chgotom
Prispevkov: 646
Pridružen: Sr mar 14, 2007 6:33 am
Kraj: Chicago, USA
Ford F-350 Super Duty Harley Davidson Crew
Napisal/-a chgotom Če maj 14, 2009 4:24 am
Tole je bolj kot zanimivost iz vrste takim. Monster Trucks, tudi na ameriskih cestah ni ravno vsakdanji pojav (mogoce spodaj v Texasu...).
Nekaj fotk:
http://cardem-enterprises.com/photos/di ... m=26&pos=0
Posast ima bencinski V10 6800ccm motor, ki razvije max 362 konjev. Tehnicno specifikacijo motorja navajam kar v originalu:
Ford's 6.8L SOHC 3V Triton® V10 Engine Specs
For pure muscle in a high-cube gas-powered engine, look no further than the new 6.8L SOHC 3V Triton® V10 in a Ford Super Duty pickup. Like its kid brother, the 5.4L Triton® V8, the 6.8L V10 features 3 valves per cylinder ( 2 intake, 1 exhaust) for increased power and efficiency. Couple this with an advanced tuned air management system, and you have outstanding load carrying and towing performance.
2007 ENGINE SPECS
2007 - Max HP - 362 @ 4750 rpm
2007 - Max Torque - 457 @ 3250 rpm
Ford 6.8L Engine Specs / Highlights
SOHC V-10 design features one camshaft in each cylinder
head operating 3 valves - 2 intake and 1 exhaust
SOHC design provides an advanced level of valve control
Deep-skirt engine block and low-friction internal components
mean greater reliability and fuel economy
Electronic Throttle Control (ETC) uses electronic sensors and
motors instead of mechanical linkage to deliver
seamless and consistent engine response
Silent-design chain cam drive contributes to durability and
helps reduce noise, vibration, and harshness
Coil-on-plug ignition system design for high-mileage durability
Centrally located, unique design, platinum-tipped spark plug
helps provide surefire ignition and complete combustion
A fail-safe cooling system is designed to protect the engine
due to loss of coolant. If the engine overheats, it will
automatically switch from 10-cylinder operation to alternating
5-cylinder operation. The vehicle will continue to operate,
but with limited engine power. This system allows the driver to
travel a short distance to obtain service or to reach a repair
facility. The distance that can be traveled depends upon
vehicle load, outside temperature, and road conditions.
a_sist
Prispevkov: 1530
Napisal/-a a_sist Če maj 14, 2009 7:07 am
Kako jim uspe iz takega motorja razviti samo 362 konjev?
gofra
Prispevkov: 1153
Napisal/-a gofra Če maj 14, 2009 7:38 am
Erm, ker jih avtomobil ne potrebuje vec? :D
Sika
Prispevkov: 193
Pridružen: Ne jul 20, 2008 11:12 am
Kraj: Rogaska Slatina
Napisal/-a Sika Če maj 14, 2009 7:56 am
heh, to je res ja, se jih ne rabi vec :D sam, bo treba it v zda malo pogledat te zverine.
Fiat di amore per'l auto
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Če maj 14, 2009 10:33 am
a_sist je napisal/-a:Kako jim uspe iz takega motorja razviti samo 362 konjev?
Ker je optimiziran za zelo široko krivulja in količino navora za vleko prikolic in prevoz tovora ipd.
primozek68
Prispevkov: 1983
Napisal/-a primozek68 Če maj 14, 2009 11:07 am
Ja najbrž ja. Tale tud slučajno ni namenjen vleki česarkoli, ampak je sam show-off.
INFINITI
Prispevkov: 7259
Napisal/-a INFINITI Če maj 14, 2009 11:52 am
primozek68 je napisal/-a:Ja najbrž ja. Tale tud slučajno ni namenjen vleki česarkoli, ampak je sam show-off.
To še zmeraj ne menja dejstva za kaj je bil motor razvit a ne?
blackmagic
Prispevkov: 504
Pridružen: Po okt 23, 2006 11:14 am
Kraj: Fram
Napisal/-a blackmagic Če maj 14, 2009 12:06 pm
Večje cole, pa v podn :rofl
Hec.
Prava zverina :bow
Who cares about
the shining of the sun
when the earth is black
\,,/ 666 \,,/
__bambi__
Prispevkov: 147
Pridružen: Sr maj 13, 2009 12:26 pm
Napisal/-a __bambi__ Če maj 14, 2009 12:15 pm
lep j :D kojnu ma pa tuk mal ker je mašina narjena tako da ima več navora in ni tuk navita kot naprimer kaka honda :D :D
fiatpowered
Prispevkov: 474
Napisal/-a fiatpowered Če maj 14, 2009 1:17 pm
to je avto za prave moške
Patrik_A3
Prispevkov: 4873
Napisal/-a Patrik_A3 Če maj 14, 2009 1:33 pm
__bambi__ je napisal/-a:lep j :D kojnu ma pa tuk mal ker je mašina narjena tako da ima več navora in ni tuk navita kot naprimer kaka honda :D :D
honda 4ever <3
DaDek
Prispevkov: 4246
Napisal/-a DaDek Če maj 14, 2009 1:39 pm
<3
LaKi_
Prispevkov: 184
Pridružen: Sr jul 14, 2004 10:51 pm
Napisal/-a LaKi_ Če maj 14, 2009 4:03 pm
Zakaj ta sploh rab parkirne senzorje, itak je meter nad vsem v kar bi se lahko zaletu :)
Težko je danes biti norec, kajti konkurenca je velika.
LaKi_
Prispevkov: 184
Napisal/-a LaKi_ Če maj 14, 2009 4:10 pm
Hja, pr njih če avto nima vsaj V8, pol to ni pravi motor za avto.
fiatpowered
Prispevkov: 474
Napisal/-a fiatpowered Če maj 14, 2009 5:44 pm
in če nima zadej kesona, je samo avto za metroseksualce...
pravi moški vedno vozi še en kup orodja v kesonu...
amerika pač...
gecco
Prispevkov: 1726
Napisal/-a gecco Če maj 14, 2009 6:24 pm
sj prav, avto naj bo uporaben, ne pa sam kup pleha v katerem se lahko voziš samo sam pa mogoče še ženska, ki pa bulš da nima več kot 50kg ker drugače bo vse drajsalo po tleh :) :P
Huda stvarca
gago
Prispevkov: 140
Pridružen: To mar 30, 2004 9:48 pm
Kraj: Krajn
Napisal/-a gago Če maj 14, 2009 8:32 pm
fiatpowered je napisal/-a:to je avto za prave moške
It is called ego buster ali po domače podaljšek kur...
The greatest trick devil ever pulled was to convince people that he doesn't exsist.
Dariooo
Prispevkov: 2810
Napisal/-a Dariooo Če maj 14, 2009 9:26 pm
lenivec je napisal/-a:
gecco je napisal/-a:sj prav, avto naj bo uporaben,
in ta avto je pa uporablen al kaj?
Uporaben je kot kak Q7, cayeene, touareg in ostali...in uporaben je, da ga lahko parkiras bilo kam (beri...pousod, razen kot v en box...) :)
chgotom a mogoče ves koliko kg ima ta avto?
A ta tudi pride v slo? kaj gre na pol, pa v dva kontenera? :)
