Feroza za drag!!!
Napisal/-a nebivedu Če jan 26, 2006 8:36 am
Daihatsu Feroza with SR20 DET conversion. 400HP.
Garret ball bearing turbo.
HKS head gasket.
550 injectors.
Custom 50mm BOV.
8 point bond roll cage.
Custom auto meter dash.
Aerotec race seats.
Microtech computer.
Custom 100mm intercooler.
Hilux rear diff.
Hilux front breaks & stub axles.
Dual shocks all round.
Custom 2800lb clutch.
Genuine 360 rear wheel horsepower.
12.2 sec 1/4 mile.
Zadeva se prodaja za 12.000 australskih dolarjev.
croma_man
Prispevkov: 4288
Napisal/-a croma_man Če jan 26, 2006 9:04 am
:shock: :shock: :shock: :shock: :shock:
iz enga ekstrema v drugega (offroad dragster grounded to the floor) :D:D:D
Napisal/-a nebivedu Pe jan 27, 2006 8:51 am
Evo še en ekstrem
http://websites.golden-orb.com/ct/102734.php
One Tuff Truck
OWNER :
Ben Barlow
YEAR / MAKE / MODEL :
Daihatsu Feroza 1991
ENGINE HARDWARE :
Nissan SR20DET
ENGINE ACCESSORIES :
Garrett GT 25/30 Roller bearing turbo
Custom manifold
K&J custom intercooler
K&N 4" inlet pod filter
Turbosmart 2 stage boost controller
Intercooler water spray kit
Custom blow off valve
Microtech MTX8
EXHAUST :
3" mandrel bent stainless steel
SUSPENSION :
Modified dual shocks
Double plated chassis rails
Lowered rear leafs
INTERIOR :
6 point roll cage
Aerotech seat
Custom dash
Autometer gauges
RPM water temp, oil pressure, boost
EXTERIOR :
Rally speed bull bar
PIAA spot lights
GEARBOX :
Standard 5 speed
2800lb clutch
BRAKES :
Hilux
WHEELS & TYRES :
Cheviot rims
Goodrich all terrains
PERFORMANCE :
180kW @ the wheels
13.5 @ 102mph
Ben is starting to get used to the power of the Feroza so next on the cards is larger injectors and a boost upgrade. He is aiming for 12 second 1/4's. We'll update his time when he does it.
Liquid
Prispevkov: 1794
Kraj: ob smaragdni reki
Napisal/-a Liquid Pe jan 27, 2006 10:22 am
:shock: :shock:
hudi sta obe :twisted:
_PaPy_
Prispevkov: 558
Pridružen: Sr mar 30, 2005 2:51 pm
Napisal/-a _PaPy_ Pe jan 27, 2006 10:43 am
ufff nebivedu ti pa si manijak na tunane đipe. huda oba
_CoS_
Prispevkov: 108
Pridružen: Po jul 26, 2004 2:19 pm
Napisal/-a _CoS_ Pe jan 27, 2006 9:47 pm
Ta prvi mi je lepši, feltne in podrobnosti. drgač pa oba huda :)
PRODRIVE
Prispevkov: 2657
Napisal/-a PRODRIVE Pe jan 27, 2006 9:53 pm
Ta dva morata bit prvo usekana na terence,potem pa še na hitre terence
CARPE IMPREZAM
