alen89
Prispevkov: 60
Pridružen: Ne nov 16, 2008 12:38 pm
Trokiranje mrzlega motorja in napaka na računalniku
Napisal/-a alen89 Po mar 28, 2011 11:00 am
Pozdravljeni!
Avto normalno vžiga, dokler se ne segreje do delovne temparature občasno kar močno trokira (kot da nebi dobil dovolj pritoka nafte) ob pritisku na gas. Ko se segreje do delovne temparature teh težav še nisem zasledil.
Ob priklopu na računalnik je zaznal naslednjo napako:
18074/P1666 - Valve for Pump - Jet: Cylinder 1 (N240): Electrical Malfunction
Possible Symptoms
Irregular rpm
Possible Causes
Wiring and/or connections to/from the Valve for Pump Jet
Valve for Pump Jet
Possible Solutions
Check wiring and Check / Clean all connections
Replace the cable-tree to/from all the Valves for Pump Jet
Replace Valve for Pump Jet (replace them all !)
Special Notes
The ECU checks the Begin of Injection Period (BIP) by sending a very small amount of current (less than 0.0001 A ) through each injector. Because the current is so small, any extra resistance in the wiring due to damage or corrosion can cause this fault. Before replacing injectors, replace the wiring harness first.
Gre pa za VW Golf IV, letnik 03, 1.9TDI 101KM,..
Zanima me ali je imel že kdo podobno težavo? Hvala in lp
