ESX
Prispevkov: 834
Pridružen: To mar 08, 2011 11:40 am
Kerozin - Čistilo injektorjev
Napisal/-a ESX Sr nov 28, 2012 9:40 pm
Na tujih forumih sem zasledil pogovore, da večina Injector cleanerjev vsebuje nekje 85% kerozina po njihovo parafina in da na vsake toliko časa dodajo 250ml kerozina (pri nas poznan kot svetilni petrolej) v tank.
Tistih ostalih 15% pa naj bi bili različni dodatki, 2-propanol, aceton ...
I've used commercial injector cleaner in the past with good results, but after reading the ingredients (they don't want you to know what's in them, but it's actually readily available on the hazard safety data sheets Smile ) I now use my own home-brew injector cleaner in both my diesels.
My formula is 85% paraffin or kerosene, 5% ATF, 5% IPA, 5% acetone (nail polish remover) or any aromatic hydrocarbon such as Naptha or Methyl Ether Ketone, etc.
The theory is the paraffin cleans the fuel lines, pumps, etc. the ATF offsets the lack of lubricity in the other ingredients, the IPA and acetone clean combustion deposits & varnish. Added bonus is that the IPA and acetone will also absorb any water in your fuel tank and burn it off nicely.
I fill up a 500ml Evian water bottle and squirt half of it in at every fill-up, although any brand of water container will do Smile
Total cost is about £8 for 5 litres. At 250ml per tank this lasts for 20 tankfuls. So 40p-per-shot. Compare that with the cost of commercial injector cleaner.
Even looks like redex in the bottle Smile
By way of evidence, just after purchase I had problems with my mondeo and the notorious 'flashing glowplug light' - and code P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector). Went away and never came back after initially using BG244 injector cleaner then my home brew cleaner thereafter.
If I forget to use a squirt of injector cleaner for a few tanks in the mondeo, I get the fault back again Rolling Eyes
Works just as good in petrol motors too.
Tukaj je dolga tema o tem in večina ima s tem samo dobre izkušnje
http://www.alfaowner.com/Forum/alfa-155/61960-homemade-injector-cleaner.html
Je že kdo od vas poskusil to ?
Re: Kerozin - Čistilo injektorjev
Napisal/-a nebivedu Sr nov 28, 2012 9:41 pm
Bencinarju dodaš 2 deci čiste nafte na tanke goriva, pa imaš isti efekt.
ESX
Prispevkov: 834
Napisal/-a ESX Sr nov 28, 2012 9:48 pm
nebivedu je napisal/-a:Bencinarju dodaš 2 deci čiste nafte na tanke goriva, pa imaš isti efekt.
Verjetno res, saj naj bi bil kerozin zelo podoben nafti samo brez dodatkov
AgitatoR
Prispevkov: 4443
Kraj: Rbn 104
Napisal/-a AgitatoR Sr nov 28, 2012 9:50 pm
Ali pa daš 15€ na injektor za UZ čiščenje.
ESX
Prispevkov: 834
Napisal/-a ESX Sr nov 28, 2012 9:52 pm
Ja samo je malo bolj enostavno zlit to v tank kot pa injektorje vn pobirat.
Napisal/-a joztom Če nov 29, 2012 9:27 am
Nafta ne more čistiti injektorjev, lahko pa jih podmaže in hitreje in lažje delujejo. Kamen topi alkohol ali kaka druga sorodna kislina, le-ta spremeni obliko vbrizganega snopa. Pri dodajanju kar tako je potrebno nekaj znanja, sicer lahko zariba ležaj HP pumpe, obloge pa se sicer očistijo. Torej ob čistilu se vedno doda ojačano mazanje goriva.
TrijoAdijo
Prispevkov: 4168
Napisal/-a TrijoAdijo Če nov 29, 2012 1:21 pm
Ali pa narediš domačo mešanico:
vzameš STP čistilo za dizle (http://www.petronia.si/cISTILO-ZA-DIZEL-MOTORJE-05l), ga pretočiš v čisto...ampak res čisto posodo, potem vzameš 1L čiste prefiltrirane nafte in jo zmešaš s tem čistilom. Potem pa spelješ oba voda za gorivo (dovodni in povratni vod) iz bosch pumpe v to posodo.Fajn je, da imaš vmes še filter goriva.Zalaufaš motor in ga pustiš pol ure do 45 minut laufat na mestu.Rezultati bojo, kakšni pa bojo, je pa odvisno od stanja injektorjev in pumpe. Večini dizlom je šlo na bolje.Samo ne časovno pretiravat s čiščenjem.
ESX
Prispevkov: 834
Napisal/-a ESX Če nov 29, 2012 5:24 pm
joztom je napisal/-a:Nafta ne more čistiti injektorjev, lahko pa jih podmaže in hitreje in lažje delujejo. Kamen topi alkohol ali kaka druga sorodna kislina, le-ta spremeni obliko vbrizganega snopa. Pri dodajanju kar tako je potrebno nekaj znanja, sicer lahko zariba ležaj HP pumpe, obloge pa se sicer očistijo. Torej ob čistilu se vedno doda ojačano mazanje goriva.
se pravi bi bilo pametno ob tem čistilu dodati še 3dcl 2T ?
vuli
Prispevkov: 431
Pridružen: Pe jul 13, 2012 7:43 pm
Kraj: Bovec
useless
Prispevkov: 8
Pridružen: Sr okt 25, 2017 8:24 am
Napisal/-a useless Pe okt 12, 2018 3:53 pm
Res je, mnogo čistil za šobe vsebuje kerozin. Primer: STP® Diesel Fuel Treatment & Injector Cleaner http://www.stp.com/sites/default/files/STP%20Diesel%20Fuel%20Treatment%20%26%20Injector%20Cleaner%20%282015-02%29.pdf
Pozor, gre za "čisti" kerozin, ki mu odstranijo žveplo. Pri nas takega kupiš v Merkurju za 5€/1L. Išči svetilni petrolej.
