monster_d
Prispevkov: 10019
Kraj: Ptuj
pomoc za Yugo Cylinder Head Conversion
Napisal/-a monster_d To jun 17, 2003 2:24 pm
Torej ce kdo fajn obvlada anglescino, pa ce bi pripravljen si malo vec casa uzeti in tole malo prevesti bi mu bil hvalezen!
Saj nekaj kapcam ampak vseeno se pri vsaki drugi besedi zatakne!
SAj ni treba vse, dase nebo kdo ustrasil, ampak tako taglavne stvari!
LP monster_d
Performance Tips
Fiat SOHC Power tips
One of the things most people look for in their X1/9 or their 128, is a little bit more power. Sure, all of us want more power, but not all of us are willing to compromise streetability, reliability, fuel economy, or the look of the motor. There is a way you can get more power from your carbureted X1/9 or 128 in a weekend, without losing any of these things.
U.S. Spec X1/9's and 128's were delivered with an absurdly low compression ratio, (8.5:1) for emissions reasons, due to a relative lack of sophistication of the Fiat's emission system in the late 1970's. This results in a relatively low power output for the SOHC series of engines, which can easily be improved in a weekend.
The Yugos sold in the States from '86 - '91 all used a variant of the Fiat SOHC motor. Most that were imported used the 1116cc engine, while later cars used a 1301cc engine. There are no differences between the 1116cc and 1301cc Yugo heads. The cylinder heads from the Yugo are a direct swap for any of the carbureted Fiat SOHC motors. The advantage to using the Yugo cylinder head on your Fiat is this: Yugos were delivered with a compression ratio of 9.2:1 on the 1116cc and 1301cc engines. Higher than the Fiat CR, but not too high to create a problem running pump gas. The Yugo head has a smaller combustion chamber than any Fiat head, which provides the increase in compression, without the need for expensive high compression pistons, or expensive machine work. It also retains the non-interference benefit on the 1500 engines.
The application of the Yugo head to a Fiat block will result in the following approximate compression ratios:
Yugo head on (stock) Fiat 1300cc block: 9.5:1
Yugo head on (stock) Fiat 1500cc block: 10:1
Utilizing the Yugo head on your Fiat motor will provide a nice increase in low end torque, peak horsepower, better fuel economy, and no penalties in reliability or the need for complex, custom modifications. It fits right on, uses the same head gasket as your original engine, and looks stock.
Caveats:
There are a few caveats with the Yugo heads. I will try to explain them as best I can, so that you have all the information before you start tearing down your motor.
Fiat engines were delivered with two different sizes of head bolts/studs. All of the 1300 cars used a 12mm bolt/stud combo, the early 1500 blocks used a 12mm bolt/stud combo, and the late (80+) 1500 blocks used a 10mm bolt configuration. These can be identified by the socket size that fits them. A 12mm bolt/stud uses a 19mm socket, and the 10mm bolts use a 17mm socket. Yugos were delivered to the States with two head bolt sizes as well, Yugos from `86-late'87 used the 12mm bolts, and Yugos from 88-91 used the 10mm bolts. So, if you go looking for a Yugo head, try to get one that has the same size boltholes as your block. If you can't find a 12mm head and you need one, any competent machine shop could open up the small boltholes in the later style head for a nominal charge.
Use with fuel injected motors. At this time, I can't recommend the Yugo head conversion for FI cars, as the FI heads have an extra sensor in the cylinder head for the FI computer, and notches in the intake ports for the fuel injectors. Yugo heads do not have a provision for the Bosch FI temperature sensor, or the notches in the intake ports for the injectors. I'm sure the sensor could be added to the Yugo head in the same spot, and the notches could easily be added to the intake ports, but you're on your own here. I haven't done it, yet.
Port sizes. Yugos were only delivered to this country with 1100 and 1300 engines. Thus, the port sizes are optimized for these motors, and not the 1500. Installing the Yugo head on a 1300 engine presents no issues, but installing a stock Yugo head on a 1500 will cause some high RPM restriction. The upside to this, is the fact that it turns the 1500 into a low-end torque monster. If you like to cruise around, and don't rev the engine over 6000 rpm much, there is no problem. If you want to alleviate the high RPM restriction on the 1500, you'll need to do a decent porting job on the Yugo head.
Smog ports. This may be a benefit to some of us, depending on your locale, and emissions laws. Yugo heads have no provisions for EGR or air injection, so if you are required to have these in your area, it may not be a wise modification. The flipside is that the ports were never on the head to start with, so if there are things like that missing, you don't need to plug holes, and it looks stock.
There you have it, the easy way to get some more power out of your Fiat SOHC motor, using the same carburetor, cam, pistons, and manifolds your Fiat came with. I've picked up Yugo heads from salvage yards for less than $25, so find a head, pick up a gasket set, and you can get some more power out of your X1/9 or 128.
I have a Yugo head on my '78 1500 X1/9, and have done the conversion on several other Fiat motors, both 1500 and 1300 with great success. I highly recommend it if you're looking for an inexpensive way to increase your horsepower.
