Rjuhar
Prispevkov: 2634
MPRESIV
Napisal/-a Rjuhar Pe maj 05, 2006 10:17 am
Exterior:
- Vorsteiner CSL front bumper
- BMW OEM CSL trunk
- CSL style CF rear diffuser
- CF Kidney Grilles
- CF Side Grilles
- CF Headlight trim set
- Smoked front corners
- Black Roundels
- Silvervision turn signal bulbs
- Umnitza Predator Chromium DDE
- ProLumen 6000K HID bulbs (not installed)
Wheels & Tires:
- Kinesis F110 19x8.5 (18 lbs) and 19x10 (19 lbs) wheels
- Bridgestone S03 245/35-19 and 275/30-19 tires
- Turner Motorsport 8mm spacers
Suspension & Braking:
- Brembo GT 4-piston front calipers (custom painted yellow) with 14" front rotors
- Brembo 4-piston rear calipers (custom painted yellow) with OEM 12.9" rear rotors
- Goodridge stainless steel braided front brake lines
- Hawk HPS F+R brake pads
- KW Variant 2 coilovers
- Dinan front swaybar
- Quattro CF front strut bar (not installed)
Engine:
- Dinan Vortech Supercharger (4.6 psi Boost Pressure)
- Dinan high flow cold air intake
- Larger capacity fuel injectors
- Racing-Style aluminum radiator
- Dinan engine management System
- Dinan high flow throttle bodies
- Evosport headers with ceramic coating
- Evosport high flow cats
- Milltek section 2
- Milltek exhaust
- UUC Stage II lightweight flywheel
- UUC UltraSmooth Cerametallic clutch kit
- Rogue tranny mounts
- UUC EVO3 SSK
- UUC DSSR
- Defi control unit & BF gauges (Boost, Oil Temp, EGT)
- Modified CDV from Zeckhausen.com
- CF engine cover and other parts
Interior/Audio:
- Silver CF steering wheel
- UUC RK Shadow CF shift knob and CF e-brake
- LeatherZ alcantara shift and e-brake boots with red stiching
- LeatherZ Gauge Panel
- Valentine One radar hardwired
- OEM homelink
- Silver CF interior trim set (not installed)
- Tru Technology T-2.100 amp (not installed)
- Seas Excel 6" midbass speakers (not installed)
- Phass AT28 tweeters (not installed)
- Custom passive crossovers (not installed)
- JL 10W6v2 subwoofer (not installed)
- JL 500/1 mono amp (not installed)
...in tako dalje...
veliko slik avta najdete na http://www.efiunlimited.com/gallery/sho ... 30&cat=500
sandek
Prispevkov: 1043
Kraj: maribor-metropola
Napisal/-a sandek Pe maj 05, 2006 10:31 am
:shock: zelo lepo zgleda :D
Liquid
Prispevkov: 1794
Kraj: ob smaragdni reki
Napisal/-a Liquid Pe maj 05, 2006 10:37 am
fukish :DDD
RedWind
Prispevkov: 384
Pridružen: Če jun 24, 2004 9:46 am
Kraj: Domzale
Napisal/-a RedWind Pe maj 05, 2006 10:40 am
branu se ga neb ;)
dejvi
Prispevkov: 1003
Napisal/-a dejvi Pe maj 05, 2006 11:47 am
Slin, slin. Fookish lep. Zame najlepši model BMW sploh.
M3
Prispevkov: 1931
Napisal/-a M3 Pe maj 05, 2006 11:56 am
čeljust mi bo dol odpadla. dej rjuhar nehaj rajcat z takimi :D
george_h
Prispevkov: 102
Pridružen: Če jan 26, 2006 3:13 pm
Napisal/-a george_h Pe maj 05, 2006 11:56 am
adijo kir BMW............. :shock: :shock: :shock: :shock:
croma_man
Prispevkov: 4288
Napisal/-a croma_man Pe maj 05, 2006 11:57 am
eno drugačno vprašanje...kak se slika npr. prva slika...kaj je potrebno nastavit na fotkiču?
Napisal/-a lisko Pe maj 05, 2006 1:10 pm
croma_man je napisal/-a:eno drugačno vprašanje...kak se slika npr. prva slika...kaj je potrebno nastavit na fotkiču?
Sicer off topic.... ampak nastaviš na portret. Izbereš objekt in slikaš.... objekt ti izostri ozadje pa zamegli kot na slikci .
DoubleG
Prispevkov: 563
Napisal/-a DoubleG Pe maj 05, 2006 1:14 pm
ubijalski je, sam zgleda mi ko en fotošop :)
rok46
Prispevkov: 2861
Napisal/-a rok46 Pe maj 05, 2006 2:23 pm
mater,to hoče pomoje asvalt raztrgat :twisted: :twisted:
Vrni se na Tuning
