Kennman
Prispevkov: 600
Pridružen: Po jan 12, 2004 1:01 pm
Kraj: Velenje
Kaj je to??
Napisal/-a Kennman Po sep 06, 2004 10:03 pm
Sicer sem prebral tekst ampak ne stekam cist dober. Torej, o cem se gre in kaksni skripci so to??
http://img.sportruck.com/howto/pullies.jpg
Underdrive pullies usually consist of crankshaft and alternator pullies. These increase horsepower by reducing accessory drag. Pullies can benefit almost any engine, large or small. Installation is a snap, but there are a few disadvantages to underdrive pullies. Because the alternator is turning slower, it won't be able to produce the current needed to keep the battery charged when running at idle. If you leave your truck on idle for extended periods of time, you may want to only install the crankshaft pulley. An underdrive pulley set can add up to 15 horsepower to your engine and can also improve fuel economy.
Kennman
PiLLLe
Prispevkov: 2461
Kraj: lublana
Napisal/-a PiLLLe Po sep 06, 2004 10:09 pm
prvo kt prvo to je pomoje laz drugo kt drugo so ti pa to jermanice k jih namonetras na original :P :)
LP PiLLLe
lublancan
Prispevkov: 2785
Napisal/-a lublancan Po sep 06, 2004 10:11 pm
to zgleda kot jermenica in ne kot škripec
zdej da bi pa menu jermenice (klinastga jermena) pa ne vem no, če so drugih dimenzij porušš razmerje in ne vem kolk je to dobr razn če maš kšno kontrolo obratov al pa kej
a to je use kar piše?
podpis
Žune
Prispevkov: 528
Pridružen: So jun 21, 2003 10:16 am
Kraj: LJUBLJANA
Napisal/-a Žune Po sep 06, 2004 10:20 pm
Men tut tole ni čist jasn. Sem že večkrat to zasledil tud na ameriških forumih. Kaj to sploh naredi z motorjem?
SlikaSlikaSlika
AgitatoR
Prispevkov: 4443
Kraj: Rbn 104
Napisal/-a AgitatoR To sep 07, 2004 12:20 am
Jermen na jermen vec konjev ??
PiLLLe
Prispevkov: 2461
Kraj: lublana
Napisal/-a PiLLLe To sep 07, 2004 12:40 pm
fora tega je cista fizika. vecji kt je jermenica lazje se bo vrtel. fora tega je sam v tem da je treba vse uskladit da ti npr nebojo ventili prehiteval bate al pa kj tazga :)
Lp PiLLLe
lublancan
Prispevkov: 2785
Napisal/-a lublancan To sep 07, 2004 12:52 pm
PiLLLe je napisal/-a:fora tega je cista fizika. vecji kt je jermenica lazje se bo vrtel. fora tega je sam v tem da je treba vse uskladit da ti npr nebojo ventili prehiteval bate al pa kj tazga :)
Lp PiLLLe
za to se uporabla zobat in ne klinast jermen, ker lahk nastavš točno kdaj se more kej odpret - klinasti pa lahk zdrsne
drgač bi blo pa to edin dobr zqa alternator poganjat, pa kšno klimo
podpis
FireSTORM
Prispevkov: 2098
Kraj: Murska Sobota
Napisal/-a FireSTORM To sep 07, 2004 1:32 pm
Samotar je napisal/-a:Jermen na jermen vec konjev ??
vec koncjev ne, mogoce bi se dalo pridobit par km ce bi naredil drugacna razmerja, ampak to se ni samo tak za spilat, mores se ze malo spoznat na to stvar
LP FireSTORM :hi
vepar
Prispevkov: 1611
Kraj: nou mejst
Napisal/-a vepar To sep 07, 2004 2:12 pm
halo :roll: lažji material,pa se mašina lažje zavrti. to je manj izgub=posledično več moči
poglejte na tej strani http://www.ssgti.net/main.htm klikni tunning in potem cisto spodaj :con
PiLLLe
Prispevkov: 2461
Kraj: lublana
Napisal/-a PiLLLe To sep 07, 2004 7:02 pm
mah sami smartassi
Vrni se na Tuning
