dog
Prispevkov: 39
Pridružen: Ne jan 20, 2008 3:56 am
Servo volan - Touran
Napisal/-a dog So feb 24, 2018 8:51 am
Na avtuTouran 2.0, letnik 2012 se mi je ob vžigu prižgala kontrolka za volan rdeče barve ter servo volan mi več ne deluje.
Varovalke ter napetost na motor volana sem preveril in je bp. Na testerju mi kaže napako:
0003 -control unit
-circuit failure
- permanent
02546 - Steering limit stop
- Faulty or no basic setting/adaption
- Permanent
Kakšen nasvet?
Ivan36
Prispevkov: 4569
Re: Servo volan - Touran
Napisal/-a Ivan36 So feb 24, 2018 10:44 am
http://wiki.ross-tech.com/wiki/index.php/02546
02546
Contents
1 02546 - Steering Limit Stop: No or Incorrect Basic Setting / Adaptation
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
1.4 Special Notes
Possible Symptoms
Steering Assist OFF
Possible Causes
Possible Solutions
Perform Steering Limit Stop Adaptation
Make sure the Ignition is ON and the Engine is Running.
Center Steering Wheel (±10°) and hold it centered for about 5 Seconds.
Turn Steering Wheel completely to the Left and hold there for about 10 Seconds.
Turn Steering Wheel completely to the Right and hold there for about 10 Seconds.
Center Steering Wheel (±10°).
Switch Engine and Ignition OFF.
Switch Ignition ON.
Wait about 5 Seconds.
Steering Assist Warning Lamp should turn OFF (If it doesn't, perform a short Test Drive).
Special Notes
When this DTC will not clear in Mk70 and MK60 ESP equipped (1K) Golf models see the WSS (Wheel Speed Sensor) notes Here.
The Steering Limit Stop Adaptation page contains several additional notes if the procedure is not successful.
Category: Fault Codes
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
dog
Prispevkov: 39
Napisal/-a dog Ne feb 25, 2018 9:53 am
Poskusil navedeni postopek, a brez uspeha :(
Napisal/-a abbe Ne feb 25, 2018 9:17 pm
a mas mogoce slab akumulator?
dog
Prispevkov: 39
Napisal/-a dog To feb 27, 2018 9:59 am
Sem imel mogoče mal slabši akumulator. Ker mi je tester izpisal napetost 11V.
Sem poskusil z drugim akumolatorjem ki je bil čist vredu, pa je napaka ostala.
dog
Prispevkov: 39
Napisal/-a dog So mar 03, 2018 8:05 pm
Na vw servisu poskušali vse možno če bi bila napaka programska, a brez uspeha. zgleda da je res volanska letev v okvari. A kdo to popravlja v Slo.?
Cena nove originalne cca 1.200eur. Mislim da sem našel nadomestek, ki pa trenutno nikjer na zalogi. https://www.autodoc.si/lizarte/8132630
sonce123
Prispevkov: 12
Pridružen: Po maj 11, 2015 11:45 am
Napisal/-a sonce123 Ne mar 04, 2018 5:04 am
Na eBay.de poglej pod Lenkgetriebe VW Touran. Jaz vedno ko drugje nimajo dela tam pogledam. Prej pa kontaktiram prodajalca in mu pošljem podatke o vozilu. Vzamem pa takšnega, da veliko kaj prodaja pa z dobro oceno. Najboljše iz Nemčije.
Google najde za obnovo:
http://aggantar.si/sl-SI/a-165835/obnov ... nske-letve
dog
Prispevkov: 39
Napisal/-a dog Ne mar 04, 2018 1:37 pm
Kar sem okrog klical vsi rihtajo samo hidravlicne, noben ne rihta elektricnih. Bom v pon. se mal okol poklicu, ce bo kaj vec uspeha :)
AssKicker
Prispevkov: 597
Napisal/-a AssKicker Po mar 05, 2018 8:38 am
Pokliči v Lesce, Car Hifi, mogoče bo tam kej več uspeha :)
Prispevkov: 6571
Napisal/-a Fan Če mar 08, 2018 12:52 am
Se je preverilo da ne nagaja čistilec ( zmanjšan pretok )?
drinyy
Prispevkov: 67
Pridružen: Ne avg 24, 2014 1:14 pm
Napisal/-a drinyy Če mar 08, 2018 7:05 pm
Če z testerjem pogledaš kot zasuka volana kaže pravilno?
Kar je čvavek naredo vahko čvavek popraji!
Po forumu brska: Google [Bot] in 8 gostov
