mloncar
Prispevkov: 976
razlika med MAP in MAF
Napisal/-a mloncar Če sep 09, 2004 4:16 pm
naslov vse pove!
MAF vem de je mass airflow.. ..kaj je pa MAP?
RegY
Prispevkov: 6720
Kraj: MariboR
Napisal/-a RegY Če sep 09, 2004 4:22 pm
mass air pressure? nisem ziher... edino pressure mi pade na pamet
Zadnjič spremenil RegY, dne Če sep 09, 2004 4:24 pm, skupaj popravljeno 1 krat.
pugi405
Prispevkov: 1970
Napisal/-a pugi405 Če sep 09, 2004 4:24 pm
Nope, pubeci... To ti je manifold absolute pressure. 8)
mloncar
Prispevkov: 976
Napisal/-a mloncar Če sep 09, 2004 4:42 pm
in kje se nahaja MAP? MAF se nahaja pred TB, ne?
pugi405
Prispevkov: 1970
Napisal/-a pugi405 Če sep 09, 2004 4:49 pm
japan power je napisal/-a:in kje se nahaja MAP? MAF se nahaja pred TB, ne?
Manifold je sesalni trakt....
mona
Prispevkov: 24
Pridružen: Po jul 05, 2004 8:18 pm
Napisal/-a mona Če sep 09, 2004 8:01 pm
Običajno je s cevko povezan s sesalnim kolektorjem in je nekje v bližini.
GorazdO
Prispevkov: 2109
Napisal/-a GorazdO Če sep 09, 2004 8:40 pm
hm.. na Subarujih maš tule dovolj obširen članek o MAF vs. MAP:
http://www.cobbtuning.com/tech/airflow/index.html
na kratko:
MAF Sensors
Mass Air Flow (MAF) Sensor is used by the engine control unit (ECU) to determine the weight of the air going into the engine. To do this, Subaru uses a cylinder shaped sensor mounted securely to the stock air cleaner box behind the passenger side headlight assembly. Inside the sensor there is a special wire or film which is kept heated to a certain temperature. As air passes through the sensor, this wire or film is cooled and the sensor determines how much electricity is required to keep the wire up to temperature. This enables the sensor to determine how much air (in weight) is passing through the sensor at any given moment. This signal is then sent to the ECU which it compares to a preprogrammed map to deliver fuel and ignition spark, taking into account other engine inputs such as engine RPM and temperature.
Pros:
* Highly accurate A/F Ratios for a wide variety of driving conditions
Cons:
* Present a restriction in air flow
* Fragile
MAP Sensors Speed-Density systems (used on the 2000+ models) calculate the weight of air going into the engine by using a Manifold Absolute Pressure (MAP) sensor, the Intake Air Temperature (IAT) sensor and the Perfect Gas Law. To accurately determine the correct weight of fuel needed, the ECU has a Volumetric Efficiency map stored in it which it uses to calculate how much fuel must be added for a proper Air/Fuel mixture.
Pros:
# Easy and inexpensive to implement
# Very durable
Cons:
# Does not compensate very well for changes in VE
# Not very accurate A/F Ratios under transient driving conditions (ie: non-WOT street driving)
mloncar
Prispevkov: 976
Napisal/-a mloncar Pe sep 10, 2004 8:25 pm
hvala za obrazložitev!
Po forumu brska: Google [Bot] in 70 gostov
