makz85
Prispevkov: 6
Pridružen: So avg 24, 2013 3:40 pm
Forc focus tdci izgubi gorivo na klancu
Napisal/-a makz85 So avg 24, 2013 3:44 pm
ze nekaj casa se mi dogaja ce avto parkiram v klanec in ga pustim cez noc, zjutraj prizge za 3 sekunde, nato crkne. Moram ga spustiti na ravno in ''verglati'' skoraj 2min da ponovno vzge, nato je dobro. Ocitno stece nafta nazaj v kestel? Pogledal sem tudi filter goriva ki je na vrhu motorja in je bil cisto prazen. Kaksna ideja kaj bi lahko bilo?
Avto je Focus karavan 2008 letnik, 1.6 TDCI 109KM
Hvala!
Re: Forc focus tdci izgubi gorivo na klancu
Napisal/-a joztom So avg 24, 2013 5:19 pm
Sicer banalna, nikakor pa ne hecna okvara, ker verglaš s pumpo brez mazanja z nafto. Takoj popravi povratni ventil, preden boš srečal špene v filtru!!
makz85
Prispevkov: 6
Napisal/-a makz85 So avg 24, 2013 7:01 pm
ja vem, samo sem mogel zjutraj v sluzbo in nisem imel izbire...bom zamenjal, upam da je to to. HVALA!
sm pozabu prasat...sj to je AGR ventil?
marko01
Prispevkov: 1918
Napisal/-a marko01 So avg 24, 2013 8:19 pm
Ne ni, to je ventil ki se najverjetneje nahaja na povratnem vodu nafte.
Lp by Mare
Ivan36
Prispevkov: 4577
Napisal/-a Ivan36 So avg 24, 2013 8:34 pm
Ok the most common fault we see regarding your issue is a partially blocked fuel filter
This is more noticeable when demanding power
These fuel filters on the 1.6 TDCI s are prone for partially blockages suspectably caused by wax debris from the internals of the filter (as this filter comes. As a complete unit and cannot be stripped )
Other faults on these 1.6 TDCI s regarding your fault are fuel pressure sensor wiring issues (usally the wiring is too tight on the loom and causes an intermitent loose connection causing a hesitation feeling when driving
Also the EGR valves were prone to water ingress but this was more so on the 05/06 models thus EGR fault would also give you black smoke
I would suspect a fuel problem from your description
The best way to clarify exactly what sub system the fault lies in is to have a diagnostic fault code check carried out as this gives more clarity on this type of issue
The best way to diagnose a partially blocked fuel filter (without just replacing it ) is to have the vehicle driven with a data logger connected to it this allows the technician to monitor the live data from the vehicles sensors etc
If on data logger the fuel rail pressure drops suddenly them you know this is where the issue lies
Partially blocked Fuel filters are the most common fault though
These filters shod be replaced every 37.5k or 3 years which ever comes first
But have seen them changed as early as 20k for this type of fault
http://www.justanswer.com/uk-ford/6v8e4 ... -gets.html
makz85
Prispevkov: 6
Napisal/-a makz85 So avg 24, 2013 9:54 pm
Filter goriva sem menjal 300km nazaj...
Napisal/-a lisko Ne avg 25, 2013 3:49 am
V samem filtru goriva (ohisjo) je verjetno nepovratni ventil. Si sigurn dobro sestavo? Ne vlece kje lufta? Ce je vse ok potem za filtrom prerezi cev in daj u mes nepovratni ventil(med filter in pumpo).
makz85
Prispevkov: 6
Napisal/-a makz85 Ne avg 25, 2013 8:15 am
Servis sem naredil 15.000 km nazaj in takrat sem menjal tudi filter goriva. Nekje 2.000 km pred zdajsnjim servisem se mi je pojavila ta napaka, zato sem iz preventive pri zdajsnjem rednem servisu se enkrat menjal filter goriva ker sem tudi sam sumil v to, vendar je napaka ostala. Filter je zamenjal mehanik, tako da mislim da ima znanje za to.
Stole
Prispevkov: 57
Pridružen: Ne jul 10, 2005 9:12 am
Kraj: Trbovlje
Napisal/-a Stole Ne avg 25, 2013 9:34 am
Ma filter goriva pumpico,da po menjavi dobiš gorivo vanj.Stari fordi ven,da so jo imeli,ta pumpica se hitro pokvari-zob časa,tudi če se ne uporablja-dvakrat so mi jo na servisu uporabili pri menjavi posledice so bile takšne kot opisuješ ti,potem sem nabavil ohišje brez pumpice in nikoli več teh problemov.
makz85
Prispevkov: 6
Napisal/-a makz85 Ne avg 25, 2013 11:53 am
Evo, imam tocno ta filter goriva...kaj pomaga? Je tukaj pumpica gor?
TrijoAdijo
Prispevkov: 4168
Napisal/-a TrijoAdijo Ne avg 25, 2013 5:57 pm
Ma tisto pumpco so imeli stari fordi....s pravim motorjem. Ta tvoj te pumpce nima. Nepovratni ventil ti je odpizdlo. Zamenjaj,zainliftaj,pa gasa.
makz85
Prispevkov: 6
Napisal/-a makz85 Ne avg 25, 2013 6:50 pm
Se še kako drugace rece ker gledam v tecdocu in ne najdem nepovratnega ventila...? Ta ventil se nahaja na pumpi?
Napisal/-a joztom Po avg 26, 2013 10:07 pm
Lahko je kot žogica za napumpat
Napisal/-a lisko Po avg 26, 2013 10:16 pm
makz85 je napisal/-a:Se še kako drugace rece ker gledam v tecdocu in ne najdem nepovratnega ventila...? Ta ventil se nahaja na pumpi?
Nahajan se verjetno v samem ohišju filtra. Tko al boš menjal ceko ohišje al pa boš nardil kot sem povedal zgoraj. Vsaka malo bolša avtrgovina ga ima....8 eurov pride....Mam na obeh dizlih dodatno vgrajen.
ucmanster
Prispevkov: 40
Pridružen: Ne sep 30, 2012 11:31 am
Napisal/-a ucmanster Sr maj 06, 2015 1:28 pm
lisko je napisal/-a:V samem filtru goriva (ohisjo) je verjetno nepovratni ventil. Si sigurn dobro sestavo? Ne vlece kje lufta? Ce je vse ok potem za filtrom prerezi cev in daj u mes nepovratni ventil(med filter in pumpo).
med ventil al pumpo? al na povratni vod do filtra?
Mam namreč sam problem da mojmu fordu 1.8 tdci zmanjkuje nafte. in pol ne vžge. Na cevi od mašine do filtra je en del cca 4 cm premera in 2 cm debel priklučen v cev. in me zanima če bi to bil lahko nepovratni ventil? ni nič na štrom vezano. a to je serijsko dano ali je moral to nekdo že na ta način težavo reševat( star avto sem kupil)
Po forumu brska: jure5j in 14 gostov