Drey #24
Prispevkov: 1009
Napisal/-a Drey #24 To jun 17, 2003 2:29 pm
Ej Monster tole je pa kr velik za prevajat :wink: !! Heh 8)
UnoTurbo
Prispevkov: 92
Pridružen: Sr maj 07, 2003 10:12 am
Napisal/-a UnoTurbo To jun 17, 2003 2:58 pm
Kokr sem jest zdele tole na hitr preletu, je avtor samo hotu povdart da je fiat v anglijo in ameriko pošiljal motorje z nižjo kompresijo. In s tem posledično je tudi moč manjša. Zastava, oziroma Yugo, pa je za svoje 1.1 in 1.3 motorje uporabljala glavo, ki je dopuščala malenkost večjo kompresijo in iz tega naslova je 1.3 motor ali 1.5 motor malenkost močnejši, saj se mu kompresija zveča. Problem naj bi bil edino pri vijakih , saj so delali dve različici. Tako, na hitro nekako, bi bilo to, to. Tako da za jugeca samo po sebi ne pride v poštev. Če boš pa staknu kakšn 1.5 motor od x1/9 pol pa je to to :)
WhiteCell
Prispevkov: 2972
Napisal/-a WhiteCell To jun 17, 2003 3:00 pm
a negre vse skjupej samo za nizanje glave in vecanje kanalov...
nic novga
V8 POWER
monster_d
Prispevkov: 10019
Kraj: Ptuj
Napisal/-a monster_d To jun 17, 2003 10:13 pm
Ja pol bo ze res!
TNX uno turbo!
glavno sem ze znizal tak da tega pomoje nebom vec rabil!
TEchno si ze porihtu glavo in 1.3 masino? Gre jo navit do 125KM!
UnoTurbo
Prispevkov: 92
Napisal/-a UnoTurbo Sr jun 18, 2003 7:08 am
Ni kej :)
Upam da bo čim manj problemčkov pri predelavah jugičev.
Čist tko off topic. Moj fotr je mel ob koncu 70-tih(uff kje je že to) stoenko,malček dodelano. 1.3 motor, obdelana glava, ostrejša odmična, 2 dvojna Webra, polirani sesalni kanali, izpuh 4 v enga(made by Jenič, zdej je to jureš), pa ostale manjše dodelave. Kokr se jest spomnim je mel redline na obratomerju okol 7000. Vem pa da se je brez uporv avto zavrtel na 9000. V glavnem za tiste cajte je šlo zlo, zlo dobr. Konjičkov je blo okol 105. Je bil pa problem k je bla sam 4 gang. No pol se je ena firma spustila v predelavo tega menjalnika in dodala 5 zobnik. Sam ni bil kos moči motorja. Tko da je ostal na 4 gang:) tretja 150:) Glih tok k serijska stoenka do daske :) No upam da nisem kej zamoru :)
*bojci*
Prispevkov: 494
Napisal/-a *bojci* Sr jun 18, 2003 7:22 am
Stoenka in obratomer?! A si ga je dal naknadno not vgradit? V defaultu ga namreč nima..
Napisal/-a nebivedu Sr jun 18, 2003 7:44 am
Imele so ga zastava 101 super je imela obratomer, je pa tut že serisko imela 1300ccm in 75 ali pa 90 KM. Smo jo imel doma belo pa komplet predelano za rally, k je fotr užival noret po cestah - vsak dan iz nm do lj, ko še ni bilo avtoceste, pa je prehiteval vse živo.
Nebivedu
P.S. k jo je prodajal je bila vredna za pol stanovanja leta 1983 na brilejevi v lj. in tko smo ta avto prodal še en kredit in smo mel dvosobno stanovanje u lj.
UnoTurbo
Prispevkov: 92
Napisal/-a UnoTurbo Sr jun 18, 2003 8:43 am
Ja naknadno je bil vgrajen :). Drugače so ga pa po defaultu imele specialke. 1.3 motor en dupli vplinjač in pa 72KM. Pa full lepe abartove litke, malenkost trše vzmetenje, "športni" zici... Sej če bi kje zdele dubu še kakšno ej bi jo prec kupu : :lol: .
.::GTR::.
Prispevkov: 1156
Pridružen: So mar 15, 2003 1:59 pm
Kraj: Gorenjska
Napisal/-a .::GTR::. Pe jun 20, 2003 12:18 am
mene pa zanima do česa sploh ''doprinese'' poliranje glave pa kanalov - kolk HP se dobi pr 1.0 mašini (3 zyl.) 40KW (prometna :) ) ?
monster_d
Prispevkov: 10019
Kraj: Ptuj
Napisal/-a monster_d Pe jun 20, 2003 12:30 am
justyGTR je napisal/-a:mene pa zanima do česa sploh ''doprinese'' poliranje glave pa kanalov - kolk HP se dobi pr 1.0 mašini (3 zyl.) 40KW (prometna :) ) ?
TEzko je rect koliko bi kaj dobil, zelo je odvisno od masine!
vec pridobis z vecanjem kanalov in nizanjem glave!
SAm mam kr fajn znizano glavo pa se kanale na sesalnem kolektorju sem spoliral pa sm zelo zadovoljen!
Par km ziher je!
Vse je odvisno tudi od strokovnosti predelave!
Seveda se vse dosti bolj pozna ce naredis vec stvari!
Recimo da se spoliras sesalni kolektor in izpusni, izpuh 4v2v1 ce ga se nimas, sporten filter itd!
Vrni se na Tuning
