yyyeb
Prispevkov: 178
Pridružen: So nov 08, 2008 8:35 pm
olje diesel, olje bencin
Napisal/-a yyyeb Ne dec 07, 2008 10:31 am
ali obstaja kaka razlika kaj moraš dolivat v kakšen motor ali je vse eno?
npr. 5w30 lahko dolijem v bencinarja in v diesla?
Napisal/-a adis Ne dec 07, 2008 10:50 am
yyyeb
Prispevkov: 178
Napisal/-a yyyeb Ne dec 07, 2008 1:58 pm
še enkrat isto vprašanje!
a se razlikuje olje za diesel od olja za bencinarja?
Napisal/-a abbe Ne dec 07, 2008 2:03 pm
da
yyyeb
Prispevkov: 178
Napisal/-a yyyeb Ne dec 07, 2008 2:04 pm
po čem?
Napisal/-a adis Ne dec 07, 2008 2:07 pm
http://www.avtomobilizem.com/forum/view ... 6e7a53547f
In petrol (gasoline) engines, the top compression ring can expose the motor oil to temperatures of 320 °F (160 °C). In diesel engines the top ring can expose the oil to temperatures over 600 °F (315 °C). Motor oils with higher viscosity indices thin less at these higher temperatures.
Different motor oils are sold for Diesel fuel engines, with many claimed to contain a higher level of detergents and dispersants to keep fine combustion soot in suspension. However, for some brands only the packaging varies (the oil is the same), and in general a diesel engine can use any good quality oil of the correct grade and specification.
Zadnjič spremenil adis, dne Ne dec 07, 2008 2:11 pm, skupaj popravljeno 1 krat.
Napisal/-a abbe Ne dec 07, 2008 2:07 pm
na to ti noben nebo znau odgovort(proizvajalci tega ne povedo,niti pa ne verjamem da bos kje na netu zasledil) ampak ce na flasi pise da je za dizle na eni drugi pa da je za bencinse motorje poj vrjetn je neki tazga notr.enkrat je ze bla debata o tem,pa ce ti nekdo da link ga je pametno prebrat
