egster
Prispevkov: 166
Pridružen: To dec 25, 2007 5:55 pm
Čuden zvok volana
Napisal/-a egster So jan 24, 2009 1:14 pm
Se mogoče komu sanja, kaj bi pomenil tale zvok:
http://www.youtube.com/watch?v=9tBqpYmBAaA
Sem opazil en dan, ko sem imel izklopljen radio, drugače ne dela tega. Predvsem tudi to počne samo na mestu, med vožnjo ne??
Hvala.
R
mihaing
Prispevkov: 2875
Kraj: Slovenc
Napisal/-a mihaing So jan 24, 2009 1:29 pm
citiram: If the car is running at idle speed while you are turning, the power steering pump has to push a lot of fluid with little power. If it sounds like a slight creaking, then it's normal. If it is a high-pitched squeal, then the serpentine belt may need to be tightened or replaced. Either way is not that big of a deal. If it is a grinding noise and you can feel a jerking motion as you turn the steering wheel, then you have a serious problem and need to take it into a mechanic.
mihaing
Prispevkov: 2875
Kraj: Slovenc
egster
Prispevkov: 166
Napisal/-a egster So jan 24, 2009 1:42 pm
potem je to še v mejah normale :?: :D
mihaing
Prispevkov: 2875
Kraj: Slovenc
Napisal/-a mihaing So jan 24, 2009 1:54 pm
Recimo. Samo jaz bi vseeno šel vprašat na servis koliko košta popravilo.
TrijoAdijo
Prispevkov: 4168
Napisal/-a TrijoAdijo So jan 24, 2009 4:17 pm
Jest bi poizkusil z menjavo olja v servo letvi.
LP!
Napisal/-a pskoda So jan 24, 2009 5:27 pm
pumpa bo šla
