reber
Prispevkov: 836
Kraj: Bled
passat 2007 servo volan?
Napisal/-a reber To dec 04, 2007 5:54 pm
Kako ima passat 2007 2.0tdi narejen servo volan?
Ali ima servo črpalko in olje, ali je res popolnoma električni in baje preko jermena ali pa direkt, saj ni pomembno.
S kolegom sem šel stavit za kišto pira, pa bom zgleda zgubu, ker sem jaz reku, da ima olje in servo črpalko, elektro je pa samo pomoč pri parkiranju in mestni vožnji, oziroma za regulacijo trdote volana, še vedno pa je olje tisto, ki je pogonski medij ...
Kaj je zdaj res in kaj ne ali je mogoče pri passatu več variant z volanom, ki je odvisen od opreme?
RED_line
Prispevkov: 670
Kraj: Markovec City
Napisal/-a RED_line To dec 04, 2007 8:17 pm
vsi passati imajo za moje pojme isti volan. kašen servo je, pa tine bi znal povedat.
gassssssssssssssssss
phoebus
Prispevkov: 1496
Napisal/-a phoebus To dec 04, 2007 8:57 pm
ROFL. Vsi audiji slabo vlečejo, vsi BMWji so nevemkaj, vsi passati imajo zame enak volan,... :pop:
Tattoo-
Prispevkov: 1318
Kraj: Circuit de la Sarthe
Re: passat 2007 servo volan?
Napisal/-a Tattoo- To dec 04, 2007 9:19 pm
reber je napisal/-a:Kako ima passat 2007 2.0tdi narejen servo volan?
Popušil si! ;)
Passat nima več običajnega hidravličnega servo volana, ampak ima neodvisno od izbranega nivoja opreme elektro-mehanski volan!
Electrical-mechanical power-assisted steering is making its première in this class of the new Passat – one of the most innovative steering systems in the world. The same applies to the system used in the Passat as it did in the earlier Touran, Golf and Golf Plus; it provides definite feedback that gives the driver a proper “feel” for the steering. Besides numerous benefits in the area of vehicle dynamics, the electrical-mechanial steering has a positive effect on fuel consumption, because, in contrast to conventional hydraulic solutions, it “works” only when the steering-wheel is turned. This reduces the average fuel consumption by about 0.2 of a litre. A further feature of the “self-teaching” steering is straightrunning correction. The system recognises transverse angles in the roadway by itself, and compensates for them. Straight-running correction thus adds significantly to driving comfort.
AM
Prispevkov: 748
Napisal/-a AM To dec 04, 2007 9:39 pm
:pop:
Napisal/-a joztom To dec 04, 2007 10:46 pm
A Passati imajo servo volan?
reber
Prispevkov: 836
Kraj: Bled
Napisal/-a reber Sr dec 05, 2007 10:11 am
:( heh, se mi je kar zdelo, sem se spomnil trenutek kasneje, ko sva šla stavit, zdej je kar je ... ampak dobro pa je, da bova gajbo spraznila skupaj :pivo :pij:
Ampak 0,2l da se pozna prihranek če ni servo črpalke :shock: to se mi pa zdi veliko
RED_line
Prispevkov: 670
Kraj: Markovec City
Napisal/-a RED_line Pe dec 07, 2007 12:03 pm
phoebus je napisal/-a:ROFL. Vsi audiji slabo vlečejo, vsi BMWji so nevemkaj, vsi passati imajo zame enak volan,... :pop:
v čemu je problem? to da se mi zdi da so vsi isti?
avtomobil
Prispevkov: 287
Pridružen: Če apr 28, 2005 8:40 am
Napisal/-a avtomobil Pe dec 07, 2007 11:38 pm
Kaj pa octavia?
Avto,moj partner!!!!!!!!
