EsEk
Prispevkov: 19
Pridružen: So feb 13, 2010 12:25 am
AUDI A6 2005 --- PROBELEMI!!! nujno!!!
Napisal/-a EsEk To avg 10, 2010 5:03 pm
IMAM AUDI A6 3.0 QUATTRO .. PROBLEM IMAM S KLIMO, DA MI ZAČNE PO 20 KILOMETRIH GRET, NAMESTO DA BI HLADILA. AVTO SEM PRIKLOPO NA RAČUNALIK (VAG) IN OSTALE SO MI TE NAPAKE, KI SE NE DAJO ZBRISAT. MI LAHKO POMAGATE DALJE,. PROSIM....
Tuesday,10,August,2010,17:25:32:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
62 72
VIN: WAUZZZ4F86N041971 Mileage: 161030km/100059miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 A HW: 4F0 907 401 B
Component: 3.0L V6TDI 000AG 0020
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
No fault code found.
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3.0lTDI RdW 0030
Revision: --H01--- Serial number: 4051209
Coding: 0000001
Shop #: WSC 02327 785 00200
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10600500197427
Coding: 0001111
Shop #: WSC 00822 264 68222
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H44 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
2 Faults Found:
00380 - Special Vehicle Control Module (J608)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 161034 km
Time Indication: 0
Date: 2010.08.10
Time: 17:19:34
02639 - Antenna Reader for Keyless Access Authorization
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 161034 km
Time Indication: 0
Date: 2010.08.10
Time: 17:19:34
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4F0 910 730 R HW: 4F0 035 729 C
Component: MMI Cockpit H15 0050
Revision: C51100CE Serial number: AUZ6Z2E6L114G1
Coding: 0514005
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H07 0050
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 M
Component: KLIMABETAETIGUNGH05 0160
Revision: 00000027 Serial number: 00000030029414
Coding: 0000022
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
Shop #: WSC 02335 785 00200
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 96288 km
Time Indication: 0
Date: 2007.06.24
Time: 20:58:00
Address 0E: Media Player 1 Labels: Redir Fail!
Coding: 0514005
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD08MFVY
Coding: 0013362
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025051660315
Coding: 0002011
Shop #: WSC 02323 785 00200
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 S
Component: KOMBIINSTR. M73 H10 0630
Revision: 01000000 Serial number: 4R770LN65
Coding: 2049143
Shop #: WSC 30001 552 00000
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 12008056158084
Coding: 6CFE53C41B0104
Shop #: WSC 02325 785 00200
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00000000 Serial number: av
Coding: 0000522
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 F HW: 4F0 907 289 F
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01004977000000
Coding: 0000133
1 Fault Found:
01701 - Dimmer for Interior Lighting
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 17
Reset counter: 32
Mileage: 161030 km
Time Indication: 0
Date: 2010.08.09
Time: 13:30:04
Address 47: Sound System Labels: 4F0-910-7xx-47.lbl
Coding: 0514005
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000070246
Coding: 0001003
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00000000 Serial number: $v
Coding: 0000522
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Address 56: Radio Labels: Redir Fail!
Coding: 0514005
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000061412
Shop #: WSC 00599 264 55342
Part No: 4F0 915 105 C
Component: von VA0 1506170121
Coding: 344630393135313035432056413031353036313730313231
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H11 0030
Coding: 0000002
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H11 0030
Coding: 0000002
End ---------------------------------------------------------------------
Napisal/-a adis To avg 10, 2010 5:04 pm
ena tema bo čisto zadosti.
nasvet:
pojdi do mehanika ki se spozna na klime, da pogleda kaj je in zakaj ti klima dela obratno kot bi morala.
torej ali ti je plina zmanjkalo ali pa ti je šel kompresor.
Napisal/-a Slicker To avg 10, 2010 5:10 pm
na desni strani pri blatniku v motornem prostoru je ventil kateri uravnava delovanje klime. tisto zamenjaj in bo problem 99% rešen. stane pa ta ventil 225€ in je kar pogosta napaka na A6. zakaj se pa napake ne dajo zbrisat pa nebi vedel.
EsEk
Prispevkov: 19
Napisal/-a EsEk To avg 10, 2010 5:24 pm
TO POMENI, DA ZAMENJAM TA VENTIL IN PROBLEM BO REŠEN. KJE PA NA VAG-U LAHKO PREVERIM, ČE JE TA VENTIL???? JAZ SEM RAZMIŠLJAL DA SE MEŠA SENZORU ZA NOTRANJO TEMP.
Napisal/-a Slicker To avg 10, 2010 5:30 pm
mislim da tega ventila tester ponavadi ne zazna. pelji na servis pa reskiraj tistih 25€ da ti ga priklopijo na tester in potrdijo mojo diagnozo. lahko bi bil tudi senzor notranje temperature, samo dvomim. če pa slučajno je ta senzor, potem imaš pa problem ker so štirje senzorji not. temperature v tvojem avtu štirje in ti tester nebo pokazal kateri je zanič ;)
EsEk
Prispevkov: 19
Napisal/-a EsEk To avg 10, 2010 5:38 pm
KER LEVA STRAN AVTA JE NORMALNO HLAJENJE, DESNA PA GREJE PA TUDI ČE IMAM NA MINIMUM. DA AVTO SAMO HLADI, MORAM PRED VŽIGOM IZKLOPIT KLIMO, TEMPERATURO PA DAT NA MINIMUM. IN POL KOMPLET VSE HLADI. KAK PREMAKNEM TEMPERATURO VIŠJE .... ŽE GREJE KO NOR!!!
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI To avg 10, 2010 6:59 pm
EsEk je napisal/-a:KER LEVA STRAN AVTA JE NORMALNO HLAJENJE, DESNA PA GREJE PA TUDI ČE IMAM NA MINIMUM. DA AVTO SAMO HLADI, MORAM PRED VŽIGOM IZKLOPIT KLIMO, TEMPERATURO PA DAT NA MINIMUM. IN POL KOMPLET VSE HLADI. KAK PREMAKNEM TEMPERATURO VIŠJE .... ŽE GREJE KO NOR!!!
Nehaj se dret po forumu!
marko01
Prispevkov: 1918
Napisal/-a marko01 To avg 10, 2010 7:07 pm
menjati moreš ventil, to je edin ventil ki je na cevi od klime in ima konektor, na servisu je okoli 270 €. Ne rabiš pa lepit tu gor skoraj celo stran napak :roll: to ti bo vsak mehanik ki pozna ta avto povedal da je ta ventil ki uravnava klimo !
Lp by Mare
Re: AUDI A6 2005 --- PROBELEMI!!! nujno!!!
Napisal/-a MacTron To avg 10, 2010 7:34 pm
@EsEk: Nadaljuj kjer si zacel in ne odpiraj ostalih tem po nepotrebnem.
http://www.avtomobilizem.com/forum/view ... ?p=1309594 :!:
