MAF sensor
(Note: EGR is turned off after approximately 2 minutes of idle. Reading should be within that time period.)
If a DTC is present, air mass actual will have a constant value of approx. 550mg/H over the complete RPM and load range.
Group 004 (Start of injection)
Start of injection (specified): 2 ATDC - 3 BTDC
Start of injection (actual): 2 ATDC - 3 BTDC
Cold start injector duty cycle: 3 - 80%
If start of injection (specified) is earlier than 3 BTDC, engine too cold.
If start of injection (actual) is before 3 BTDC, engine too cold, injection pump set too advanced, or cold start injector inoperative.
If start of injction (actual) is later than 2 ATDC, injection pump is set too retarded, injection adjustment blocked, or cold start injector inoperative.
Group 005 (starting conditions)
Engine speed
Starting quantity
This is not useful for troubleshooting.
Group 006 (test with ignition switch on)
Speed
Brake pedal monitor
Cruise control system
Cruise control system (indicates if activated, 0 = activated but switched off, 1 = activated, swtiched on, 255 = not activated)
Cruise control system left digit: Clutch switch closed (clutch not depressed) = 0, 1 = clutch depressed
Cruise control system middle digit: CC/DFI brake pedal switch open (brake pedal depressed) = 1, 0 = pedal not depressed
Cruise control system right digit: brake light switch depressed pedal = 1, not depressed = 0
Right cruise control system 6 digit display has a 1, left to right, when:
Clutch operated
Brake pedal operated
Resume speed operated on the switch
Acceleration operated on the switch
Cruise control and memory switched off
Cruise controll system switched on
Group 007 (Temperatures)
Fuel Temperature
Nothing
Air intake temperature
If the car has been sitting overnight (for example) these should all equate to approximately ambient air temperature. If not a sensor may be bad.
If fuel temp indicates -5.4C, there is a short circuit or the sensor is bad/inoperative.
If air temp indicates approx. 136.8C (275F) the air temp sensor is bad/inoperative. Check for a DTC.
If coolant temp sensor indicates a large deviation from ambient temp, there may be a short circuit or the ECT sensor is bad/inoperative.
Group 008
Injection limitation when warm/full throttle/3rd gear @ 3000 RPM
Engine rpm (2900-3100)
Injection quantity requested mg/R (40.0-42.0)
Injection quantity rpm limit mg/R (35.5-36.5)
Injection quantity MAF limit mg/R (36.0-39.0)
Group 009 (injection quantity limitation)
Engine rpm
Injection quantity (cruise control system active)
Injection quantity limit signal from automatic transmission controler during gear change
Nothing
Group 010
Air system warm/full throttle/3rd gear @ 3000 RPM
MAF sensor: 800-1000
Barometric pressure
MAP (boost): 1700-2080
Throttle position %: 100
Group 011
Charge pressure control warm/full throttle/3rd gear @ 3000 RPM
Engine rpm
Specified MAP: 1850-1950
Actual MAP: 1700-2080
MAP Valve DC: 45-95
Group 012
Glow Status
Glow period
Suply voltage from ECM
Not useful for troubleshooting.
Group 013
This group shows the smooth running control injected quantity cylinder 1 - 4, left to right. Values expected -2.0 - + 2.0 mg/R
This is showing how the ECM is balancing the power for each cylinder at idle to account for variations in component tolerances, jet sizes, compressions, etc.).
Group 015 (fuel consumption)
Engine rpm
Injected quantity (actual)
Fuel consumption
Injection requirement (as indicated by the go pedal)
Group 016 (additional heater)
Generator loading
Additional heater
Activation of heater elements
Voltage supply from ECM
Additional heater display is 8 digit number where, left to right, 1 =
nothing
nothing
ECT sensor inoperative
engine started within the last 10 seconds
engine speed below 870 rpm
battery voltage below 9 volts
generator inoperative
ECT exceeds 70 C-80C (158F - 176F), or intake air temp exceeds 5C (41F)
Activation of heater elements is a 2 digit number. Left digit = 1 when high heat output relay is on. Right digit = 1 when low heat output relay is on.
Group 017 readiness code
Not relevant
binary code: x000xxxx
Not relevant
binary code: 0xxxxxxx
These may represent ready (0) for "Comprehensive component", "Misfire", and "Fuel system" in the first code and "EGR system" in the second. I have not verified.
Group 018
Speed
binary bits: 00
nothing
nothing
Group 019 (Quantity adjuster)
Voltage from modulating piston displacement sensor: 0.500 - 0.970 V
Voltage from piston displacement sensor: 4.150 - 4.740 V
nothing
nothing
If specfied values are out of tolerance, possible malfunction of the injection pump quantity adjuster.
Group 020
Ignition timing
Absolute pressure
Speed
Load
Group 021
Fuel Temperature
Intake Air Temperature
Absolute pressure
Load
Group 022
Binary bits
Unknown
Binary bits
Binary bits
Group 026
An undocumented field
Groups 027-040
nothing in any field
Groups 041-079
Not valid
Group 080
Jibberish
Group 081-085
Nothing in any field
Group 086-124
Not valid
Group 125 CAN bus communiation status
Auto. trans. controller: Transmission 1
ABS status: ABS 1
Instrument status: Instruments 1
Airbag status: Airbag 1
Group 126-129
Group 130-255
Not valid
Moj je vedno pripravljen za dogodivščine!
dules
Prispevkov: 327
Pridružen: Ne dec 28, 2003 2:04 pm
Napisal/-a dules Po okt 15, 2007 7:17 pm
zdej pa povej kje si tole razlago dobil hvala
Volkswagen Golf MK1 motor 1.1 letnik 1978 v obnavljanju ter Golf MK4 1.9 TDi 130 Konj letnik 2003
andrej86
Prispevkov: 727
Napisal/-a andrej86 Po okt 15, 2007 7:56 pm
dules je napisal/-a:zdej pa povej kje si tole razlago dobil hvala
mogoče autodata? :shock:
dules
Prispevkov: 327
Napisal/-a dules Po okt 15, 2007 7:59 pm
nobeden program kakor je autodata in vivid workshop oz njim tega nimajo notri !
Največ teh stvari se dobi večinoma po netu sam sem že kar nekaj cajta iskal pa ne dobim kar bi hotel !
Napisal/-a abbe Po okt 15, 2007 10:25 pm
sicer ne vem ke je dobu to ampak je ze prj v eni temi o zgorevalnih komorah razlozu zadevo v nule.seprav da ma zlo velik pojma o zadevah.vec takh bi rabl na forumu.
JoeLoe
Prispevkov: 242
Napisal/-a JoeLoe To okt 16, 2007 7:24 am
Že pred časom, je Google zame najdu :-), ko se m pač rabil.
Dragi moji, sicer je podoboen skupek informacij za tiste, ki imamo registriran in legalno kupljen vag-com, na voljo tudi na Rosstech-ovem portalu. Pa v njihovm forumu, so zgleda hudi znalci.
Če maš voljo in cajt (al pa če moraš) najdeš literaturo in informacije.
dules
Prispevkov: 327
Napisal/-a dules To okt 16, 2007 4:49 pm
kaj al misliš da nism gledal oz da nisem dobil neke podatke , sam kaj la jest gotovo iščem pod napačno besedo al kaj ne vem
tisto kar je na vag-com strani pa že vse vem !
JoeLoe
Prispevkov: 242
Napisal/-a JoeLoe To okt 16, 2007 7:32 pm
dules je napisal/-a:kaj al misliš da nism gledal oz da nisem dobil neke podatke , sam kaj la jest gotovo iščem pod napačno besedo al kaj ne vem
Ja, glih kuker sem reku, ejga. Cajt, vuola al pa muss! ...pa najdeš.
Jaz sem se lotil teh zadev glih zaradi mehanikov, ki so mi s svojo šlamparijo in neprofesionalnostjo dali mislit.
En mi je na R5 Five mašino uniču, k je mela samo 45.000 km. Zaradi drugega bi se kmalu zaletel. Jasno so pa vsi mastno računal. Jaz pa kredit za stanovanje pa kredit za avto, pa kredit za dopust...pa dojenčka doma.
No pr men je bil muss!
Aja, pa fotr je mel enga prjatla, k so mu na pooblaščenem Citroen servisu Viso servisiral. Možak se je malo vozil, ampak vsakič do dneva natančno pripeljal avto na servis (na eno leto). V tretjem letu, pri prevoženih cca. 12.000 km je mašina zaribala. Zakaj? Ker mu nikoli niso zamenjali olja! Zaračunali so ga seveda vedno.
