Fenix_
Prispevkov: 212
Pridružen: Če apr 21, 2005 10:05 am
Kraj: Obala
Mercedes B170 2008
Napisal/-a Fenix_ Pe jan 28, 2011 9:22 am
Bi imel eno vprašanje glede resetiranja računalika za servis.
Na števcu je napis da je servis poteku že 62 dni in ta napis se ne da nikakor zbrisat.
Je kaka finta da se to resetira. Sem bil na mercedesu in pravijo da se tega ne da zbrisat če ne naredijo servisa.
Zadnji servis je bil narejen decembra 2009 in do zdej imam prevoženih 4.000 km a servis je na 15.000km
Re: Mercedes B170 2008
Napisal/-a dobek Pe jan 28, 2011 9:52 am
ce je vsaj malo podobno, kot je moj imel...
kljuc na drugo pozicijo, se sprehodis po meniju BCja do FSS (tam, kjer ti kaze, za koliko je prekoracen servisni interval), dve sekundi drzis reset tipko (tisto, s katero drugace dnevni stevec resetiras), izpise, ce hoces resetira in da naj reset drzis; drzis reset, dokler ne zapiska, potem pa izpise, da je bil interval na novo nastavljen
Fenix_
Prispevkov: 212
Kraj: Obala
Napisal/-a Fenix_ Pe jan 28, 2011 10:24 am
Probal sem to, ma ni delovalo, bom probal še tvojo varianto in upam da mi rata.
This technique has always worked for me, and is exactly as it was mentioned in my owners manuals under FSS so your mileage may vary:
Your Key Switch has 4 detents or positions.
Position 0 – Locked Wheel – Engine Off
Position 1 – Wheel Unlocked – Engine Off
Position 2 - Wheel Unlocked – Engine On – This is where you normally have the key when driving
Position 3 – Wheel Unlocked – Starter Engaged
Now you are going to use the same button, that when pressed twice, displayed your remaining time and mileage. Normally the R button.
Get in the car and close the doors. Put your finger on the R button but do not press it yet.
Turn your key to the Run (ON) Position, Number 2 from the list.
Now Press the R Button 2 times.
You will see the number of miles or days remaining for service displayed.
Turn the key to the off position within a few seconds.
Press and Hold the R Button while turning the key back to the run position (2).
Nothing has changed yet – do not panic, keep holding in the R button for 10-15 seconds more, you should hear a beep, and now the see that the system has reset the service interval. Let go of the button and you are all set.
Fenix_
Prispevkov: 212
Kraj: Obala
Napisal/-a Fenix_ Pe jan 28, 2011 2:00 pm
dobek je napisal/-a:ce je vsaj malo podobno, kot je moj imel...
sem probal, ma ne gre
h4ck
Prispevkov: 583
Pridružen: So nov 04, 2006 2:25 pm
Napisal/-a h4ck Pe jan 28, 2011 2:04 pm
Pa niso servisi 15.000km ali eno leto ? Nevem... :D
RedBull™
Prispevkov: 4315
Napisal/-a RedBull™ Pe jan 28, 2011 7:43 pm
mislim da imaš servis na vsakih 20.000 km ali eno leto (pač kar je prej)
in ker je v tvojem primeru bilo prej leto naokoli,moraš opraviti servis.
